M/T ET Street R radial lifespan w/ street use? #3003467
01/09/22 02:36 PM
01/09/22 02:36 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
For people who use(d) M/T ET Street R radials on the street, what sort of life in road miles would be expected? For me they'd mostly be used for driving the "old" Challenger to & from the track. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003476
01/09/22 03:00 PM
01/09/22 03:00 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I've had the same 315-60-15 M/T E.T. streets on my Satellite since late in 2010. They're getting a little thin, but I think there's one more year left in them. Mostly local car shows and plenty of back road acceleration trials. Have lasted longer than I expected for a "soft" tire.
Re: M/T ET Street R radial lifespan w/ street use? [Re: 67_Satellite] #3003501
01/09/22 04:44 PM
01/09/22 04:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I had some on the Charger, had about 4k street strip miles on them, still had almost full tread depth [ groove] but what killed them was my fault, would drive on the street in the summer VERY hot road temp, pull in the garage & park it, as a result not jacking up the car & putting on stands the tires got WAY out of round & unusable frown lessons learned the hard way , they HOOKED awesome, have M&H now, they hook good also but the Radial Street R drove much better on the street
Re: M/T ET Street R radial lifespan w/ street use? [Re: CSK] #3003508
01/09/22 05:00 PM
01/09/22 05:00 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Wonder if these work and would help your flat spot issues? They are pricey, but you could make something similar out of wood on the cheap maybe?
https://www.raceramps.com/car-stora...LxMel9QIVFiCtBh23iQJ4EAAYASAAEgKxavD_BwE
Re: M/T ET Street R radial lifespan w/ street use? [Re: Neil] #3003512
01/09/22 05:26 PM
01/09/22 05:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
those look like they may help,
Re: M/T ET Street R radial lifespan w/ street use? [Re: Neil] #3003517
01/09/22 05:44 PM
01/09/22 05:44 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
...or you could pick up a set of Vehicle/Wheel Dollies...the benefit being: you get to move your ride around as need be w/o much fuss!
That's what I did, but picked them up at our Canuck version of your HarborFreight...better yet, HF has these on clearance right now => Haul-Master Vehicle Dollies - 2 pc, and at $50 for a set (so $100 for the whole car) you can't beat that!!!
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003559
01/09/22 07:30 PM
01/09/22 07:30 PM
Come on now Brad, you know it depends on the driver tsk up
Do you do burnouts to impress the local cruise night gang? whistling
I ran the original ET Street Radials on my old Duster on the street and race on them also, I found out that those tires had a lot of rubber on them under the center grooves, a lot of rubber up
I didn't have the speedometer hooked up so no idea of exactly how many miles and runs I put on those tires, maybe 3000 street miles and 300 hundred runs shruggy
I found out the hard way on the street that those tires would break loose going around a long curve at or above 65 MPH if I went to WOT and open the six pack shock realcrazy Be careful please twocents
The same size bias ply ET Street wouldn't do that up work
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003595
01/09/22 08:56 PM
01/09/22 08:56 PM
AndyF Offline
AndyF  Offline
Drove my Duster about 500 miles last summer and used up 1/3 of the tread. I was on it hard much of the time.
Re: M/T ET Street R radial lifespan w/ street use? [Re: AndyF] #3003639
01/09/22 10:09 PM
01/09/22 10:09 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The R and the regular both have the same compound from what I understand, the differences are the rain grooves and the sidewall (R is softer).
My car had ~3000 miles on ET Street SS's and still had plenty of tread left, but they were something like 8 years old. Put a new set on and traction noticeably improved.
Re: M/T ET Street R radial lifespan w/ street use? [Re: Blusmbl] #3003645
01/09/22 10:30 PM
01/09/22 10:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know what size tire you plan on but if it is the 275/60 I would get a set of 275 Pros. They have a DOT number somehow and they work awesome. I bought a used set from a friend and they had 20 high 4 second 1/8 mile passes on them. So far I have 25 passes on them and a fair amount of street driving, they don't appear to have worn much if at all since I got them.
