Page 2 of 3 1 2 3
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3014771
02/12/22 07:01 PM
02/12/22 07:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by Brad_Haak
Quick update and I'll probably post more details later.
Yes, I went to Capitol today.
Yes, a bone-stock & full-interior Challenger 1320 can run in the 11s.
Yes, the DA was very good, but not "mineshaft".
Yes, the track was prepped, but it didn't hold up.
10am to 11pm. Today
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: cudaman1969] #3014866
02/12/22 11:34 PM
02/12/22 11:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by cudaman1969
Back in the day every track was no-prep, you brought your own bottle of VHT, did the burn out then squirted a puddle under each slick spun the tire then to the line. Had to watch walking around back there in sneakers, it would pull the shoe right off your foot. Racers are spoiled today, it’s all done for them. Good ole days.
Yeah, and a 9 second bracket car was the fastest thing there.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: pittsburghracer] #3014889
02/13/22 02:04 AM
02/13/22 02:04 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
10am to 11pm. Today
Where I live thats not only mineshaft its almost unbelievably good. But having lived and raced there so I believe it.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Al_Alguire] #3014969
02/13/22 11:29 AM
02/13/22 11:29 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Yeah, it's relative to your location. I used the term mineshaft to mean negative DA, since I see people posting about personal bests and "world records" in some pretty deep negative ranges.
DA was 200 to 250, so that was way better than 3000+ I've seen in the summer. This car will be in low-to-mid 12s when the heat & humidity roll in.
More stuff later...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015017
02/13/22 01:09 PM
02/13/22 01:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Heck 3000' DA is mineshaft here smoke
Glad you got tomake it and see for yourself what Capital is about now. We had good times thee while living in DC
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Al_Alguire] #3015022
02/13/22 01:20 PM
02/13/22 01:20 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Elevation @ Capitol is 120ft. Mason Dixon 540 ft and Cecil is 341 ft. For a little perspective.
America First!
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Al_Alguire] #3015024
02/13/22 01:22 PM
02/13/22 01:22 PM
Loudoun County, VA
Loudoun County, VA
The Hicks family is putting in a lot of work to make Capitol better and I was glad to get out there when the chance came up. Yesterday about 60*, this morning fresh snow on the ground.
Details, FWIW
3/4+ fuel tank to start
43 psi front
Full interior and misc stuff in the trunk
Driver ~ 210 lbs "track ready"
1) 11:35 AM
RT .128
60 1.771
1/8 7.661 @ 91.05
1/4 11.991 @ 113.75
Notes: 20.0 psi rear; crappy burnout; some wheelhop off line
2) 11:47 AM
RT .333
60 1.680
1/8 7.560 @ 90.90
1/4 11.894 @ 113.75
Notes: 20.5 psi rear; big burnout; solid launch
DA check at 11:57 AM = 175
3) 12:06 PM
RT .289
60 1.908
Notes: 21.5 psi rear; spun off line, so I let out early
4) 12:11 AM
RT .166
60 1.816
1/8 7.747 @ 90.72
1/4 12.086 @ 113.52
Notes: 21.5 psi rear; spun & hopped
DA check at 12:18 PM = 200
5) 12:31 AM
RT .142
60 2.037
1/8 8.323 @ 88.06
1/4 12.756 @ 111.66
Track scraped & sprayed cuz nobody appeared to be hooking up
DA check at 12:18 PM = 252
6) 2:01 PM
RT .067
60 1.717
1/8 7.591 @ 91.09
1/4 11.923 @ 114.27
Notes: 18.0 psi rear; big burnout; solid launch
7) 2:10 PM
RT .098
60 2.088
1/8 8.484 @ 87.68
1/4 12.921 @ 113.69
Notes: 18.5 psi rear; spun hard
8) 2:22 PM
RT .088
60 2.015
1/8 8.321 @ 88.23
1/4 12.733 @ 112.38
Notes: noticeable headwind; 18.5 psi rear; spun hard
Decided to call it a day, since the last round of track prep isn't holding up w/ the influx of cars after noon
At least my reaction times were going in the right direction...
