Re: b body enclosed trailer
[Re: rockerbob]
#301315
04/27/09 09:58 PM
04/27/09 09:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
And from the rear. Had to put it this far back to reduce toung weigtht. It wanted to sway when a semi assed me if I pulled it up farther. Now its steady.
Are you using a weight equalizer hitch... they are almost a must. I hauled my 26' with a 5.9 1500 for 5 years with the EQ hitch and it pulled great, stopped great(both axles with brakes). With the EQ hitch you can shift the weight around without upsetting things. I used the 1200 lbs bars ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#301316
04/27/09 10:06 PM
04/27/09 10:06 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
No just a regular hitch. I bought a new distribution set up & went to install it. However the brake controller was in the way. I need to get that relocated. It will deffinately help & I can pull the car back up if I want to.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Post deleted by Defbob
[Re: WILD BILL]
#301318
04/27/09 10:54 PM
04/27/09 10:54 PM
#301319
04/27/09 10:57 PM
04/27/09 10:57 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you had an Arrow you could use a 18ft....
Or a Radio Flyer wagon
[Re: Runner]
#301320
04/28/09 12:46 AM
04/28/09 12:46 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
I have had three enclosed trailers so far, two 24 ft 10,000 lbs GVW ![](/ubbthreads/images/graemlins/thumbs.gif) and one 22 ft. 7000 lbs GVW ![](/ubbthreads/images/graemlins/down.gif) The 1971 B bodys will fit in a 24ft and leave plenty of room to work and have a standard size cabinet(as long as the front side door is far enough forward) with a work bench top ![](/ubbthreads/images/graemlins/thumbs.gif) If your thinking of getting a golf cart then a 28 or 30 ft. is the best bet, buy the right size once ![](/ubbthreads/images/graemlins/whistling.gif) IHTHs
[Re: Runner]
#301322
04/28/09 08:55 PM
04/28/09 08:55 PM
rockerbob
Raleigh, NC
Mine dropped 2 MPG but its still worth it cause it freed up a bay in my shop. I just leave the car in the trailer now till I go to the next race.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
[Re: Runner]
#301324
04/29/09 01:52 AM
04/29/09 01:52 AM
Cab_Burge
what kind of fuel milage drop can i expect going from an open trainer to closed?
It depends on how you drive and the weight of the open trailer, I took a 850 mile trip with a freinds open trailer, it was empty for half the trip and we got 21.3 MPG with the air condition on towing at 67 MPH on mostly flat ground. I got 20.8 coming back at the same speed with a 1933 Plymouth 1/2 ton pick up truck on the trailer The most MPG I recorded with that truck towing my 24 Pace enclosed trailer empty was 15.6 MPG or so, that was towing at around 55 MPH. I usually towed a little faster than that and got 12.3 to 15.0 MPG, depending on the terrain, at around 68 MPH with the car in it That truck was a 1998 1/2 Ram 2500 2WD CTD with 3:54 gears, automatic and 235x85x16 inch tires My new truck, 2006 3500 4 wd four door with 3:73 gears, automatic, doesn't do that well Best so far has been around 12.8 at low speeds(under 75 MPH in NV.) ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Runner]
#301325
04/29/09 09:08 AM
04/29/09 09:08 AM
MR_P_BODY
thanks alot guys. i really dont see a gold cart or atv in my future. im cool with walking, i might take a bike though.
You will find that it doesnt make much difference with the weight of the trail and contents(unless REAL heavy) but the big front wall of the trailer is what kills the mileage... keep the speed down and its less pressure on the front and a little better mileage ![](/ubbthreads/images/graemlins/wave.gif)
