Running two factory 3/8" fuel lines for EFI?
#3013465
02/08/22 05:32 PM
02/08/22 05:32 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
Anyone run two factory bent/repro 3/8" hard lines for your EFI supply and return lines? I imagine there would be interference since they're trying to turn in the exact same place. Perhaps use a factory 3/8", and replicate the factory1/4" return in 3/8" manually.
Re: Running two factory 3/8" fuel lines for EFI?
[Re: AndyF]
#3013501
02/08/22 07:24 PM
02/08/22 07:24 PM
Posts: 4,741 Moved to N.E. Tennessee
GomangoCuda
If you put the pump and regulator setup inside the gas tank then you only need one fuel line. That is the way most of the modern cars are plumbed. Fixed
[Re: 375inStroke]
#3013512
02/08/22 07:47 PM
02/08/22 07:47 PM
Posts: 1,810 North Dakota
Azzkikrcuda
North Dakota
That is what I did on my car (E-Body), just have to rebend them slightly here and there to fit. I used the 3/8 Stainless lines from Inline Tube. I prefer steel hardlines to rubber for the long runs under the car.
The only Carbs I care about are under the hood!
[Re: GomangoCuda]
#3013598
02/09/22 01:04 AM
02/09/22 01:04 AM
Posts: 31,060 Oregon
AndyF
If you put the pump and regulator setup inside the gas tank then you only need one fuel line. That is the way most of the modern cars are plumbed. Fixed That is correct. Looks like I mixed up my first post.
[Re: Sniper]
#3013603
02/09/22 01:45 AM
02/09/22 01:45 AM
Posts: 3,458 Dandridge TN
Dabee
Dandridge TN
. Have used those on several efi systems I have installed. Have never had any negative issues with them.
[Re: Dabee]
#3013623
02/09/22 09:00 AM
02/09/22 09:00 AM
Posts: 1,385 Az
69hemibeep
Az
Which EFI are you looking at?
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#3013738
02/09/22 02:55 PM
02/09/22 02:55 PM
375inStroke
Seattle, WA
Holley Sniper. From their instructions: "We recommend at least a 3/8” feed line and 3/8” return line." "The Sniper EFI system requires a return fuel line to the fuel tank." "The return line must not present a pressure restriction to the return fuel flow. There should never be more than approximately 3 PSI of pressure in the return line. A line that is too small, or has restrictions will cause tuning problems with the system." Now, I watched one of their videos that says their in tank pump has a built in return, so an external regulator and return is not required. Waiting on a response from them to clarify is this pump, with the Sniper, still requires a return line or not. https://youtu.be/n8Avatc3fd4
[Re: AndyF]
#3013955
02/10/22 09:09 AM
02/10/22 09:09 AM
Posts: 1,385 Az
69hemibeep
Az
The Sniper doesn't need a return line if the regulator is in the tank. There is nothing to return if the Sniper receives 60 psi fuel. In that case you just plug the regulator out port on the back of the Sniper and you're good to go. Ive done this on two cars. Like everything else I need another sending unit pump combo that is back ordered for a 69 B-body
[Re: Cab_Burge]
#3016022
02/16/22 02:36 PM
02/16/22 02:36 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Cab, 1/2" for EFI? I mean you can but that will support a huge amount of power
[Re: TJP]
#3016089
02/16/22 05:57 PM
02/16/22 05:57 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I prefer steel hardlines to rubber for the long runs under the car. I will also mention that one big advantage of utilizing a return line is the fuel not being used recirculates back to the tank (constantly moving) thereby keeping the fuel cooler and less prone to vapor locking which really shouldn't happen at 40-60 PSI That sounds good in theory but in reality it eventually heats up all the fuel. Probably not as bad with a sniper as with two fuel rails but it still will take some heat back to the tank. My car with port EFI will heat the fuel up to 120 degrees pretty easy, I even have a cooler with a fan on the return line. I may eventually move my regulator back by the tank to prevent this but for now it is what it is. I have seen fuel temps as high as 140* in heavy traffic(I have a flex fuel sensor that also reads fuel temp).
68 Barracuda Formula S 340
[Re: INTMD8]
#3016100
02/16/22 06:19 PM
02/16/22 06:19 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Cab, 1/2" for EFI? I mean you can but that will support a huge amount of power N/A with mechanical fuel pumps only for me up to now EFI soon
