Re: Are all 6 pack cams low taper design?
[Re: cudaman1969]
#3006655
01/19/22 12:59 AM
01/19/22 12:59 AM
Posts: 3,089 Michigan
A727Tflite
Flat faced lifters.. goes against saying lifters have to have a crown don’t it. They are not flat, wrong description. Edited - they appear to be perfectly flat - at least to the naked eye after checking some that I have.
[Re: lewtot184]
#3006707
01/19/22 08:50 AM
01/19/22 08:50 AM
Posts: 6,305 nowhere
Sniper
nowhere
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. 6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better. The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following. 1969 Hemi - 2899549 6bbl - 3418491 1970-71 Hemi - 3418491 6bbl - 3418491 So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did.
[Re: Sniper]
#3006709
01/19/22 08:59 AM
01/19/22 08:59 AM
Posts: 3,916 usa
lewtot184
usa
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. 6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better. The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following. 1969 Hemi - 2899549 6bbl - 3418491 1970-71 Hemi - 3418491 6bbl - 3418491 So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did. i suspect there may have been a manufacturer or supplier change for the part number change. original single street hemi springs had the yellow stripe and at some point later they were a green stripe. so there was a change and the 34xxxxx number tells me sometime after 1970. the 28xxxxx number would be correct for '68 and '69. anyhow i have some yellow and green stripe springs and the wire size, height, and spring rate are the same. i remember buying this stuff back in day but that's been so many decades ago.
[Re: Sniper]
#3006713
01/19/22 09:24 AM
01/19/22 09:24 AM
Posts: 3,916 usa
lewtot184
usa
All I can say is that the 4bbl 440 used a different part number spring, same as the 383's did in 69. In 70-71 they used one of two different springs, depending on application I suspect Magnum vs non-Magnum type differences here. No mentions in any of the springs listings of stripe colors so no help there.
Nowadays, there are better choices. the non-hipo 256 cam did use a different spring. most i've seen were painted a greenish color and i think may have had an extra 1/2 or maybe 1 coil. the hypo wedge has,IIRC, an extra coil than the street hemi. factory cams back then had very mild ramp speeds and long closing ramps which didn't need a lot of spring. they were only 4500rpm engines.
[Re: 3hundred]
#3006717
01/19/22 09:47 AM
01/19/22 09:47 AM
Posts: 2,531 God's Country Maryland
GODSCOUNTRY340
Okay, I am going from memory so take this all with a bag of salt. The standard 440 valve gear was good for about 5800 rpm. Chrysler wanted to raise this to about 6200 rpm. So they installed heavier springs on the Six-Pack motors. Heavier spring...more cam load....a low taper lobe provides more contact area and maintains engine durability with the higher loading. Again, I'm going from memory and I only have two functioning brain cells left. If yours are gone, mine are too. It was also the rationale for the HD rocker arms which Direct Connection later claimed they'd reinforced the wrong end, FWTW. From this thread I assume low taper lifters are made of unobtainium? Which would make an NOS 6 pack camshaft a paper weight? It's no paper weight, just use the crowned lifters with it (new). Break it in normally and use a zinc oil, good to go.
[Re: Sniper]
#3006733
01/19/22 10:52 AM
01/19/22 10:52 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. 6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better. The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following. 1969 Hemi - 2899549 6bbl - 3418491 1970-71 Hemi - 3418491 6bbl - 3418491 So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did. Excellent research. Since I have an A12 I frequently find myself restricting a Six-Pack discussion to 1969 which can be, as it is in this case, a mistake. Thanks for the clarification.
[Re: Cuda340]
#3006737
01/19/22 11:00 AM
01/19/22 11:00 AM
Posts: 3,916 usa
lewtot184
usa
Does anyone have a pic of the six pack rocker arms vs the non-six pack rockers? Is there a part number stamped in them for identification purposes? think the "6pak rocker" was standard on 4bbl engines. my '69 r/t (4bbl) has the original rockers on it and they are the improved version vs the '68 and earlier. i don't have any original '68's but do have mopars re-pops and there is a noticeable difference. i'll try get some pics of the two later. the later rocker was used on '70's smog engines too so you're not boxed in by "6pak specific".
[Re: 6PakBee]
#3006745
01/19/22 11:35 AM
01/19/22 11:35 AM
Sniper
nowhere
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. 6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better. The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following. 1969 Hemi - 2899549 6bbl - 3418491 1970-71 Hemi - 3418491 6bbl - 3418491 So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did. Excellent research. Since I have an A12 I frequently find myself restricting a Six-Pack discussion to 1969 which can be, as it is in this case, a mistake. Thanks for the clarification. Thank you. You know, looking at it again, the statement that the 6bbl never used the Hemi springs is correct. The Hemi, however, started using the 6bbl springs in 70-71. Semantics? maybe, but interesting. As for rockers, when I converted my 64 413 to 906 heads I also used the later style rockers and there was a noticeable difference in metal thickness. At least to the eyeball, if I ever measured it I have forgotten those numbers, that happened in 1988 so time erased those memories, lol. My 413 was a bit of an oddball. It was originally stamped with a T then over stamped with a V. Indicating, to me, it was a 63 413 put into a 64 model car. The casting number ended in 3200, 63, it had rocker stands, last used in 63, and 4 bolt valve covers, again last used in 63. I do not recall the SPD of that car, it may have been an earlier 64 MY one. Who knows.
[Re: lewtot184]
#3006756
01/19/22 12:07 PM
01/19/22 12:07 PM
Posts: 1,710 central il.
second 70
central il.
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. 6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better. The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following. 1969 Hemi - 2899549 6bbl - 3418491 1970-71 Hemi - 3418491 6bbl - 3418491 So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did. i suspect there may have been a manufacturer or supplier change for the part number change. original single street hemi springs had the yellow stripe and at some point later they were a green stripe. so there was a change and the 34xxxxx number tells me sometime after 1970. the 28xxxxx number would be correct for '68 and '69. anyhow i have some yellow and green stripe springs and the wire size, height, and spring rate are the same. i remember buying this stuff back in day but that's been so many decades ago. The hemi changed from a flat tappet cam and lifters to a hydraulic setup in 1970. That's why the springs changed.
[Re: cudaman1969]
#3006765
01/19/22 12:29 PM
01/19/22 12:29 PM
A727Tflite
Flat faced lifters.. goes against saying lifters have to have a crown don’t it. I corrected my post, the lifters I have appear to be flat as described. The cam they ran on (low taper lobes) have wear across the whole width of the lobe but has a higher wear pattern to one side. I corrected my earlier post where I said the lifters were not flat.
[Re: A727Tflite]
#3006771
01/19/22 12:56 PM
01/19/22 12:56 PM
Posts: 3,916 usa
lewtot184
usa
the heavy duty so called 6pak rocker
