Page 1 of 4 1 2 3 4
anyone using an 8.8 Ford in a B body? #3007341
01/20/22 06:45 PM
01/20/22 06:45 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
Due to availability and cost I am considering using an 8.8 Ford Exlporer Rear in my 70 Satellite. the width seems close enough (5/16 wider per side) just need to move the spring mounts. Has anyone used one of these?
Thanks Shane
Re: anyone using an 8.8 Ford in a B body? [Re: 70rrclone] #3007348
01/20/22 07:14 PM
01/20/22 07:14 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
down
Master, again and still
Re: anyone using an 8.8 Ford in a B body? [Re: DaveRS23] #3007351
01/20/22 07:24 PM
01/20/22 07:24 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Have never used on in a B body but have used them in several street rod builds. Especially the ones with disc brakes. In fact I’m putting one in the 1948 Federal Motors truck street rod I’m currently working on. Paid $250.00 3.73 posi and disc brakes. up
Re: anyone using an 8.8 Ford in a B body? [Re: DaveRS23] #3007352
01/20/22 07:24 PM
01/20/22 07:24 PM
La Grange, Ky
La Grange, Ky
Ok so you had nothing of value to add. for Dave.
Thanks!!!
Re: anyone using an 8.8 Ford in a B body? [Re: 70rrclone] #3007360
01/20/22 08:01 PM
01/20/22 08:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Some appear to have a different pinion yoke design so you may have to mod your driveshaft end.
I think they are reasonably durable.
What do you do for a pinion snubber?
Re: anyone using an 8.8 Ford in a B body? [Re: 70rrclone] #3007369
01/20/22 08:38 PM
01/20/22 08:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: anyone using an 8.8 Ford in a B body? [Re: Neil] #3007382
01/20/22 09:17 PM
01/20/22 09:17 PM
La Grange, Ky
La Grange, Ky
I'll have to look at it closer but I think it has enough of a flange on each side that I cab fab up a snubbed for it. It has some kind of anti rotation shock on it so I may be able to use that also. The buy-in was less that $100 for a 3.73 posi rear complete with brakes and swaybar. So I figured it would be worth a shot. I have a 1350 u-joint flange on the way along with some spring mounts.
Shane
Re: anyone using an 8.8 Ford in a B body? [Re: 70rrclone] #3007384
01/20/22 09:22 PM
01/20/22 09:22 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Make sure to check the pinion offset. I know one side of the housing is a lot longer than the other.
Re: anyone using an 8.8 Ford in a B body? [Re: Dabee] #3007390
01/20/22 09:32 PM
01/20/22 09:32 PM
Ky.
dart67 Offline
dart67  Offline
Ky.
Hey, Russ. Where did you find the 8.8 ford rear? Junk yard? Marketplace?
Thanks, Kevin
Re: anyone using an 8.8 Ford in a B body? [Re: dart67] #3007396
01/20/22 09:50 PM
01/20/22 09:50 PM
La Grange, Ky
La Grange, Ky
I got mine out of a u pull it in Louisville
Shane
Re: anyone using an 8.8 Ford in a B body? [Re: 70rrclone] #3007409
01/20/22 10:13 PM
01/20/22 10:13 PM
GA
roadrunninMark Offline
GA
Here is a good post for swapping into an A body. You probably can use most of the info and adjust accordingly for a B. I looked into this for an e body but I decided to stick with the 8 3/4 and upgrade the rear brakes to disc in the future. I will use the mopar action Jeep Liberty parts write up and save 50lbs over the drums... and also keep it all mopar. https://www.forabodiesonly.com/mopar/threads/8-8-swap.89918/
Re: anyone using an 8.8 Ford in a B body? [Re: roadrunninMark] #3007434
01/20/22 11:37 PM
01/20/22 11:37 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
That's what Tony and Lucky did in the 5.7 Duster on Hot Rod Garage.
Used a extra stick short axle when the shortened the one side.
It they were u lucky in that the 373 gear was there and dusk brakes but did not have posh.
They assumed it was a post and think they went spool.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: anyone using an 8.8 Ford in a B body? [Re: dart67] #3007446
01/21/22 01:09 AM
01/21/22 01:09 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Thanks, Kevin
Local junk yard. Been dealing with them for last 14 years.
Re: anyone using an 8.8 Ford in a B body? [Re: Dabee] #3007511
01/21/22 10:17 AM
01/21/22 10:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Most of them are 3.73 and some are even 4.10 geared. The disc brake years have 31 spline axles. I have had one in my Jeep for 16 years.
68 Barracuda Formula S 340
Re: anyone using an 8.8 Ford in a B body? [Re: DaveRS23] #3007643
01/21/22 05:06 PM
01/21/22 05:06 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Originally Posted by DaveRS23
down
So do you drive Mopars that have saginaw steering pumps or tilt columns (gm stuff)?
Re: anyone using an 8.8 Ford in a B body? [Re: mgoblue9798] #3007664
01/21/22 05:50 PM
01/21/22 05:50 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
yes , i do drive dodges with tilt columns. we have 14 dodge trucks and all but 1 have tilt columns in them. no big deal. a friend of mine has the long axle side cut and uses the short axle in his. he has them in his 68 rambler american and his d50.
Re: anyone using an 8.8 Ford in a B body? [Re: mgoblue9798] #3007682
01/21/22 07:01 PM
01/21/22 07:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
down
So do you drive Mopars that have saginaw steering pumps?
Yep. IF it came from Ma Mopar. The OP is free to put any cheap other manufacturer's parts on his Mopar that he wants. And here in the US we are free to express our opinion of it. Or do you believe that we are not free to express our opinion?
Re: anyone using an 8.8 Ford in a B body? [Re: DaveRS23] #3007707
01/21/22 08:26 PM
01/21/22 08:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Some of us still live on a budget. $200 for a 10 year old 8.8 with 3:73 gears and a limited slip and disc brakes compared to $800 for a 50 year old 8 3/4 with a 2:96 open gear center (if any) and shot 10" drum brakes, or a $200 wide width 9 1/4 that needs everything rebuilt, or any 8 1/4 with poor gear choices that probably won't handle the power, or a $2000 for an aftermarket Dana rear, pretty much bare, for something I just want to drive and have some fun with, doesn't make a Mopar supplied rear end very logical. The only useable Mopar delivered rear axle that would fit our old stuff from the last 20 years would have had to come out of a truck, those choices are not good, and most do not have matching bolt patterns, where the 8.8 at least has the 5 on 4 1/2" bolt pattern.
I'm a pretty hard core Mopar guy, but at some point you have to face reality. Gene
Re: anyone using an 8.8 Ford in a B body? [Re: poorboy] #3007725
01/21/22 09:35 PM
01/21/22 09:35 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Used one from an Exploder in my Wrangler.
Came with a 4.10 L/S, disc brakes. Strong unit, great swap that uses the same wheels.
Would recommend this rearend, it takes a lot of abuse.
It takes 33" tires hill climbing and pedal to the floor. It should hold up perfectly fine on the street.
Re: anyone using an 8.8 Ford in a B body? [Re: 65Fury440] #3007763
01/22/22 12:44 AM
01/22/22 12:44 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Put an 8.8 in a 56 Dodge truck I built for a friend. Reason was he wanted disc brakes on the rear. This truck is street / strip and has a 408 magnum in it making about 525 hp. That was five years ago. The 8.8 is holding ip good.
Page 1 of 4 1 2 3 4
