Re: 1805 -6s carbs on a hemi ?
[Re: second 70]
#2998620
12/26/21 02:26 PM
12/26/21 02:26 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
I just put a pair of 1912s on mine. Haven't messed with them yet other than put light springs in them and they seem pretty good. I have to wait for better weather to dial them in. I had 1407s on it and they worked but it took alot of tinkering to get them right. 10.5:1 pump gas 528 hemi. Eddy heads and intake.
[Re: calrobb2000]
#2998635
12/26/21 03:43 PM
12/26/21 03:43 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
Are those smog carbs or performance carbs.? I won't use any smog carbs now on any muscle cars or street and strip motors IHTHS
[Re: Cab_Burge]
#2998640
12/26/21 04:03 PM
12/26/21 04:03 PM
Uncle Barry
Are those smog carbs or performance carbs.? I won't use any smog carbs now on any muscle cars or street and strip motors IHTHS I believe those he posted are just regular 650 avs carbs, Cab.
[Re: calrobb2000]
#2999900
12/30/21 01:17 PM
12/30/21 01:17 PM
Posts: 1,711 central il.
second 70
central il.
stock intake street hemi, progressive linkage, 6903 fuel pump . Thanks for the info but my settings won't help since I run a Stage V open and 1 - 1 linkage. I can tell you even thou mine is only a 426 it did like the 1407's better at WOT. But again this was on an open plenum manifold.
