Re: Brake rotors stacking up
[Re: fourgearsavoy]
#3002678
01/06/22 06:26 PM
01/06/22 06:26 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
I'm so Damn old, I was trained to turn both rotors and drums in college automotive technology courses.
This reminds me of the pile of rotors my wife's previous Sebring ate over the years. Eventually I gave up any reasonable service strategy and experimented with different brands until, shockingly I finally found one that held up.
So wasteful to just throw the stuff out when there's a slight issue, but no other choice.
Rich H.
Esse Quam Videri
[Re: Powerflow]
#3002700
01/06/22 08:07 PM
01/06/22 08:07 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
the dealership i work at USED to do this 10+ years ago. there is a scrap metal dumpster behind the shop now. it usually gets filled up and hauled away every month. the $$$ go to the owners now. most dealerships and larger repair shops do it this way now.
perception is 90% of reality
[Re: Rhinodart]
#3002728
01/06/22 09:25 PM
01/06/22 09:25 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
The last two times I had my rotors replaced at my Dodge dealer they WOULD NOT turn them, only replace with new. It seems that ALL the manufacturers recommend the same thing, so what has changed? People complaining too much about warped rotors 6 months after they are turned? Chinese steel sucks so much that they cannot be turned reliably? Cheap wheel bearings failing so they MUST replace them also? The last time I bought rotors for the Ramcharger I had them mic the new ones since they already had the mic out to check the old ones, they were just a few thousands over the minimum to be turned. IMHO, just the wear from one set of brake pads lifespan will take the rotor under the minimum specification to be turned.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3002732
01/06/22 09:49 PM
01/06/22 09:49 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
[Re: Rhinodart]
#3002747
01/06/22 10:13 PM
01/06/22 10:13 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
The last two times I had my rotors replaced at my Dodge dealer they WOULD NOT turn them, only replace with new. It seems that ALL the manufacturers recommend the same thing, so what has changed? People complaining too much about warped rotors 6 months after they are turned? Chinese steel sucks so much that they cannot be turned reliably? Cheap wheel bearings failing so they MUST replace them also? It’s less expensive to put on new Chinese rotors.
China is the enemy.
[Re: 1972CudaV21]
#3002750
01/06/22 10:30 PM
01/06/22 10:30 PM
Posts: 9,477 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Its all a big hustle for the people who cant turn a wrench, I average 130-150k miles off oem rotors with simple pad changes and light da scuffing on the rotors then and simply drive like ive got some sense.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3002755
01/06/22 10:44 PM
01/06/22 10:44 PM
Posts: 6,264 nowhere
Sniper
nowhere
I am at 111k miles on the OEM rotors and pads for the work truck. Got over 90k on the OEM tires.
[Re: Mr PotatoHead]
#3002760
01/06/22 11:09 PM
01/06/22 11:09 PM
Posts: 10,570 Freeport IL USA
poorboy
Freeport IL USA
I have a pair of brake drums off of a 44,000 mile truck. The shoes looked great, but the chassis was going under something else, so the owner wanted new shoes and wheel cylinders. One rear drum had a little warp and created a noise at slow stopping speeds. Took the drum in to get turned, only one of 6 parts stores in town turns drums now. and then only one guy. The drums only have .060 that they can be turned (even new off the shelf), The 1st cut only cut about 1/4 of the drum. The 2nd cut cleaned up about 3/4 of the drum, The 3rd cut cleaned up the entire braking surface, but that cut was not smooth. The guy took one more small cut to try to clean up the surface, after he replaced the cutting tool. It was just slightly better, but I took it home, it was just under specs. The guy did not charge me to turn that drum ($20 normal cost). My cost on a replacement drum was $60 (the local store was cheaper then what was available on line right at the time), but would have had to be ordered. Before Dec I priced out those drums and they were only $42 each then, but the week later the price jumped to $60. The front rotors only have an allowable .060 cut as well, try getting a warp out of a rotor in a .060 cut once, at .060, you would be lucky to get a smooth cut on both sides from a rotor that wasn't warped. By the way, its cheaper these days to buy a rotor kit, (both rotors, and pads), then it is to buy just rotors. You can get the master front brake kit that included calipers and hardware as well as the rotors and pads for less the the calipers and the rotor kits separately.
If the brake noise come back, the customer gets new drums, at whatever they cost then. I spent a couple hours jacking with that drum for a questionable return. Would have been more cost effective to order the new drums before the project started.
[Re: 1972CudaV21]
#3002778
01/07/22 01:16 AM
01/07/22 01:16 AM
Posts: 4,946 WI
Dcuda69
WI
The last two times I had my rotors replaced at my Dodge dealer they WOULD NOT turn them, only replace with new. It seems that ALL the manufacturers recommend the same thing, so what has changed? People complaining too much about warped rotors 6 months after they are turned? Chinese steel sucks so much that they cannot be turned reliably? Cheap wheel bearings failing so they MUST replace them also? It’s less expensive to put on new Chinese rotors. Assuming the originals came from????
[Re: A12]
#3003089
01/08/22 07:49 AM
01/08/22 07:49 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Here is what usually happens in our shop. The car is in the lube bay and they notice the brakes are worn under 4 mm. The writer sells the job with rotors because they don't trust the lube guys ability to judge the condition of the rotors. I don't machine a lot of rotors anymore maybe 1 or 2 sets a week. I look at it this way they only pay me 1.8 to machine rotors,replace pads,and service the arbors and pins. The pay me 1.5 to replace the rotors,pads and service the arbors and pins So is it worth it for me to set up the lathe and machine some rusted rotors for 0.3 ? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3003099
01/08/22 10:12 AM
01/08/22 10:12 AM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Here is what usually happens in our shop. The car is in the lube bay and they notice the brakes are worn under 4 mm. The writer sells the job with rotors because they don't trust the lube guys ability to judge the condition of the rotors. I don't machine a lot of rotors anymore maybe 1 or 2 sets a week. I look at it this way they only pay me 1.8 to machine rotors,replace pads,and service the arbors and pins. The pay me 1.5 to replace the rotors,pads and service the arbors and pins So is it worth it for me to set up the lathe and machine some rusted rotors for 0.3 ? Gus The customer has no say in the decision?
