Did T/As have hood to radiator support seals? #3007584
01/21/22 01:32 PM
01/21/22 01:32 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Looking at Detroit Muscle Technologies they list a front hood seal for AARs with a note that says "not sure if T/A hoods had seals".
If so, can someone post some detail pics of how the seal orients and distance from bottom of hood to the mounting clip holes.
I'm working with an AAR Fiberglass reproduction T/A hood which didn't come drilled out for things like this or hood pins, etc.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Did T/As have hood to radiator support seals? [Re: Michael Ecks] #3007596
01/21/22 02:17 PM
01/21/22 02:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes there is a seal, IIRC it's the same size as the AAR seal, not the steel hood Challenger seal, when I have more time I'll dig up some photos, unless someone beats me to it....
MikeG
Re: Did T/As have hood to radiator support seals? [Re: DAYCLONA] #3007599
01/21/22 02:28 PM
01/21/22 02:28 PM
Columbus, GA
Columbus, GA
Thanks DAYCLONA, I search widely on google images. The front seal area apparently isn't the sexiest thing to photograph on T/A cars, just lots of air cleaner and hood scoop photos LOL.
Re: Did T/As have hood to radiator support seals? [Re: Michael Ecks] #3007644
01/21/22 05:08 PM
01/21/22 05:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The T/A hoods used the exact same hood to radiator support seal as the steel hood Challengers - but it was modified to work with the N94 Challenger hoods by cutting some off of each end.
Re: Did T/As have hood to radiator support seals? [Re: Michael Ecks] #3007724
01/21/22 09:29 PM
01/21/22 09:29 PM
Columbus, GA
Columbus, GA
Thanks again Dayclona, those pics are exactly what I needed!
