Page 2 of 3 1 2 3
Re: Anyone shoot A4 silver recently? [Re: Pacnorthcuda] #3080042
09/23/22 04:19 PM
09/23/22 04:19 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
It can be confusing but 1971+ Winchester Gray
Was PPG formula 2314, but coded A4.
1969/1970 Silver Poly was PPG formula 2016, and also coded A4.
They have a noticeably different appearance because the mixes are different.
The ‘69/‘70 2016-code mix is the one I was chasing and seem to have nailed down.
Lots of black accents goes great with either.
Mine originally had black top, black lower body (69 gtx), black hood stripes.
A lot of that is going away for personal taste reasons as this is definitely not a
Strict restoration, but it will have enough black left to give some contrast.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3080052
09/23/22 04:46 PM
09/23/22 04:46 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
https://www.forabodiesonly.com/mopar/threads/race-day-in-michigan-us131.521791/
Scroll down to post 13….
If it’s right(A4) it’s got a discernible green “ tinge” to it.
Love the color, gets lots of compliments
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3080196
09/24/22 09:33 AM
09/24/22 09:33 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
It definitely is slightly green.
The color inherently flops quite a bit depending on the lighting and how much sun it's getting, and I'd have to say that's probably my favorite thing about it.
The sprayout is on the old cut off door skin and pretty large (about 1' x 2') so I could really get a feel for it.
I moved it to various places outdoors while I worked on the car with the service door open.
As outdoor conditions would change, I'd take a peek to the side to check it out as clouds rolled by/sun would get brighter and so on.
The more I looked at it, the more I loved it. Couple times I had to step out for a closer look.
I will also say this is the second sprayout I've attempted.
The first was through Tamco and, although it was a beautiful color it did not flop to green, it was a little too gold/beige and totally missed the mark.
This second was through PPG and as expected + as everyone says it was right on the money, no need to change anything about it.
Was expecting problems and ended up a little surprised how user friendly it was to spray.
Two medium wet coats of base and it looked great. Could have stopped there.
I had a little left in the cup so I did an orientation coat just to see how it would behave, but TBH it did not seem to need it.
Of course staying consistent with the technique throughout the whole car (especially in awkward places like inside the trunk and so on) is the actual struggle there, and the challenge is to adapt and overcome.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3080254
09/24/22 12:06 PM
09/24/22 12:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Hey Zip…..
One thing I noticed too( after being stubborn/ unsure etc, about it…..I got talked into getting my car ceramic coated recently by the guy who runs the detail shop we use.
All I can say is, wow, it really made the color pop. Paint looks knee deep.
Couldn’t believe the difference. Have some pictures of it after being done on Facebook.
I know you aren’t at the point to even think about this, but when you do…..do it!
1.41 best 60 foot
6.56 at 104.17
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3080463
09/25/22 10:22 AM
09/25/22 10:22 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I'm surprised no one mentioned that silver was a color that you shouldn't buy back in the day. The reason was it would breakdown faster than any other paint color. Paint of all kinds have improved massively since back then and since you have the the factory color just get the same color in a modern paint formula. You can use the link for reference for different paint manufactures.
link
Re: Anyone shoot A4 silver recently? [Re: Moparite] #3080541
09/25/22 02:39 PM
09/25/22 02:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
link
SAME AS PLUM CRAZY..MY CAR WAS RED PRIMER WHEN I BOUGHT IT WITH SMALL PATCHES OF PURPLE
Re: Anyone shoot A4 silver recently? [Re: ph23vo] #3080574
09/25/22 04:48 PM
09/25/22 04:48 PM
New York, USA
Chargerfan68 Offline
New York, USA
So, is it agreed and accepted that A4 for 1969 is same formula as AA1 for 1968?
A few years ago, I was able to get 2 gallons of RM AA1 for my 68 charger. I did a test sprayout on a new valence corner from AMD It def has a slight greenish tint in certain light. Looks just like the orig color that is remaining in certain areas of my Charger.
That was about 7 years ago and I heard they have gotten rid of certain toners.
Re: Anyone shoot A4 silver recently? [Re: Chargerfan68] #3080778
09/26/22 10:51 AM
09/26/22 10:51 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
1968 AA1 should be PPG 8588.
Over the years, I developed the opinion the AA1 leans towards green a little less than 1969/1970 A4.
The leaning is still there. Just different.
Disclaimer: Just an opinion and I'm no expert....Someone with a PPG mixing bank could confirm or deny any potential difference in the formulas....I am just trying to turn out good quality work/fairly closely match what I have and wouldn't debate that any more than I'd debate the word "buffed" in the description of one of them LOL.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: Pacnorthcuda] #3080794
09/26/22 11:43 AM
09/26/22 11:43 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Originally Posted by Pacnorthcuda
That’s Winchester Grey right? I always thought a black vinyl top pared well with that!
