Too light front weight! Where do I start? (Susp setup) #3008436
01/24/22 09:32 AM
01/24/22 09:32 AM
gregsdart Offline OP
Last outing I had 53 frt/47 rear weight, was trying to control wheel stands. Since then I have lightened the front end by 130 lbs with an aluminum block and light battery.
The new weights should be 1420 rear, 1470 front, for 51 get ,49 rear.
106 wb, 30 inch ladder bars,Afco big guns for rear shocks, rebuilt Afcos up front. Currently the ladder bars are in lowest hole in front, very stiff extension setting on rear shocks. Fronts were found to be worn out at time of this slow mow video of launch.
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008438
01/24/22 09:35 AM
01/24/22 09:35 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Raise the bars. The lower they are the greater leverage on the front end. How may adjustment holes do you have? Do you have front travel limiters?
Re: Too light front weight! Where do I start? (Susp setup) [Re: fbs63] #3008442
01/24/22 10:04 AM
01/24/22 10:04 AM
https://photos.app.goo.gl/sxJiCTXrzBqSxaB3A
A slow mo vid of last pass.
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008444
01/24/22 10:10 AM
01/24/22 10:10 AM
My thinking also on raising the bars. They are in the bottom of four holes. I have front end limiters, and can tie the front end down pretty tight if needed.
I have a basic change to the whole suspension setup in mind, but before posting it, would like to hear from others with more tuning experience. I am running 10.5 x 33 Hoosiers on 14 inch rims.
Re: Too light front weight! Where do I start? (Susp setup) [Re: fbs63] #3008447
01/24/22 10:19 AM
01/24/22 10:19 AM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Raise the bars to a higher hole
Lighten the rear of the car
Tighten front shocks
Move things forward in the car
Less gear in trans (leave in second gear or 2.10 instead of 2.45 first)
....BAD A$$ STREET CAR.....
Re: Too light front weight! Where do I start? (Susp setup) [Re: n20mstr] #3008488
01/24/22 01:07 PM
01/24/22 01:07 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Took the words right from my fingertips.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Too light front weight! Where do I start? (Susp setup) [Re: EvilB1Dart] #3008504
01/24/22 01:39 PM
01/24/22 01:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In addition to what has been mentioned. Heavy battery in front of the radiator. Reduce front extension travel. Stiffer shorter front springs. If the front shocks were worn bad you may find that will cure a lot of it. My shocks have to be full stiff on rebound to keep from clicking the 60 ft with the rear tires. They are going to go in for stiffer valving yet. mine is 55% on the nose.
Doug
Re: Too light front weight! Where do I start? (Susp setup) [Re: dvw] #3008514
01/24/22 01:57 PM
01/24/22 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Have your shocks revalved by one of the many shock guys out there these days. Was the BEST thing we have ever done to the Vette, working with Adam Dryziach and we have a ways to go still. Along with what has been mentioned. Moving things up front as mentioned will help as well as tieing front end down. Also launch RPM can be lowered to keep it from "popping" up, etc etc
Re: Too light front weight! Where do I start? (Susp setup) [Re: Al_Alguire] #3008520
01/24/22 02:15 PM
01/24/22 02:15 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Horsepower, gear and ladder bars can be a tough deal to tame.
I wouldn't go crazy raising the bar pivot up. You could try it. You may be able to do it with the Big Gun valving, but if you already have them cranked up, it may be too much hit to control.
Other than that, all the things mentioned, less gear, less RPM, tie the front end down, tighten the shocks (both ends), move weight forward, etc, etc...
The gorilla in the room is the ladder bars. If this thing has the engine in your sig line in it, your going to be struggling with it forever.
My #1 answer is...
You will wish you had done it long ago after the first hit.
