Page 2 of 4 1 2 3 4
Re: How to fix this intake? [Re: dizuster] #3014153
02/10/22 09:23 PM
02/10/22 09:23 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Originally Posted by dizuster
Originally Posted by 66coronet
My combo is a 540 wedge:
13 to 1 comp
roller 680 lift
Indy -1 345 cnc heads
modman with a pair of edelbrock carburetors.
4.10 gear
ATI converter
Its not a real aggressive combo.
Thanks for sharing.... I saw yours has been 9.49 best? What's it weigh? Mine is a pig (currently 3740 with the turbo motor this modman 485" will replace).
It has been a good bit quicker since.
With all the ballast out it weighs 3495. I typically run it at 9.75 because its not as violent.
Re: How to fix this intake? [Re: AndyF] #3014249
02/11/22 10:01 AM
02/11/22 10:01 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Originally Posted by AndyF
Have you talked to Ken at Indy about that intake? I had a chat with him a while back and he said he had some tricks to make power with that intake. He probably has more dyno time with that intake than anyone else in the world so you might as well start there. It is a little easier to talk to Ken these days since Russ is out of the loop.
Not sure that you see this but, this is exactly what I knew but, I just wasn't going to call him to pick his brain and not make a purchase. Just the same if one of us makes a solid improvement, it just might benefit the company. Ken has always been helpful sharing what he knows. They could cast them with more runner but, then you'd still get someone cutting them out like you see frequently done on the single planes claiming that's the solution. Makes me wonder what Wilson didn't know when they modified your intakes lol.
Re: How to fix this intake? [Re: HardcoreB] #3014378
02/11/22 03:07 PM
02/11/22 03:07 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Darin Morgan says the flat floors are best in an intake because of the pulsing between the cylinders. He said a vertical divider was the worst he ever tested. Wet flow is hard to predict from what I've read about it.
Floyd Lippencott IV
Re: How to fix this intake? [Re: mr_340] #3014415
02/11/22 04:52 PM
02/11/22 04:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Worst for he was doing.
For Chrysler, it was the smallest, cheapest, lightest design to add a 2nd 4 bbl.
Horses for courses
Boffin Emeritus
Re: How to fix this intake? [Re: polyspheric] #3014630
02/12/22 10:10 AM
02/12/22 10:10 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its a shame a dual carburetor under hood intake manifold is simply not made for the 340 360 mopar. Offenhauser still makes a unit but its design is for the 273 heads. It will bolt to 340 heads but its not ideal and its a design from the 1960s. Ford and Chevy have dual plane dual quad manifolds in traditional and airgap versions and from multiple manufactures. I like tunnel rams but I really like under hood dual quad setups. Harkens back to a time where to go faster- you absolutely had to add another carburetor!
Keep old mopars alive.
Re: How to fix this intake? [Re: 2boltmain] #3014691
02/12/22 01:51 PM
02/12/22 01:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The Mod Man is available for LA, Magnum, and W2 Mopar, along with a variety of tops.
Although, these days “available” is a relative term.
Re: How to fix this intake? [Re: fast68plymouth] #3014694
02/12/22 01:58 PM
02/12/22 01:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
I had a customer try one on a 470.
He was running a 400-2, but wanted to play in the NSS stuff.
4 speed car, And he used Ede carbs.
I seem to think the big problem he had with it was a stumble right after the launch.
I don’t recall there being a big speed difference at the top end between the two.
Re: How to fix this intake? [Re: fast68plymouth] #3014722
02/12/22 03:56 PM
02/12/22 03:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
That's what the divider cures, by reducing plenum volume by 50%.
Boffin Emeritus
Re: How to fix this intake? [Re: fast68plymouth] #3014738
02/12/22 04:57 PM
02/12/22 04:57 PM
Shelby Twp. Mi
Shelby Twp. Mi
Very much appreciated and thanks for sharing. I think the best cure would be a 'pump-shot' type of carb(S ). Whatever I do to the plenum I will take into account a compromise between ideal volume, packaging limits, and fuel distribution. It's unlikely the plenum will be significantly smaller than it is now in volume.
