Re: Power steering Box
[Re: Gunsling3r]
#3000798
01/01/22 07:32 PM
01/01/22 07:32 PM
Posts: 4,223 ohio
ruderunner
ohio
You talking about the sector shaft cap? Just remove the bolts on the cap, DON'T, touch the adjustment bolt.
Once it's off, remove the adjustment bolt, but count the turns needed to get it out. Replace the o rings and reassemble, turning the adjustment bolt back the same number of turns.
Angry white guy
[Re: Gunsling3r]
#3001028
01/02/22 09:00 AM
01/02/22 09:00 AM
Posts: 4,223 ohio
ruderunner
ohio
Ok, not the box I was thinking but, unthread the cap and don't touch the adjuster screw. Actually, you've already thrown off the adjustment so back in off again for now, you'll have to readjust after resealing.
Remove cap and adjustment as a unit, replace seals. Install adjustment so it's bottomed out in the cap. Install cap on box. Reset adjustment screw per manual.
Angry white guy
