Re: 440 Dakota build
[Re: kenworth_goose]
#3012933
02/07/22 12:50 AM
02/07/22 12:50 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
I will be watching this. I have been casually looking for a 2wd Dakota to put a 440 or 3g hemi in. Anybody have suggestions on what years are the best for either of these swaps. I suppose the first ones are lighter and later years have a roomier engine compartment. What years would have 4 1/2 X 5 bolt pattern wheels?
[Re: GomangoCuda]
#3012957
02/07/22 08:42 AM
02/07/22 08:42 AM
Posts: 11 MI
1990A
MI
Not positive on the years with 5 bolt pattern but when i did up my 95 i was able to just replace the front 6 bolt hubs with the earlier 5 bolt direct swap and used a j-body rear axle. Nice to see the OP progress with the motor mounts i went with engine plates front and rear and used A-body hooker super comp fenderwell headers they worked out pretty good for exhaust
[Re: GomangoCuda]
#3012980
02/07/22 11:20 AM
02/07/22 11:20 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Nice. Been thinking about building a small block early Dak myself. Pretty clean ones pop up on occasion for a good price around here. I'll be following your build as well. I think '89 or '90 is the year they lengthened the front end. The earlier years take more work to put in a sb or bb. Don't remember when they changed to 6 lug wheels ('94?). There are several way more Dakota-knowledgeable folks here and hopefully they will give a definite answer. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: GomangoCuda]
#3013071
02/07/22 03:24 PM
02/07/22 03:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
My 90 v6 had 5 lugs and 91 had 6 lug 318. The 6 lug is easy to convert to 5 lug till the new body came out in 97.
I have a super clean 2wd ex cab 92 318 I would consider selling, I don't want to give it away and they are not worth much here so I was just planning to keep it but it is really nice and could drive anywhere.
Really to do a gen 3 swap I think 08 and up would be easiest because the 4.7 computer, harness and trans can be made to work, don't know how you would make it all work on the older ones without standalones trying to get along with the stock one to keep gauges and stuff all working. I think there is plenty of room in any of the engine compartments for a gen III. The one he has in this picture is the smallest engine compartment as 91 they at least lengthened it a little to accommodate the 318.
[Re: HotRodDave]
#3013117
02/07/22 05:29 PM
02/07/22 05:29 PM
Posts: 11 MI
1990A
MI
That 318 dal is it a 5sp might be interested
[Re: HotRodDave]
#3013150
02/07/22 07:33 PM
02/07/22 07:33 PM
Posts: 245 Falcon, CO
Mad-Max
Falcon, CO
cool build - that's gonna be hellafun I have an '02 QC Dakota 4x4 that I put a 440 in, along with a ridiculous load of other off-road stuff - been handling a bunch of teething problems and just now getting it rolling... - Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Oxx" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
[Re: GomangoCuda]
#3013756
02/09/22 03:18 PM
02/09/22 03:18 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I will be watching this. I have been casually looking for a 2wd Dakota to put a 440 or 3g hemi in. Anybody have suggestions on what years are the best for either of these swaps. I suppose the first ones are lighter and later years have a roomier engine compartment. What years would have 4 1/2 X 5 bolt pattern wheels? I don't know the year cutoff, but I swapped 81/4 axles, drums and front rotors on to my 92 to make it 5 lug. It was a bolt on deal no fiddling around.
#3014280
02/11/22 11:44 AM
02/11/22 11:44 AM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#3014515
02/11/22 09:03 PM
02/11/22 09:03 PM
mgoblue9798
Atlanta, GA
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25 Did you have to cut an axle to use that rear, or use a special backspacing on the wheels?
[Re: mgoblue9798]
#3014588
02/12/22 02:10 AM
02/12/22 02:10 AM
mopar65
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25 Did you have to cut an axle to use that rear, or use a special backspacing on the wheels? I did not have to cut a axle and with 15x10 wheels. used 5.5 BS
support our troops
#3115438
01/22/23 02:48 PM
01/22/23 02:48 PM
Posts: 31 Pennsylvania
19_Dart_68
Pennsylvania
Haven't posted on here in a while but here goes. I'm putting together a 440 Dakota. I bought a really clean 90 Dakota short bed and had this 440 laying around. Put a small cam in it and a set of 67 closed chambered heads to bump the compression. Which headers are those? B-body? What size primaries? What engine mounts did you use to fab ? Do you have a factory truck oil pan or an aftermarket one? Thanks in advance. I am in the middle of my 1988 440 build...It had motor plates, but I really want to use standard mounts.
68 Dart - 440 Swap in Progress...please stand by
[Re: mgoblue9798]
#3118122
02/01/23 03:01 PM
02/01/23 03:01 PM
mopar65
Also I think I could use a 15x10 wheel with 4.5/5.0 BS. But don't have any to try out right now. I would like to try like was said and widen the wheel wells and run a 15x12 wheel. I think these early dakotas look awesome with a big fat tire in the back.
support our troops
[Re: 19_Dart_68]
#3118123
02/01/23 03:03 PM
02/01/23 03:03 PM
mopar65
I can't answer for the op. But I have heard that with the big block a set of hooker 2 inch Abody fender well headers will work. But don't remember if you have to do any mods to get them to fit.
support our troops
[Re: mopar65]
#3118870
02/04/23 02:38 PM
02/04/23 02:38 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25 Just curious what's done to the engine and transmission?
[Re: OrangeProwler]
#3118908
02/04/23 05:58 PM
02/04/23 05:58 PM
mopar65
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25 Just curious what's done to the engine and transmission? The engine isn't much of a build. My friend built it as a claimer engine for a class he was racing in. He ended up building a gen3 hemi engine for his 87 dakota, so I bought thr 5.9 magnum engine off him. Here is a breK down of the build. Stock bore and stroke 2000 5.9 magnum Stock crank and rods. Clivlite full Grove rod/main bearings. ARP rod bolts. KB107 pistions. Comp 550 solid lift cam Trickflow 190CC heads. 3/8th Smith brother oil through push rods. PRW billet steel 1.6 rockers Ported indy cylinder head single plane intake Holley 650DP ported to flow close to 800cfm Hooker 1-5/8 full length headers. Turboaction built 904 transmission RMVB Coan 8 inch 5500 stall. Which I need to send in and get redone. Ford 8.8 full spool and 4.30 gears. 28x9x15 slicks. Forgot to add I installed the trickflow heads. When I got it from him. It had some EQ heads on it.
support our troops
