Re: Mufflers
[Re: DusterKid]
#2997543
12/22/21 11:08 AM
12/22/21 11:08 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Who's muffler are you guys using that helps tone down your race car but doesn't hurt the overall performance much? I currently just have 6" Schoenfeld Race Muffler on my car, but looking to quiet the car down some. Would like something that milds the sound down, but doesn't sound like a mustang going down the track either. Kooks make really nice polished stainless mufflers that knock down noise, nice sound, no effect on my car at the track. Pretty, and not expensive. https://www.summitracing.com/parts/...G6tf39AIVahPUAR2RrQ-mEAQYAyABEgJKufD_BwE
Re: Mufflers
[Re: B3422W5]
#2997765
12/23/21 02:44 AM
12/23/21 02:44 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
These cut my noise down a little (with emphasis on “little”). Flowmaster FlowF/X 3” bullets.
Re: Mufflers
[Re: dvw]
#2997834
12/23/21 11:37 AM
12/23/21 11:37 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Dynomax bullet on my Challenger. They help quiet it down some. I mean a little, very little.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Mufflers
[Re: BigFish69]
#2998006
12/23/21 08:41 PM
12/23/21 08:41 PM
B3422W5
Portage,michigan
Do you know the weight on those kooks mufflers, was there any performance loss ? No known performance loss. Not sure what they weigh. I have the 3 inch ones like i linked to. Guessing 4 or 5 pounds each. They are polished stainless. Edit….4.33 pounds
Re: Mufflers
[Re: DusterKid]
#2998223
12/24/21 02:51 PM
12/24/21 02:51 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
I used a set of the older crimp style Magnaflow 14 inch long by 7 inch wide ovals with 3.0 inch side inlet with a perforated pipe exiting in the center. The muffs were mounted at the rear bumper and fed by 3.0 inch pipes off the 3.5 inch Hooker fenderwell A body headers, that car slowed down .03 ET in the 1/8 mile with them on and .2 MPH, 7.01 ET hooked up at 95.3 MPH, 6.98 ET at 95.5 MPH with the complete system removed IHTHs That car was a real hoot, not real loud at part throttle cruising but a lot louder at WOT Best run with the exhaust system on in the1 /4 mile on Oregon pump swill was 9,994 ET at 134.6 MPH weighing 3450 Lbs. with me in it
Re: Mufflers
[Re: Cab_Burge]
#2998227
12/24/21 03:30 PM
12/24/21 03:30 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
At the end of your collecter, what ever length works best, go up an inch in diameter with an adapter , and add a straight through muffler of the larger size. Add an extension on to the muffler. As long as the system stays at least an inch bigger than the collector you have a zero loss system, except for the extra weight.
Re: Mufflers
[Re: moparx]
#2998611
12/26/21 01:41 PM
12/26/21 01:41 PM
B3422W5
Portage,michigan
[s][/s] if using a complete exhaust system, [x pipe with tail pipes] would race bullets at the end of the tail pipes [where the gasses are the coolest] be the least restrictive place in the system to place them ? Performance matters less the further back you go on the exhaust system
Re: Mufflers
[Re: B3422W5]
#2998683
12/26/21 07:36 PM
12/26/21 07:36 PM
Posts: 9,865 MI, usa
dvw
MI, usa
Years ago my street car ran 11.72. It had 3” to the back bumper with Flowmasters. Removed the entire system (70lbs). Made a back to back run. It went 11.66 Doug
Re: Mufflers
[Re: dvw]
#2998852
12/27/21 01:34 PM
12/27/21 01:34 PM
Posts: 19,555 north of coder
moparx
were the flowmasters in the normal position around the rear seat, or at the end of the tail pipes ? some have suggested mounting the mufflers at the rear bumper. i was wondering why ? better noise control ? less restriction because of the cooler exhaust gasses ? another reason ?
Re: Mufflers
[Re: moparx]
#2998870
12/27/21 02:23 PM
12/27/21 02:23 PM
Posts: 4,694 Wichita
GY3
Wichita
Engine Masters on MTOD did an episode on this.
The Dynomax UltraFlows performed really well and is what we have on the car.
3" pipe to the mufflers and 45* turn downs at the rear axle. Car is quiet enough to have a conversation in going down the road but has minimal restriction.
I have had issues with one that keeps cracking where they stamped "DYNOMAX" in it. We've had to weld that up a few times but it's just on the one muffler. Other than that minor issue, very pleased with them.
