Re: 1968 Charger pass [Re: CSK] #3008475
01/24/22 12:42 PM
01/24/22 12:42 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
This is what I have
Re: 1968 Charger pass [Re: CSK] #3008480
01/24/22 12:53 PM
01/24/22 12:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That’s what I thought you had.
1.6 rockers?
I guess you could pull off a couple intake springs and have them tested.
Personally, I’d like to see more open load....... especially since with the lifters you have, and the way you have them set up, there is no worry about bleed down.
Re: 1968 Charger pass [Re: fast68plymouth] #3008483
01/24/22 01:00 PM
01/24/22 01:00 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
1.6 rockers?
I really need to freshen up the engine, BUT if I do that I think its time for an aftermarket block, would like an alum low deck, its all about the lack of money & not sure I could physically do all that by myself anymore, if I take it apart will it EVER run again LOL smile
Re: 1968 Charger pass [Re: CSK] #3008484
01/24/22 01:03 PM
01/24/22 01:03 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
on the springs I agree 100%, I was looking at the conical springs with more rate & seat pressure , yes 1.6 T&D
Re: 1968 Charger pass [Re: CSK] #3008516
01/24/22 02:03 PM
01/24/22 02:03 PM
moparx Offline
moparx  Offline
SUPER picture ! up bow
i wish mine could do that, but i know it will never happen.
beer
Re: 1968 Charger pass [Re: moparx] #3008770
01/25/22 11:12 AM
01/25/22 11:12 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice car, check fuel cell Vent
Re: 1968 Charger pass [Re: FastmOp] #3008831
01/25/22 01:14 PM
01/25/22 01:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
maybe its the 4 turns of lifter preload you run..... whistling I my experience if you want a hydraulic to rpm, you run as little preload your ears can stand.
Re: 1968 Charger pass [Re: B1MAXX] #3015301
02/14/22 11:07 AM
02/14/22 11:07 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
The lifters are made to be run like I have them, if you have .020 or .070 preload & the valve springs are to weak the lifter will still pump up & hold the valves open, the problems I have start at below 5500 rpm in HIGH gear and fuel pressure drops off & on, it is NOT because of my lifter preload, running them loose so it will RPM is just a bandaid for the wrong valve springs.
That said I pulled the fuel pump & found nothing wrong with the wiring or pump, went ahead & got a larger volume pump & drilled out the sending unit pump line connection as it was much smaller id than -6 should be at the recommendation of Member INTDM8 as he was correct on that info for the Tanks Inc set up,I also was using a stock 3/8 steel line that has all the tight bends in it, I already had some new -6 efi hose so I replaced the factory steel line with it so no more bent up steel tubing,did a volume test @ 50 psi & it flows about 120 GPH now @ 12volts ,will make it back to a track rental soon.
Re: 1968 Charger pass [Re: CSK] #3015346
02/14/22 01:31 PM
02/14/22 01:31 PM
moparx Offline
moparx  Offline
will be waiting to see the results. up
beer
Re: 1968 Charger pass [Re: moparx] #3015351
02/14/22 01:38 PM
02/14/22 01:38 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
/\ x2
Just my opinion. up A liquid hydrauliced doesn't know/care how stiff the spring is. But it's all good. We've got different opinions.
