M/T ET Street R radial lifespan w/ street use?
#3003467
01/09/22 02:36 PM
01/09/22 02:36 PM
Posts: 1,165 Loudoun County, VA
Brad_Haak
Loudoun County, VA
For people who use(d) M/T ET Street R radials on the street, what sort of life in road miles would be expected? For me they'd mostly be used for driving the "old" Challenger to & from the track. Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: M/T ET Street R radial lifespan w/ street use?
[Re: 67_Satellite]
#3003501
01/09/22 04:44 PM
01/09/22 04:44 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I had some on the Charger, had about 4k street strip miles on them, still had almost full tread depth [ groove] but what killed them was my fault, would drive on the street in the summer VERY hot road temp, pull in the garage & park it, as a result not jacking up the car & putting on stands the tires got WAY out of round & unusable lessons learned the hard way , they HOOKED awesome, have M&H now, they hook good also but the Radial Street R drove much better on the street
[Re: Neil]
#3003512
01/09/22 05:26 PM
01/09/22 05:26 PM
CSK
Pattison Texas
those look like they may help,
[Re: Neil]
#3003517
01/09/22 05:44 PM
01/09/22 05:44 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...or you could pick up a set of Vehicle/Wheel Dollies...the benefit being: you get to move your ride around as need be w/o much fuss! That's what I did, but picked them up at our Canuck version of your HarborFreight...better yet, HF has these on clearance right now => Haul-Master Vehicle Dollies - 2 pc, and at $50 for a set (so $100 for the whole car) you can't beat that!!!
[Re: Brad_Haak]
#3003559
01/09/22 07:30 PM
01/09/22 07:30 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
For people who use(d) M/T ET Street R radials on the street, what sort of life in road miles would be expected? For me they'd mostly be used for driving the "old" Challenger to & from the track. Thx Come on now Brad, you know it depends on the driver Do you do burnouts to impress the local cruise night gang? I ran the original ET Street Radials on my old Duster on the street and race on them also, I found out that those tires had a lot of rubber on them under the center grooves, a lot of rubber I didn't have the speedometer hooked up so no idea of exactly how many miles and runs I put on those tires, maybe 3000 street miles and 300 hundred runs I found out the hard way on the street that those tires would break loose going around a long curve at or above 65 MPH if I went to WOT and open the six pack Be careful please The same size bias ply ET Street wouldn't do that
[Re: Brad_Haak]
#3003595
01/09/22 08:56 PM
01/09/22 08:56 PM
Posts: 31,069 Oregon
AndyF
Drove my Duster about 500 miles last summer and used up 1/3 of the tread. I was on it hard much of the time.
[Re: AndyF]
#3003639
01/09/22 10:09 PM
01/09/22 10:09 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
The R and the regular both have the same compound from what I understand, the differences are the rain grooves and the sidewall (R is softer).
My car had ~3000 miles on ET Street SS's and still had plenty of tread left, but they were something like 8 years old. Put a new set on and traction noticeably improved.
[Re: Blusmbl]
#3003645
01/09/22 10:30 PM
01/09/22 10:30 PM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
I don't know what size tire you plan on but if it is the 275/60 I would get a set of 275 Pros. They have a DOT number somehow and they work awesome. I bought a used set from a friend and they had 20 high 4 second 1/8 mile passes on them. So far I have 25 passes on them and a fair amount of street driving, they don't appear to have worn much if at all since I got them.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3003656
01/09/22 10:58 PM
01/09/22 10:58 PM
Posts: 4,699 Wichita
GY3
Wichita
I don't know what size tire you plan on but if it is the 275/60 I would get a set of 275 Pros. They have a DOT number somehow and they work awesome. I bought a used set from a friend and they had 20 high 4 second 1/8 mile passes on them. So far I have 25 passes on them and a fair amount of street driving, they don't appear to have worn much if at all since I got them. Love that tire!
[Re: TheOtherDodge]
#3003705
01/10/22 08:31 AM
01/10/22 08:31 AM
Brad_Haak
Loudoun County, VA
Not a daily driver, but will need to handle road trips of 60+ miles each way on track days.
The original MT ET Street Radial worked well for me; didn't necessarily last a long time, but performance was consistent right down into the wear bars. Not sure the current ET Street S/S is as good since the tread pattern is more street oriented, plus the new engine combination is a good bit stronger than before.
Edit: The ET Street Radial Pro is not a realistic option for me. I also know very little about M&H. Are they worth looking into?
[Re: AndyF]
#3003735
01/10/22 10:33 AM
01/10/22 10:33 AM
Brad_Haak
Loudoun County, VA
The original ET Street Radial worked best at 17.5 psi on the track and 30 psi (+/-?) on the street; I think the street pressure might need to be a bit lower in the future to keep from wearing out the tires in the middle.
I'd hate to ruin a set of tires from the heat cycling of limited street use, but don't want to go back to swapping tires at the track, either.
[Re: Brad_Haak]
#3003764
01/10/22 11:49 AM
01/10/22 11:49 AM
Bad340fish
Tulsa OK
Edit: The ET Street Radial Pro is not a realistic option for me. I also know very little about M&H. Are they worth looking into? The 60 mile one way would make me want to run a regular tire and change at the track, but you don't have the luxury of room for tires in a Challenger do you? My worst fear is always rain, but I am only 12 miles from our track so I chance it on the 275 pros.
[Re: Bad340fish]
#3003767
01/10/22 11:57 AM
01/10/22 11:57 AM
CSK
Pattison Texas
Edit: The ET Street Radial Pro is not a realistic option for me. I also know very little about M&H. Are they worth looking into? The 60 mile one way would make me want to run a regular tire and change at the track, but you don't have the luxury of room for tires in a Challenger do you? My worst fear is always rain, but I am only 12 miles from our track so I chance it on the 275 pros. I have been caught in the rain 140 miles in the Charger with MT street R radials, it was no problem at all , just drove a little slower , the M&H in the rain a very good
[Re: Bad340fish]
#3003776
01/10/22 12:14 PM
01/10/22 12:14 PM
Brad_Haak
Loudoun County, VA
Swapping tires at the track means I can't take a passenger with me. One wheel gets stuffed behind the rollbar and the other gets the passenger seat... it's a bit of a PITA, but I did it regularly before switching to the MT ET Street Radial. FWIW, those actually weren't horrible in the rain when they still had some tread depth -- much better than the BFG Drag Radials I tried before them -- but you did need to keep your brain engaged on wet roads.
I've got a new set of the original ET Street Radials that I bought when they were discontinued, so I do have something to use when the car's rolling under it's own power. They did well as dual-duty tires and still pulled 60s in the mid-to-hgh 1.4s., but now the car is gonna hit the tires even harder. It's their replacements that I'm thinking about now...
[Re: AndyF]
#3004142
01/11/22 02:05 PM
01/11/22 02:05 PM
GY3
Wichita
Tire pressure makes a big difference. I'm assuming you pump them up to 35 psi (or more) for the highway miles? I kept mine fully inflated when I drove around town. I used to worry about pressures and air my ET street Pros up for the street and down for the track. Then I realized they drive as well at 18psi as they did at 30. I just leave them at 18 and have never had any issues. I swap them out for new about every 2 years anyway. Since I quit spinning them on the street, they have worn much better.
