Re: Pro Parts Headers
[Re: 300by500]
#3000301
12/31/21 02:07 PM
12/31/21 02:07 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I've got a set of Pro Parts headers that I had ceramic coated years ago but have never used. I've got a 498 RB going into a '69 Barracuda fastback, probably around 575 HP and eventually adding a 250 shot of NOS.
Are these worth cutting the needed fenderwell holes for better spark plug/starter access, better flow for performance, etc. or should I just get some TTI headers? It's up to you ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I've used both and I wouldn't hesitate to cut the fenderwells unless the car was a M code 440 car ![sawzall sawzall](/ubbthreads/images/graemlins/custom/sawzall.gif)
[Re: Dodgeguy101]
#3000441
12/31/21 08:04 PM
12/31/21 08:04 PM
Posts: 1,030 ohio
67mprfan
ohio
I also had a 71 demon with the same combination 440 ez-1 heads with those headers and liked them. But my fenderwells were cut out too
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 300by500]
#3000563
01/01/22 10:01 AM
01/01/22 10:01 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Are these worth cutting the needed fenderwell holes for better spark plug/starter access, better flow for performance, etc. or should I just get some TTI headers? Here’s some advice, especially if you’re going to be using nitrous. You’ll want the easiest access to removing, inspecting, and reinstalling your spark plugs. Pro Parts headers in an A-Body will be a PITA for allowing the aforementioned. I went through it myself with a 440 on juice 25 years ago with those headers in an A-Body. Put them up for sale, and combine that money with money you’d spend for TTI’s, and find yourself a quality shop that’ll build you custom headers that will fit your car perfectly without cutting it up, and also put the tubing in areas off the heads to allow you easy access to your plugs, etc. Trust me, you’ll thank yourself a thousand times for doing this.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: AndyF]
#3001648
01/03/22 04:31 PM
01/03/22 04:31 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
If you're going to be a serious nitrous racer then get rid of the inner fenders and use a strut front suspension mounted on the cage. That way you'll be able to work on the engine and the car will launch and go down the track. Not a "serious" racer at all. Springs moved in, going with minitubs. Just putting subframe connectors and an 8-point roll bar in it. Car is gonna have A/C, Gear Vendors overdrive and Sniper FI. Looking at 575-600 at the crank on the motor with a 200-ish dry shot. Basically a street toy.
[Re: 300by500]
#3001724
01/03/22 08:07 PM
01/03/22 08:07 PM
Posts: 31,082 Oregon
AndyF
If you're going to be a serious nitrous racer then get rid of the inner fenders and use a strut front suspension mounted on the cage. That way you'll be able to work on the engine and the car will launch and go down the track. Not a "serious" racer at all. Springs moved in, going with minitubs. Just putting subframe connectors and an 8-point roll bar in it. Car is gonna have A/C, Gear Vendors overdrive and Sniper FI. Looking at 575-600 at the crank on the motor with a 200-ish dry shot. Basically a street toy. If it is a street toy then use TTI headers. The smaller the better, maybe the 1 3/4 size.
[Re: AndyF]
#3001768
01/03/22 09:53 PM
01/03/22 09:53 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I ran them for a couple of years on my 496" low deck in the Barracuda. They were ok, but I picked up a lot when I built my own headers. Of course that engine was set up for 7600 rpm shift points and was never a street car. If you are putting it on the street sell the pro parts headers and put in TTI's or better yet, for ease of install the try y types. I have a friend running these and loves them. Try Y headers-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#3002453
01/05/22 11:02 PM
01/05/22 11:02 PM
Posts: 736 New York
R/T1968R/T
New York
Ran them in two big block Darts street cars. 440 @ 550HP and a 505 @ 634HP. Best A body big block headers I ever used. easy to install also. The hole on the passenger side is small. On the drivers side cut it out carefully and save it so it can be welded back.
