Page 3 of 4 1 2 3 4
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006776
01/19/22 01:04 PM
01/19/22 01:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
all 6bbls had the street hemi spring; whether yellow or green stripe.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006777
01/19/22 01:17 PM
01/19/22 01:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I think we've shown with the part numbers that this is incorrect.
Re: Are all 6 pack cams low taper design? [Re: Sniper] #3006810
01/19/22 02:28 PM
01/19/22 02:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
apply some logic. why would you need a low taper cam if you didn't have big springs?
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006811
01/19/22 02:29 PM
01/19/22 02:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
some stuff i found in old paper work.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006814
01/19/22 02:33 PM
01/19/22 02:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
more
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006817
01/19/22 02:59 PM
01/19/22 02:59 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Transman
Originally Posted by cudaman1969
Flat faced lifters.. goes against saying lifters have to have a crown don’t it.
I corrected my post, the lifters I have appear to be flat as described.
The cam they ran on (low taper lobes) have wear across the whole width of the lobe but has a higher wear pattern to one side.
I corrected my earlier post where I said the lifters were not flat.
We cool, reason I’m asking is I have a set of Hemi solids (original) that I got in a package deal that are flat and look like new, was going to send off to reface but if that’s the way it’s supposed to be I’m happy.
Re: Are all 6 pack cams low taper design? [Re: cudaman1969] #3006822
01/19/22 03:19 PM
01/19/22 03:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Don't mean to sidetrack this but has anyone found a direct replacement for the 2121154 Lubrizol? Note I didn't say equivalent, I said direct replacement.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006830
01/19/22 03:24 PM
01/19/22 03:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What logic would that be? In 1969 the 6bbl had it's own unique part number valve spring. The Hemi in 1969 used a different part number valve spring.
In 1970 the Hemi started using the same part number as the 1969/70/71 6bbl spring.
Reality states the Hemi started using the 6bbl valve spring in 1970 and that the 6bbl NEVER used the Hemi spring.
Re: Are all 6 pack cams low taper design? [Re: Sniper] #3006852
01/19/22 04:19 PM
01/19/22 04:19 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Great info!!!!! Thanks!
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3006856
01/19/22 04:27 PM
01/19/22 04:27 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
there is a set of NOS lifters for sale on ebay for the 6 pack cam
Re: Are all 6 pack cams low taper design? [Re: cudaman1969] #3006945
01/19/22 08:12 PM
01/19/22 08:12 PM
A727Tflite Offline
A727Tflite  Offline
When I checked my parts I find that the Mopar solids from back in the day are flat faced. In original packages that I have. I checked a few sets.
So it sounds like you are golden.
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006983
01/19/22 09:35 PM
01/19/22 09:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Woopee, original 68 lifters, you know they have good metal in them. Kinda blows the idea of crowns right out of the water don’t it
Re: Are all 6 pack cams low taper design? [Re: cudaman1969] #3007022
01/19/22 11:01 PM
01/19/22 11:01 PM
A727Tflite Offline
A727Tflite  Offline
If you find an extra one I would be glad to buy it from you - somehow I ended up with 15. mad
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3007130
01/20/22 11:31 AM
01/20/22 11:31 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Originally Posted by 6PakBee
Here is the '69 TSB. Note the comments for the camshaft and the tappets.
This ^ was the announcement for the dealer service departments. Here is the announcement for the Six-Pack Superbees to the dealer salespeople:
Re: Are all 6 pack cams low taper design? [Re: Sunroofcuda] #3007163
01/20/22 12:56 PM
01/20/22 12:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I love all the old bulletins and stuff, they are fun, but might be best taken with a grain of salt.
They are Marketing documents at the core.
They want you to feel like a technical person when you're reading them, but won't provide any specific technical information.
Try flat lifters today and let me know how that works out....it won't be long, and they will be concave lifters.
This is the same group that sold the 1968 383 high performance by telling us it had "440 heads", as if
that was something novel and amazing. Meanwhile the 2 barrel engine had the same heads....
This is the same group that (later) gave us the heavier "6 pack rods" as a durability upgrade instead of addressing
the problem at the source (the boat anchor heavy pistons).
This is the same group that could have very easily crossbolted every Wedge block after the durability upgrade to the Hemi was
brought into production, but decided it would be better to save 75 cents.
Be careful you don't accept half truths out of love for the brand.
Notice they're saying it's a flat faced lifter but no specification is given.
Notice they're saying the cam lobes have less taper but no specification is given.
No specs=Marketing trash
How much was standard? Not saying.
How much was it reduced? Not saying.
Under what conditions is durability improved? Not saying.
Meh.
Very possible to sell standard lifter having a crown of .0015, and a "flat faced" lifter having a crown of, say .0011 that you purchased from another supplier,
create two different part numbers, and increase durability under one subset of conditions while potentially reducing it under others.
Marketing isn't going to allow you to mention the potential reduced durability at low speeds or wherever the compromise happens to be.
(There is always a compromise....with everything)
If the flat lifter and reduced taper design were so vastly superior under all conditions, why weren't they included in
every 440 HP after the dawn of the 6 pack? Surely it would have reduced warranty claims, but it didn't happen.
Why didn't the 426 HEMI....the ultimate, most expensive engine they had,
also have low taper cam and flat lifters? Why didn't the 383? Because: Marketing Trash.
It's probably more likely the 3 bolt cams were ground by another supplier who gave Chrysler a different taper spec by default,
it passed testing and "there you go: It is now a SPECIAL CAMSHAFT".
I've held the old prints for alot of these kind of parts in my hand, most of them say nothing and leave much to
supplier interpretation.
twocents
Rich H.
Esse Quam Videri
Re: Are all 6 pack cams low taper design? [Re: ZIPPY] #3007184
01/20/22 01:40 PM
01/20/22 01:40 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Zippy, well said - obviously you put a lot of thought into that. BUT, what is in the past can't be changed & it's fun to look at old documents from back-in-the-day, as well as look at old original components & see where we have evolved to.
Re: Are all 6 pack cams low taper design? [Re: Sunroofcuda] #3007189
01/20/22 01:47 PM
01/20/22 01:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Are all 6 pack cams low taper design? [Re: ZIPPY] #3007227
01/20/22 02:58 PM
01/20/22 02:58 PM
New York
R/T1968R/T Offline OP
New York
I think at this point I will use it as a good core for a regrind!
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3007861
01/22/22 02:16 PM
01/22/22 02:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It would be easy enough to stick the cam in a lathe and run an indicator across the lobes and see what the lobe taper on that old cam really is.
Re: Are all 6 pack cams low taper design? [Re: moparx] #3007998
01/22/22 09:55 PM
01/22/22 09:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by moparx
Joe, hurry up and get a pad and pencil out, start writing stuff down before you forget, or the cobwebs take control like they have of me ! laugh2
beer
X2 thumbs popcorn
Page 3 of 4 1 2 3 4