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008523
01/24/22 02:21 PM
01/24/22 02:21 PM
Leave the bars where they are and work on the front end travel with stiffer shocks, my car has less weight (56% on the front and 44% on the rear) on the front end with a total weight of 2850 Lbs. with me in the car. Stiffening up the front travel made the car go from 1.28 to 1.24 60 ft times. up scope
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008524
01/24/22 02:23 PM
01/24/22 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we have ladder bars on the Vette, shock valving will be the key to make it work and go fast and stay down. We used to have the same issues with it especially when we had less power and needed the pitch to make the car work. It also a very short wheelbase car at 95". Moving stuff up front was a big help and we struggled to get it to 56/44 but that was a big deal, along with the shocks the car now laves flat as a Hyundai, ok maybe a bit more aggressive, and can go 1.11 60' with a small block. We have basically zero front end travel now as well. On a really hot greasy track we might go as far as 1/2" of front end travel. But usually there is 0-1/4"
Re: Too light front weight! Where do I start? (Susp setup) [Re: Al_Alguire] #3008548
01/24/22 03:20 PM
01/24/22 03:20 PM
All of you have touched on things I was considering. Since I am so light up front, I am going to limit travel in front to about two inch and the shocks were just rebuilt. Will start very close to full stiff on extension. I have nothing left to lighten or move forward. The trunk is empty😁 I have considered going up one hole with the ladder bars to try and push the nose down at the hit, and limit the rear rise by tightening the shocks.
There is another option. My front ladder bar brackets are 1/4 plate welded to a 2x3 inch X .125 thick cross member, and looks strong enough to handle fourlink bars. The bars would have to be 28 inch long to replace the ladder bars.
I would end up with a 4 link with only a couple usable instant centers. Bars would be ten inch apart in rear, and 3 1/2 inch apart at front, about 44'" I. C. Maybe 6 inch hi. It will cost a bit for the bars, but bolt in!
Thoughts on this?
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008631
01/24/22 08:14 PM
01/24/22 08:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Al when you reduce the travel on the front as far as you do, do the front shock extension settings make much difference? Greg why can't you locate the battery in front of the radiator?
Doug
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008632
01/24/22 08:15 PM
01/24/22 08:15 PM
[my doodlings concerning the poor man's 4 link
https://photos.app.goo.gl/HXyxYiLYdTMxzDd69
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3008707
01/25/22 01:27 AM
01/25/22 01:27 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
What about doing an Ultralink type set up Greg? Not sure if anyone remembers those?
Alan Jones
Re: Too light front weight! Where do I start? (Susp setup) [Re: LA360] #3008732
01/25/22 09:26 AM
01/25/22 09:26 AM
not sure what that is?
Re: Too light front weight! Where do I start? (Susp setup) [Re: dvw] #3008840
01/25/22 01:33 PM
01/25/22 01:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Doug
Believe it or not they actually do. I can still make the car want to flip over is the extension is to loose. For instance when we run NMCA NA10.5 they are usually very tight on ext, when we run WCNA they are a fair amount looser. But I believe it is simply a function of the car we run, short wheelbase deal that would prefer to wheelie. The front pickup point on the ladder bar is basically under the drivers crotchal region smile Now that we have the shocks to control the tire/chassis we are able to control the rotation and not need the pitch. In fact we are still sneaking up on this deal trying to hit our "target" wheelspeed now that we can control it. Before we struggled to control wheelspeed and had t keep it much lower to make the car happy. The wheelie thing really is a matter of controlling the wheelspeed, but it takes some time, tweaking and very good shocks to get there.
Re: Too light front weight! Where do I start? (Susp setup) [Re: gregsdart] #3009047
01/26/22 12:13 AM
01/26/22 12:13 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
there are pics of the Ultra Link in this thread. moparts
Re: Too light front weight! Where do I start? (Susp setup) [Re: dvw] #3009109
01/26/22 10:02 AM
01/26/22 10:02 AM
Doug
Already there. You can see the battery hold down other side of the fuel cell.
Re: Too light front weight! Where do I start? (Susp setup) [Re: Al_Alguire] #3009110
01/26/22 10:04 AM
01/26/22 10:04 AM
Al, thanks for at length descriptions of your tuning. Lots of valuable info there.
