Re: Street Rockers
[Re: parksr5]
#3008941
01/25/22 06:29 PM
01/25/22 06:29 PM
Posts: 150 It's Complicated
HDNMOPERS
It's Complicated
Rocker Arms Unlimited still produce them bought a set for my build
Re: Street Rockers
[Re: Cab_Burge]
#3009616
01/27/22 02:44 PM
01/27/22 02:44 PM
Posts: 88 IL
83hurstguy
IL
The ductile rockers work really well - I had a friend with a set done by RAU (the full treatment - bushings, narrowing, their new chromed/grooved shafts, hold downs). They were done when promised and the price was over $500 for everything. They looked nice out of the box, the shimming as supplied didn't line up with the valve stems very well. The rocker bodies weren't narrowed consistently (could measure 0.020-0.030" differences between them), so every location requires a unique shim configuration. Anyways, my friend ended up buying a whole set of shims and resetting them all.
After some run time, there was some glitter coming out of the valve train, pulled the rockers off, and there were some sharp edges/burrs on various rockers that were digging into the shims. Took them all off, faced the rocker sides on sandpaper, cleaned them thoroughly, so far so good.
There really isn't another company that does this, so you have to take the good with the bad... If you get them done, plan on checking your spacing setup and check everything for sharp edges. It's disappointing, but then again, it seems to be the norm with everything in this hobby these days.
Re: Street Rockers
[Re: 83hurstguy]
#3010192
01/29/22 09:49 AM
01/29/22 09:49 AM
Posts: 4,772 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Its a shame the Isky and Crane iron rocker arms are no longer made. Mancini sells iron adjustable rockers for the LA engine at a reasonable price.
Keep old mopars alive.
Re: Street Rockers
[Re: CKessel]
#3010434
01/30/22 01:12 AM
01/30/22 01:12 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Seller is Joe Balboa that used to be out of NY selling used parts. I think he uses both addresses now. His business used to be called quickfish or something. Known for selling parts with issues. No one local to him bought from him. He’s used various names and business names over the years.
Re: Street Rockers
[Re: Cab_Burge]
#3010603
01/30/22 05:18 PM
01/30/22 05:18 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I scored a set of 69-70 vintage Isky's with the wide pad and sent them to RAS about 10 years ago. Got them back with shafts, shims, and hold downs for just under $600 in about a week. They still look like new and are performing as expected. Might be going to a small street roller soon and I have no doubt they will be fine with that deal too. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