68 Barracuda Formula S 340
Re: M/T ET Street R radial lifespan w/ street use? [Re: Bad340fish] #3003656
01/09/22 10:58 PM
01/09/22 10:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love that tire!
'63 Dodge 330
11.19 @ 121 mph
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003670
01/09/22 11:33 PM
01/09/22 11:33 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
If you are looking for performance at the track, driving them on the street will deteriorate them fairly quickly. If they are just for street use they can last for a few years if they are not a "daily driver".
Re: M/T ET Street R radial lifespan w/ street use? [Re: TheOtherDodge] #3003705
01/10/22 08:31 AM
01/10/22 08:31 AM
Loudoun County, VA
Loudoun County, VA
Not a daily driver, but will need to handle road trips of 60+ miles each way on track days.
The original MT ET Street Radial worked well for me; didn't necessarily last a long time, but performance was consistent right down into the wear bars. Not sure the current ET Street S/S is as good since the tread pattern is more street oriented, plus the new engine combination is a good bit stronger than before.
Edit: The ET Street Radial Pro is not a realistic option for me. I also know very little about M&H. Are they worth looking into?
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003718
01/10/22 09:27 AM
01/10/22 09:27 AM
AndyF Offline
AndyF  Offline
Tire pressure makes a big difference. I'm assuming you pump them up to 35 psi (or more) for the highway miles? I kept mine fully inflated when I drove around town.
Re: M/T ET Street R radial lifespan w/ street use? [Re: AndyF] #3003735
01/10/22 10:33 AM
01/10/22 10:33 AM
Loudoun County, VA
Loudoun County, VA
The original ET Street Radial worked best at 17.5 psi on the track and 30 psi (+/-?) on the street; I think the street pressure might need to be a bit lower in the future to keep from wearing out the tires in the middle.
I'd hate to ruin a set of tires from the heat cycling of limited street use, but don't want to go back to swapping tires at the track, either.
Re: M/T ET Street R radial lifespan w/ street use? [Re: Brad_Haak] #3003764
01/10/22 11:49 AM
01/10/22 11:49 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The 60 mile one way would make me want to run a regular tire and change at the track, but you don't have the luxury of room for tires in a Challenger do you? My worst fear is always rain, but I am only 12 miles from our track so I chance it on the 275 pros.
Re: M/T ET Street R radial lifespan w/ street use? [Re: Bad340fish] #3003767
01/10/22 11:57 AM
01/10/22 11:57 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have been caught in the rain 140 miles in the Charger with MT street R radials, it was no problem at all , just drove a little slower , the M&H in the rain a very good
Re: M/T ET Street R radial lifespan w/ street use? [Re: Bad340fish] #3003776
01/10/22 12:14 PM
01/10/22 12:14 PM
Loudoun County, VA
Loudoun County, VA
Swapping tires at the track means I can't take a passenger with me. One wheel gets stuffed behind the rollbar and the other gets the passenger seat... it's a bit of a PITA, but I did it regularly before switching to the MT ET Street Radial. FWIW, those actually weren't horrible in the rain when they still had some tread depth -- much better than the BFG Drag Radials I tried before them -- but you did need to keep your brain engaged on wet roads.
I've got a new set of the original ET Street Radials that I bought when they were discontinued, so I do have something to use when the car's rolling under it's own power. They did well as dual-duty tires and still pulled 60s in the mid-to-hgh 1.4s., but now the car is gonna hit the tires even harder. It's their replacements that I'm thinking about now...
Re: M/T ET Street R radial lifespan w/ street use? [Re: AndyF] #3004142
01/11/22 02:05 PM
01/11/22 02:05 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I used to worry about pressures and air my ET street Pros up for the street and down for the track. Then I realized they drive as well at 18psi as they did at 30. I just leave them at 18 and have never had any issues. I swap them out for new about every 2 years anyway. Since I quit spinning them on the street, they have worn much better.
'63 Dodge 330
11.19 @ 121 mph