Re: How to fix this intake? [Re: HardcoreB] #3062423
07/25/22 01:48 PM
07/25/22 01:48 PM
Shelby Twp. Mi
Shelby Twp. Mi
It's getting to be where the intake is about the last thing needing to be done, finally getting around to it.
Re: How to fix this intake? [Re: HardcoreB] #3062428
07/25/22 01:58 PM
07/25/22 01:58 PM
Shelby Twp. Mi
Shelby Twp. Mi
I lowered the floor some. The plenum will have some awkwardly shaped wood in 4places to help lengthen the runners and 'bellmouth' the extensions. I'm not sure I'll be adding much of a center divider. I do not feel it needs ANY reduction in volume for any application, if anything that bridge down the center helps RUNNER LENGTH. If we could afford more delays I would split the top and locate the carbs more central to the ports. IN THIS PIC the runner roof was just roughed-in quickly AT THE PLENUM to see better the rest of the as-cast alignments.
Re: How to fix this intake? [Re: HardcoreB] #3062430
07/25/22 02:01 PM
07/25/22 02:01 PM
Shelby Twp. Mi
Shelby Twp. Mi
General roughed runner extensions and their approx. placement.
Re: How to fix this intake? [Re: HardcoreB] #3062435
07/25/22 02:04 PM
07/25/22 02:04 PM
Shelby Twp. Mi
Shelby Twp. Mi
"filler' idears...
Re: How to fix this intake? [Re: HardcoreB] #3081896
09/30/22 08:32 AM
09/30/22 08:32 AM
Shelby Twp. Mi
Shelby Twp. Mi
I've been doing 'other things' so this went on a backburner but this is essentially what I'll try. There will be a TWO inch spacer above this and then one additional change was Scott buying the INDY "EFI" 2 AFB top which spreads the carbs apart a touch more so they are better over each runner. Talked with a few that run the modman and run well and there some basically unmodified in the plenum. That said, we could baseline it without the plenum mods..AH, NO!
Re: How to fix this intake? [Re: 2boltmain] #3093104
11/10/22 12:00 PM
11/10/22 12:00 PM
Shelby Twp. Mi
Shelby Twp. Mi
Getting closer to epoxy...life happens in the meantime.
Re: How to fix this intake? [Re: HardcoreB] #3093108
11/10/22 12:09 PM
11/10/22 12:09 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Hey hey...you're giving away our secrets! Lol
Re: How to fix this intake? [Re: dizuster] #3093126
11/10/22 12:36 PM
11/10/22 12:36 PM
Shelby Twp. Mi
Shelby Twp. Mi
This spacer was not done by me. Credit goes to Scott's long-time friend Dave. He's good, I'm a hillbilly.
Re: How to fix this intake? [Re: dizuster] #3093129
11/10/22 12:40 PM
11/10/22 12:40 PM
Shelby Twp. Mi
Shelby Twp. Mi
All the 'tricks' aren't disclosed, lol. Truth being I'd like to see Indy revise the lower casting because if this works you'd think it would sell at a premium price. Thought myself about making 'insert kits' a guy could rub and then epoxy together because...it's probably going to be better than a single 4 no-matter how bad I am.
Re: How to fix this intake? [Re: HardcoreB] #3093152
11/10/22 01:53 PM
11/10/22 01:53 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I like it!
AFAIK the ideal shape for the divider nose isn't a knife blade (frequently seen), but a full radius, where the diameter = divider thickness.
Boffin Emeritus
Re: How to fix this intake? [Re: polyspheric] #3093157
11/10/22 02:19 PM
11/10/22 02:19 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
All this work just to try and beat the old man.
Doug
Page 2 of 4 1 2 3 4
