Re: Utiline Bed Years
[Re: Pkeel]
#3005462
01/15/22 08:49 AM
01/15/22 08:49 AM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
I have a 1980 long bed Utiline.
Wow, from the 70's to mid 80's those are rare. Don't know much about the Swepty years.All should be the same. Does yours still have wood floor?
[Re: redraptor]
#3005566
01/15/22 01:59 PM
01/15/22 01:59 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Wheelbases changed over the years, so bed sides probably did as well.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Alaskan_TA]
#3005711
01/15/22 07:49 PM
01/15/22 07:49 PM
Posts: 43,584 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
From 1953-1985 metal floors came in around 1981 I believe.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Soopernaut]
#3005724
01/15/22 08:26 PM
01/15/22 08:26 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Wheelbases changed over the years, so bed sides probably did as well. Three box side versions. 6 foot, 8 foot -and - 9 foot but only with the 300 series for the latter.
[Re: Alaskan_TA]
#3005741
01/15/22 09:38 PM
01/15/22 09:38 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Wish he had a picture, what he shows are the Power Wagon box sides, not the Utiline.
[Re: 6PakBee]
#3005765
01/15/22 10:45 PM
01/15/22 10:45 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Which is why I said I emailed Matt a while back & he had them . Send him an email.
[Re: Alaskan_TA]
#3005849
01/16/22 09:09 AM
01/16/22 09:09 AM
Soopernaut
Des Moines IA
Wheelbases changed over the years, so bed sides probably did as well. Three box side versions. 6 foot, 8 foot -and - 9 foot but only with the 300 series for the latter. The 122" wheelbase Utiline trucks had a 7.5' bed. The late 65-71 trucks had a 128" wheelbase and the 72-85 trucks had a 131" wheelbase. Did the 72-85 trucks use the same bed sides as the 65-71 trucks? What method was used to make up the 3" difference in wheelbase? The OP mentioned something about flat fender trucks. These may have used a completely different bed side and I have no idea what the wheelbase is on these.
[Re: Soopernaut]
#3006076
01/16/22 10:37 PM
01/16/22 10:37 PM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
The side panels on the uniline beds didn't change much from 1948 through the end of production in 1985.
Dodge used 3 basic rear fenders. The flat fender military looked like bent flat sheet metal with rounded edges. Those were specific military and were used up to the end of the 68 model year. The early year beds (48-52) used rounded fenders that looked like over grown trailer fenders. From 1953 up to the end of production, Dodge used the same fenders used on the Little Red Express trucks. The difference in the wheel base between the truck eras could well be in the front axle location. The 48 trucks were 109" wheel base, but with the 'modern" fenders, the wheel base stretched to 116" wheelbase. Cabs changed in 54, 58, 62, 67, and 72.
The bed sides are a bit more confusing. Up until somewhere between the 1956 and the 1957 model years, the top angle of the bed rails were bent at a 45 degree angle, after that time, and until the end of production, the top of the bed rails were bent at a 90 degree angle.
Early production trucks offered a high side bed side or a low bed side. The low side version went away in 1955. The new 1953 model was a long 116" wheelbase with a 7 1/2' box, as was used on the 3/4 ton pickups. Before 1953 1/2 ton beds were 6 1/2' long. A long bed 1 ton version was available (no length given). There was a note in the 59 model year section that stated that the long bed 1 ton dually used the wider 48-52 rear fenders, one would assume that was how Dodge covered the differences in the wheel base.
In 1959, the standard bed was renamed the Utiline bed because the style side beds were becoming more popular, the name change was to end confusion. Information past 1959 says "the uniline bed remained basically unchanged". This information was from the book Dodge Pickups history and restoration guide 1918-1971. There was a 2 page section that skimmed over the Little Red Express trucks. Gene
