Re: How far should I tear this down - 73 W100 400 block [Re: poorboy] #3008781
01/25/22 11:22 AM
01/25/22 11:22 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
you have some work ahead of you by the looks of it
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: How far should I tear this down - 73 W100 400 block [Re: northcoastmopar] #3026293
03/22/22 09:26 AM
03/22/22 09:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted by northcoastmopar
One of the heads has this issue with a valve cover bolt hole. The hole had some epoxy in it and was threaded to kinda hold the valve cover bolt. The hole is wallowed out and goes through to the water jacket.
So, can this be repaired or is it even worth repairing and I look for different heads?
The valves are somewhat mushroomed I had to file them a bit to get them out. The valve guides have pretty sizable side load wear.
Those iron heads are a dime a dozen , I'd start with another set, what part number heads do you have ?
Re: How far should I tear this down - 73 W100 400 block [Re: JohnRR] #3029017
03/30/22 03:25 PM
03/30/22 03:25 PM
Cleveland, Ohio
northcoastmopar Offline OP
Cleveland, Ohio
Hey John how are you? Haven't conversed in a long time.
Welp, the horse has left the barn on this. I took everything into the machine shop, an old school mopar-friendly place, and the block needs bored and instead of putting money into iron heads decided to go with some Eddy E-Street heads and be done with it. Crank needs turned, the bearings were well on their way to being toast. So tearing it all down was a good idea. Was an incredibly filthy engine.
Re: How far should I tear this down - 73 W100 400 block [Re: northcoastmopar] #3031173
04/06/22 10:37 AM
04/06/22 10:37 AM
JohnRR Offline
JohnRR  Offline
I'm doing ok , finally getting back to start working on all my dormant projects and to thin down my junk collection after having to move it all out of my basement after the town sewer backed up into it ...ugh .
That was probably the best idea to go with the e streets, rebuilding old iron heads isn't cheap , money well spent . Pay attention to the pistons you buy , off the shelf for stock stroke 400 choice isn't that great, you might have to get something from someone like Diamond? a possibility also is to look at replacement 440 pistons. There is a smogger piston that is is in the 1.9 CH range that will get you close to zero deck , you might just need to add some small valve reliefs depending on the size cam you chose.
Re: How far should I tear this down - 73 W100 400 block [Re: northcoastmopar] #3048402
06/06/22 07:07 PM
06/06/22 07:07 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Actually an easy fix. Hardest part is locating where the hole should be. Have it drilled for a 7/16"-14 thread then tap thds in, get a bolt or some all thread drill the end for 1/4"-20 thread. Cut the threaded end off to length needed to be flush or below surface. screw in a 1/4" bolt with a jam nut on it using red lock-tite on the 7/16 threads. Walla done. Just make sure the insert is flush, maybe file it flush.
Re: How far should I tear this down - 73 W100 400 block [Re: merpar] #3050258
06/13/22 04:38 PM
06/13/22 04:38 PM
Cleveland, Ohio
Cleveland, Ohio
The ship has sailed, I bought E-street aluminum heads. My heads were toast. Just got everything back from the machine shop. .030 over and .010/.010 on the crank. Time to start putting it back together.
