Re: Edelbrock Performer RPM Heads. [Re: pittsburghracer] #2999572
12/29/21 03:46 PM
12/29/21 03:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Progress marches on.
Ede heads are still as effective as they ever were.
What has changed is they’re several hundred dollars more that they once were....... and there is now a competing head(TF) that offers more performance for less cost than buying and modifying the Ede heads to reach equivalent flow numbers.
If I were looking to build a hot street/mild bracket engine, and TF240’s were unobtainable, and there were RPM’s on a shelf somewhere, and I felt I’d be ready for heads before the TF’s were available........ I’d just get the RPM’s and modify if/as necessary.
Re: Edelbrock Performer RPM Heads. [Re: fast68plymouth] #2999808
12/30/21 09:29 AM
12/30/21 09:29 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
How much of a difference is there between the RPM head verses the E Street? Performance wise. The E Street is about 250 -300 lower in price.
America First!
Re: Edelbrock Performer RPM Heads. [Re: carnut68] #2999847
12/30/21 11:27 AM
12/30/21 11:27 AM
So. Burlington, Vt.
So. Burlington, Vt.
Basically zero difference.
The only real difference between them now is some tiny about of blending and the valves.
The 84cc E Streets also have the spark plug holes straight instead of angled.
Re: Edelbrock Performer RPM Heads. [Re: lewtot184] #3002196
01/05/22 02:18 AM
01/05/22 02:18 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I got one of the early sets way back when and they replaced my lightly ported 906 heads with big valves that flowed about 255-260cfm. There was an improvement for sure, but because of a camshaft change at the same time, I can't contribute it all to the heads. I had absolutely no issues with the heads at all, they worked well.
With a decent sized street/strip camshaft, flat top pistons, the E heads, 1 7/8" headers, single plane intake and a 750 carb it made 360rwhp (about 450hp) on the dyno-jet chassis dyno and ran high 11s at 115mph in a 3600lb B body with 3.91 gears.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Edelbrock Performer RPM Heads. [Re: BigDaddy440] #3002489
01/06/22 06:44 AM
01/06/22 06:44 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
IMO, the E-Street heads are a good bang for the buck. If your not expecting to set the world on fire they are a nice upgrade from the factory cast iron head.
I built a real mild motor with them, +.030 440, 9.2-1, MP .528 mechanical cam, 1-3/4" pickup headers. With an M-1 single plane and a 750 Edelbrock carb it made 455hp&508ftlbs, with a Weiand TunnelRam and 2- 750 Edelbrocks it made 469hp&542ftlbs.
Re: Edelbrock Performer RPM Heads. [Re: fast68plymouth] #3002892
01/07/22 03:03 PM
01/07/22 03:03 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Is the difference in valve seat materials a non-factor for the typical usage of both series?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Edelbrock Performer RPM Heads. [Re: Brad_Haak] #3002900
01/07/22 03:39 PM
01/07/22 03:39 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
has mentioned over the last few years that valve seat material is now the same...
Re: Edelbrock Performer RPM Heads. [Re: krautrock] #3003299
01/08/22 10:16 PM
01/08/22 10:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I hear this is Edelbrock's new foundry.
