Re: New hot rod for my son!
[Re: 65 Hemi]
#3004069
01/11/22 10:53 AM
01/11/22 10:53 AM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Beautiful car. congratulations.
[Re: CKessel]
#3004246
01/11/22 05:47 PM
01/11/22 05:47 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Nice ride!! That thing is way way cooler than my first car was. That’s the kind of car you can hang on to for a long time.
[Re: Cab_Burge]
#3004766
01/12/22 11:13 PM
01/12/22 11:13 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Need to get some wiring done to see if the ac works but decided to get the car rewired. When I was younger I chased wiring issues that Got me discouraged to the point I sold the car.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: moparx]
#3004977
01/13/22 04:58 PM
01/13/22 04:58 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
chasing wiring issues, especially caused by others - man and beast alike, has been at least one reason i have no hair on the top of my head. I've fixed several stock Mopar wiring harness in the engine compartment and under the dash harness that had melted connections, worn insulation and so on that lasted a long time Slice the tape covering and remove, cut, out the bad part, twist in a new piece of the same size wire and color, solder and heat shrink cover it and retape it: up:
[Re: Mopar Dylan]
#3004989
01/13/22 05:57 PM
01/13/22 05:57 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
When I was 13 I had a bike Congrats, hope you enjoy it and hold on to it for many years to come.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3006467
01/18/22 11:37 AM
01/18/22 11:37 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Very nice! Love that body style.
