Vacuum pumps, what pump, pressure?
#3000809
01/01/22 07:58 PM
01/01/22 07:58 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have an older Moroso pump, four vain. I have gotten 10.5 inch vacuum in the past without any bleeder to control vacuum level. With the new build, I had problems getting 3 or 4 inch vacuum, but am not sure why. My moroso pump has maybe 300 runs on it, is 18 years old. The fittings are 90 degrees apart ,not the newer 120 degrees. My new short block will have DLC coated piston pins, so that area is covered. I am Looking for info on how much vacuum to run, and anything I should know to stay out of trouble. Thanks in advance, Greg
Re: Vacuum pumps, what pump, pressure?
[Re: dvw]
#3001111
01/02/22 01:40 PM
01/02/22 01:40 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Might tear that old pump apart and rebuild it. We use a 4 vane on the vette and are at 20"+ I use them on my junk too and we are 15-17 depending on the engine its on. I think the dragster could likely use something better maybe. But we have some ither issues to fix in regard to vacuum there. I also have a Star pump and it's a very nice piece for sure but the results are similar. We don't regulate vacuum with any of them and never seen any issues with the loads we pull.
[Re: Al_Alguire]
#3001361
01/03/22 02:46 AM
01/03/22 02:46 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
On my B1 540 wet sump and Moroso Enhanced 4 vane setup I was pulling 15-17” and keeping a close eye on it. With my 412” Canted Valve head SBF, 4 stage dry sump and Moroso 4 vane I was pulling 21-23”. Not every application needs a vac pump, but all applications will benefit at making more HP, especially when setup for vac pump use.
Greg, like Al suggested, freshen up your pump, it’s probably time.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: DavidDean]
#3001662
01/03/22 05:00 PM
01/03/22 05:00 PM
Al_Alguire
Las Vegas
There are better seals out there for sure. But I have not seen a lot of difference with them. I dont put mine in backwards never have. Making sure its sealed well is the key. If you are constantly putting OIL in the puke tank you have a leak!
[Re: HardcoreB]
#3001911
01/04/22 11:17 AM
01/04/22 11:17 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I have a 4 vane Moroso I bought used 8 or 9 years ago and it's been great. It pulls around 10". Have the same pump on the Camaro and it's been on that car for nearly 20 years, but it's been rebuilt a couple of times. Main seals put in the conventional way, low tension rings, etc. I bought the Moroso after my 2nd Aerospace Components pump $h!t the bed. It would pull 7" at best w/ the regulator closed. Aerospace sucks.
[Re: an8sec70cuda]
#3002146
01/04/22 10:18 PM
01/04/22 10:18 PM
gregsdart
Thanks everybody. I ordered a smoke/leak detector listed above. One step at a time, check the current pump for ware, seal the new motor well, go from there. I found a 4.5 inch pulley available from GPZ that fits, speed increase of 11 percent. Try that . If I don't t reach decent vacuum of +14 inch, the expensive fix is a 4 vain enhanced, which is supposed to reach good vacuum when staged.
