Page 1 of 8 1 2 3 4 5 6 7 8
572 all aluminum headed to dyno #3011969
02/03/22 06:22 PM
02/03/22 06:22 PM
AndyF Offline OP
AndyF  Offline OP
572 Indy block with Indy heads headed to the dyno. Best Machine built the long block, we added the Wilson EFI intake and the billet dry sump pan. Should have it on the dyno next week and then it goes into a '67 Belvedere for some drag racing come spring.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3011971
02/03/22 06:38 PM
02/03/22 06:38 PM
Chesterfield Twp. Mi.
John Burdine Offline
Heads...-1's or 573-13?
Re: 572 all aluminum headed to dyno [Re: John Burdine] #3011979
02/03/22 07:05 PM
02/03/22 07:05 PM
UK
rb446 Offline
rb446  Offline
UK
572-13 heads
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 572 all aluminum headed to dyno [Re: rb446] #3011998
02/03/22 07:40 PM
02/03/22 07:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The ends of the heads are machined flat.
The EZ heads are done that way.
Re: 572 all aluminum headed to dyno [Re: rb446] #3012029
02/03/22 09:36 PM
02/03/22 09:36 PM
NC
440Jim Offline
440Jim  Offline
NC
I like these dyno posts.
Looking forward to more details on the engine. To put the dyno numbers in context.
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3012040
02/03/22 10:52 PM
02/03/22 10:52 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Interested in the dry sump setup, any lifter valley scavenging?
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012052
02/03/22 11:44 PM
02/03/22 11:44 PM
AndyF Offline OP
AndyF  Offline OP
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012080
02/04/22 06:52 AM
02/04/22 06:52 AM
NC
440Jim Offline
440Jim  Offline
NC
Sounds like a powerful combo. I would love to see back to back numbers with larger headers more suited to 572 CID. How long are the dyno headers?
Is it too early for me to guess 920 HP? But the small headers may reduce peak HP.
From Indy web site for the Big EZ: CNC porting 325cc runners, 370 CFM at 0.700"
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3012124
02/04/22 11:38 AM
02/04/22 11:38 AM
AndyF Offline OP
AndyF  Offline OP
2 inch is the biggest Mopar header we have in the dyno room. The headers that fit the chassis are bigger, I think they are 2.25 but they don't fit the dyno. The dyno session is mostly used for confirming the engine is good to go as well as dialing in the EFI tune.
I'm not sure on hp so it will be interesting. I pushed my old 514 with EZ heads up past 900 hp a few times and it had some of the same parts. We used the 2 inch dyno headers for those pulls as well as the same intake and throttle body combo. My heads were a little big smaller than these heads and of course I was giving up almost 60 inches to this combo. The 280/296 camshaft is way different than anything I ran. Most of my testing was with a single pattern cam or a very small split of 4 degrees. I never ran anything with 16 degrees split like this one has. I expect this engine to make more than 900 hp but who knows, the cam and the headers might not get along well enough for that to happen.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012134
02/04/22 12:35 PM
02/04/22 12:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’ll be interesting to see how that cam works at the top end of the curve.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012141
02/04/22 01:16 PM
02/04/22 01:16 PM
gregsdart Offline
gregsdart  Offline
I bet it will nose over about 6800 rpm? May end up at 880 hp? But make great torque from 5000 up.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012164
02/04/22 02:11 PM
02/04/22 02:11 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I have no idea. 16 degrees of split is outside of my working knowledge. I ran a 280/286 in my 514 as well as a 282/288. Both of those cams worked pretty well in that engine. This is a small exhaust port so the extra duration might be what it needs. I might have been leaving power on the table with one six degrees of split. We should have numbers in a week so we'll see what they show.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012172
02/04/22 02:26 PM
02/04/22 02:26 PM
NC
440Jim Offline
440Jim  Offline
NC
Do you expect the large duration split to improve or reduce top RPM power?
I do wonder if the "small" 2-inch dyno headers (which may be longer than 30"?) will reduce the top RPM power.
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3012191
02/04/22 03:55 PM
02/04/22 03:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t know that I have an “expectation” on what it will do.
This motor has slightly bigger heads than a 580 we had on the dyno a couple years ago.
It also should have better oil/windage control, a better intake manifold, and more throttle body capacity.
The one here had a couple more degrees of intake duration, but less split.
It didn’t make anywhere near 900hp, but we weren’t expecting it to either.
Peaked at 64-6600, and didn’t really drop off till 7k(down 20hp).
I’m interested to see where the TQ peak occurs, and then how flat the HP curve is at the top end of the pull.
Basically....... can the big split help cover up for the smallish intake/exhaust ports for that displacement?
If it had “big” heads, I’m sure that trend of the extended top end would be there....... but not sure what to expect with the smaller heads.
When the induction isn’t the cork in terms of where the peaks should occur, the big split can really help move the peaks nicely up in the rpm band.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012208
02/04/22 04:59 PM
02/04/22 04:59 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
2" Headers are going to hurt HP on the dyno - we have seen more than 30+ HP loss with the smaller headers going from a 2 1/4" to a 2" to 2 1/8" stepped TTI header - I can also tell you from experience those heads did not work well for us with that cam spec on the exhaust side. Should be interesting to see what it makes - Are you going to run a vacuum pump ??
Re: 572 all aluminum headed to dyno [Re: DoubleD] #3012279
02/04/22 09:22 PM
02/04/22 09:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
It has a dry sump oil system now scope
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012330
02/04/22 11:59 PM
02/04/22 11:59 PM
AndyF Offline OP
AndyF  Offline OP
Loaded up and ready to go.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012335
02/05/22 12:11 AM
02/05/22 12:11 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Who specc’ed the cam?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 572 all aluminum headed to dyno [Re: B3422W5] #3012341
02/05/22 12:32 AM
02/05/22 12:32 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Can you give the complete cam specs ? Maybe show the cam card . Gary
Re: 572 all aluminum headed to dyno [Re: B3422W5] #3012387
02/05/22 09:34 AM
02/05/22 09:34 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If Best Machine built it I'm betting they came up with the cam grind.