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015026
02/13/22 01:26 PM
02/13/22 01:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Footbraking or Transbrake?
Shift rpm?
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015027
02/13/22 01:27 PM
02/13/22 01:27 PM
Loudoun County, VA
Loudoun County, VA
Also, going by all the other Challenger 1320 ET slips I've seen posted over the last couple of years, all these numbers seem right in the ballpark. Dodge advertised 11.7 at 115 when the 1320 came out in 2019, but I'm 99% sure that was a number from a car that had the passenger & rear seat delete options, which is 110+ lbs less. All the "hero runs" I see posted have cars w/ at most a 1/4 tank of fuel and anything that can be yanked out pulled to save weight.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: fast68plymouth] #3015029
02/13/22 01:30 PM
02/13/22 01:30 PM
Loudoun County, VA
Loudoun County, VA
Shift rpm?
Footbrake launch from 1500 RPM.
Shift RPM is whatever the car is programmed to do when shifting by itself in Drag Mode. I saw it swing a bit past the 6K mark, so probably about 6200.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: carnut68] #3015030
02/13/22 01:34 PM
02/13/22 01:34 PM
Loudoun County, VA
Loudoun County, VA
And MIR is a bit lower than Capitol
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015033
02/13/22 01:40 PM
02/13/22 01:40 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
What tires are on the car? Those are impressive times slips.
America First!
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: carnut68] #3015037
02/13/22 01:53 PM
02/13/22 01:53 PM
Loudoun County, VA
Loudoun County, VA
OEM fitment Nexen (Korean) 275/40R20 "Drag Spec"
They're not as soft as the M/T ET Street S/S, but probably last longer. However, all the 20-inch DRs are cursed with extremely short sidewalls. A lot of people change to 18" or 17" wheels to run tires that have taller sidewalls and improve consistency.
EDIT: Found this pic on the track's FB site. That's the last "good" run we made (11.92) and there was a really sweet A-body fastback Barracuda in the other lane. I don't know if they're someone who also posts on Moparts, though.
[img]https://www.facebook.com/ItsTrickyFilms/photos/pcb.151177707268278/151172243935491[/img]
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015080
02/13/22 05:11 PM
02/13/22 05:11 PM
K
Kiddart Offline
Kiddart  Offline
K
that is awesome Brad, best was 11.8. I will take that all day long in a true street car!! right at what they advertise. I would like to know did you data log any of the runs with the onboard computer?
Super cool picture as well!!!
Thank you
Kiddart
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Kiddart] #3015133
02/13/22 08:12 PM
02/13/22 08:12 PM
Loudoun County, VA
Loudoun County, VA
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015135
02/13/22 08:22 PM
02/13/22 08:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Right after I got my SRT in 15 I talked with a guy who had a Scat Pac 392 who was racing it, ran 11.8 with some type of drag radial and a hell cat air box. Nothing else added. Mine ran 13.1-105 mph spinning for 3 seconds on the starting line (like grease) before letting up then easing it out. Any 392 can run 11s in these 4000+ pound cars with a tire that hooks.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: cudaman1969] #3015138
02/13/22 08:31 PM
02/13/22 08:31 PM
Loudoun County, VA
Loudoun County, VA
... Any 392 can run 11s in these 4000+ pound cars with a tire that hooks.
That's what I'm seeing, too. A 1320 is just a Scat Pack 392 with some drag-focused options. Works for me.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015197
02/13/22 11:34 PM
02/13/22 11:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes unbelievable cars we have today
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: cudaman1969] #3015247
02/14/22 08:32 AM
02/14/22 08:32 AM
Loudoun County, VA
Loudoun County, VA
Speaking of which... I watched a "wouldn't give a second glance" Tesla drop a 9.44 outta nowhere.
Still boring, though.
Re: Capitol Raceway open Saturday 2/12 for T&T [Re: Brad_Haak] #3015356
02/14/22 01:46 PM
02/14/22 01:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A Tesla Plaid....Fastest poduction car made.
Page 2 of 3 1 2 3
