Changing van rear #3007910
01/22/22 04:09 PM
01/22/22 04:09 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have an 01 350 van with floating axel Dana with a lot of miles. Also have a 92 350 van with the non floating 9-1/4 (both 8 lugs) with low miles. My question can I swap the 9-1/4 to my 01? Eyeballed and it looks the same as far as springs and such. Both are abs
Re: Changing van rear [Re: cudaman1969] #3008370
01/23/22 10:33 PM
01/23/22 10:33 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
If they're both van axles it should bolt in fine, but you'll probably need the 9 1/4 driveshaft too. Pretty sure yours will be too short.
Re: Changing van rear [Re: 440newport] #3008390
01/23/22 11:13 PM
01/23/22 11:13 PM
fredericksburg,va
fredericksburg,va
Different size u-joints too. But in the process of changing out gears one more time.