In 1969 A4 was silver. Later, (71 I think) the A4 code was the Winchester/Gunmetal color.
Not sure when it changed exactly but they are NOT the same color....
And yes the 69 version def has some green in certain light. And IMO it looks great with the black trim, stripe, but I am biased...
Zip make sure you let us all see how it turns out!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Anyone shoot A4 silver recently? [Re: wingman] #3081339
09/28/22 07:39 AM
09/28/22 07:39 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Wow! Love the super bee 🐝👍👍
Hope to be in that ballpark when the time comes.
Here’s a pic of my sprayout outdoors, framed next to your car.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3081985
09/30/22 12:44 PM
09/30/22 12:44 PM
Northern BC
Canucklehead Offline
Northern BC
Is that an original A4 GTS? Paint code 99?
Re: Anyone shoot A4 silver recently? [Re: Canucklehead] #3082340
10/01/22 07:20 PM
10/01/22 07:20 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No. It was born B5
1.41 best 60 foot
6.56 at 104.17
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3083583
10/05/22 03:27 PM
10/05/22 03:27 PM
Northern BC
Northern BC
No. It was born B5
Oh, ok. There is a group of 3 of us North America wide who have original A4 GTSs. One 340, one 383 and my M-code, all paint code 99 special order and all V88 stripe delete.
Re: Anyone shoot A4 silver recently? [Re: Canucklehead] #3084708
10/10/22 06:01 AM
10/10/22 06:01 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
No. It was born B5
Don's car sure looks great.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3084784
10/10/22 11:04 AM
10/10/22 11:04 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Couple better pictures of my A4 heap.
If I knew how to post pictures better, I would..lol
https://www.forabodiesonly.com/mopar/threads/nice-picture-some-photographer-took.500454/
1.41 best 60 foot
6.56 at 104.17
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3108066
01/03/23 02:54 PM
01/03/23 02:54 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Well, I got my quantity of basecoat from the PPG store and been working with a couple different brands of clear.
Long story short I ended up getting a new clear gun, have picked out a clearcoat/will buy that next and have the directional info I need for the next steps.
Been practicing on scrap and making good progress, so far so good. Love this color.
Have more prep to do to the car before it's ready, but not really a ton (compared to everything else that has been done over the past two years).
Hopefully the reflection of power tools left on the floor give a good idea of what I'm trying to achieve.
More later....
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3110194
01/08/23 09:43 PM
01/08/23 09:43 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I have heard a lot of people bragging on Akzonobel Lesonal paint. My 68 Roadrunner is QQ1, which looks like, but is different than B5 Blue. I stole this pic from Darren (Burdar) to be able to remember the name. The guy at our paint store here that sells that brand says they can make all of the old colors, so maybe do a spray out of that before you decide. do the engine compartment in single stage urethane. Even good clear will yellow from the underhood heat after a while. For clear, I like the Universal clear from Southern Polyurethane Inc. I am by no means a professional painter, but I know enough to do my own cars. Couldn't afford it if I didn't....lol. I have learned a lot from watching "Gunman" and "Paint Society" You Tube videos and then going to the garage and seeing what works well for me. Good luck with it. I know you will do a great job.
https://www.southernpolyurethanes.com/
Re: Anyone shoot A4 silver recently? [Re: JDMopar] #3110342
01/09/23 01:56 PM
01/09/23 01:56 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you get the best results from practice and being comfortable when you are doing it. Just prep it as best you can, dont cut any corners. The most important thing i was taught is pay attention to overlap and keep it triggered off the panel. Other than that just do it.... practice as much as you can, no better teacher than experience.
....BAD A$$ STREET CAR.....
Re: Anyone shoot A4 silver recently? [Re: n20mstr] #3112915
01/17/23 04:26 PM
01/17/23 04:26 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Needed a sneak preview to give myself some motivation + to help plan 3-4 steps ahead.
Learned how to nib basecoat on this part and will do some work on the clearcoat as well
To remove dust As soon as I get the right tools and materials ordered.
Epoxy, surfacer, and clear are from spi. Earlier I also experimented with a less expensive
Acme clear that will get used for less critical stuff. (I clear coated my engine with the Acme).
I know it’s common practice to do single stage In trunks and engine bays, but I don’t have any intention
Of doing that. If the color were a solid/non metallic the answer would be different.
Single stage is made from clearcoat with color added to it, and it seems to be much more of a labor saving
Strategy than protecting against yellowing.
I’m also seeing more trunks and engine bays done in matte clear, probably an attempt to make them
Look more original, and I won’t be doing that either lol.
The color is really cool. the camera doesn’t quite do it justice as it can’t exactly pick up the green to gold flop.
Inside the shop it appears more green the further away you are.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3112938
01/17/23 05:40 PM
01/17/23 05:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's amazing, Rich!
'63 Dodge 330
11.19 @ 121 mph
Page 2 of 3 1 2 3
