400 block #2991470
12/03/21 12:25 AM
12/03/21 12:25 AM
florida dade
cesar perez Offline OP
florida dade
Whats the largest crank I can put in a 400 block with aluminum rods. Do u guys thing that it would help block from breaking with grittle and aluminum caps
Re: 400 block [Re: cesar perez] #2991507
12/03/21 05:17 AM
12/03/21 05:17 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
If you have a stock block & are wanting to make as strong as possible, I would be going down the BCR cap n girdle path. I have a block in being sonic tested & magnafluxed, if it passes that test I'll be going the BCR direction. I already have a 4.25 crank to make a 512. .
Re: 400 block [Re: rebel] #2991515
12/03/21 06:54 AM
12/03/21 06:54 AM
st.louis,mo.
dart games Online content
dart games  Online Content
st.louis,mo.
ive had a 540 stroker out of a 400 block.which someday ill build another,it had a 4.500 crank,and bme aluminun rods,6.53
Re: 400 block [Re: dart games] #2991587
12/03/21 11:53 AM
12/03/21 11:53 AM
florida dade
florida dade
That's what I have but adding aluminum rods.
Re: 400 block [Re: cesar perez] #2991625
12/03/21 01:03 PM
12/03/21 01:03 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Adding aluminum rods can take up a lot of room. I personally would have gone to the smaller Chevy rod journals if I knew I would be going to aluminum rods with a 4.15 stroker crank in an RB Mega- block. which probably has even more room than the 400 block. I had to do quite a bit of measuring, grinding and trial fitting to accomplish it . DVW helped with an old picture of the bottom inside of a mega-block he was using. Don't think any of these are a drop-in with aluminum rods, especially standard big rod journals. Bill
Re: 400 block [Re: dart games] #2991735
12/03/21 05:06 PM
12/03/21 05:06 PM
Mo.
racerx Offline
racerx  Offline
Mo.
How is that holding up in a race application ?
Re: 400 block [Re: cesar perez] #2991870
12/03/21 11:55 PM
12/03/21 11:55 PM
What size rod journals on the crank?
I would and due put aluminum main caps and AARP main studs on all the 400 stroker motors I build and use up
Forget the girdles, they are a waste of money and give you a false since of security and hope down
Re: 400 block [Re: Cab_Burge] #2992148
12/05/21 06:37 AM
12/05/21 06:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
[quote=Cab_Burge
Forget the girdles, they are a waste of money and give you a false since of security and hope down [/quote]
what are you not seeing as a strong point with a cap n girdle kit Cab? These BCR units look awesome. Caps that fit snug between the webs, A girdle that mounts further out than the main studs for even more rigidity & is 1/2" thick. I'd be more inclinded to go this way than alloy caps.
Re: 400 block [Re: rebel] #2992219
12/05/21 12:18 PM
12/05/21 12:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That engine looks familiar grin
That is my 400 500" stroker that the machine shop overbalanced adding weight the the front crank throw. discolaration on crank throw from where they welded the weight in.
After running engine like that for a few races, I pulled it back apart and had the crank re-balanced where they removed the weight the other shop added.
After that episode, I bought a good scale and rod balance fixture to verify the balance on the other 440 source stroker kits which were OK.
The BCR caps and girdle are nice. The machining cost to install them is not cheap. Align bore/hone the crank bore, and mill the block/caps level was almost the cost of the cap/girdle kit.
I also had to make a custom 1/2" oil pickup, but it ended up basically just a straight tube welded to an old milodon pickup cup/screen, Using the milodon low profile 7-quart oil pan from my old 451 stroker engine.
Re: 400 block [Re: 451Mopar] #2992252
12/05/21 01:24 PM
12/05/21 01:24 PM
Alberta
440_Offroader Offline
Alberta
That set up does look awesome. Almost gives a new meaning to the term 'wedge'. Just a quick question though... Do the sides of each cap require machining where they meet the block, or is there some clearance in there?
Re: 400 block [Re: rebel] #2992266
12/05/21 02:07 PM
12/05/21 02:07 PM
look closely at that girdle, where does it add stiffness to the block? shruggy work shruggy
It may add some strength to the main studs from moving front to rear but is that useful and needed? work shruggy
My thinking is the 5/16 oil pan rail studs do nothing to help the main caps scope work
Buy a better block instead of trying to patch up a stock block, especially 440 blocks twocents
Re: 400 block [Re: Cab_Burge] #2992506
12/06/21 10:55 AM
12/06/21 10:55 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi Cesar, how is the weather in Florida?
Last time I was there in December 2010 it was snowing lol.
Snowing here now so I’m thinking of coming over ASAP.
Best Mopar block is the 71-72 400 casting.
So a great place to start for a stroker.
My Moparmate ran a 4.500 crank in his 400, it was over 1000hp... drive
Yes if it’s a long lasting block it has to be after market 4 bolt mains.
I’m sure Ali caps are a bonus and a girdle too.
We have used the 4 bolt STEEL ‘program’ caps for nearly twenty years!
Lots of machine work and hard to find good machine shops now... sawzall hammer spank
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 400 block [Re: 440_Offroader] #2992792
12/07/21 03:28 AM
12/07/21 03:28 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
There is a bit of clearance between the side of the cap and block, but the block casting was cleaned up also.
With the oil pan gasket, you can't see the nuts bolting the girdle to the block. The girdle holes for the oil pan studs are counter-bored so the nuts are below the oil pan gasket.
Because the oil pan rail and caps are milled flat, the girdle is right on top of the caps, and the caps bolted to the girdle on the outer wedge part of the caps (along with the normal main cap studs.)
More pictures on the web site:
https://www.bcrproducts.com/caps_and_girdle_system.html
After doing all the mods to the stock block, the costs started getting up there (around $1,600 for the caps, girdle, and machine work), but still way less than an aftermarket block which are around $5,000 these days.
https://www.manciniracing.com/engineblocks.html
https://billmitchellproducts.com/product-category/engine-blocks/mopar-big-block-2/
Re: 400 block [Re: 451Mopar] #2994823
12/13/21 12:49 AM
12/13/21 12:49 AM
gregsdart Offline
gregsdart  Offline
The girdles may provide some lateral stability but darn little virticle. Look at the block structure of the latest performance engines. Deep skirted blocks that do something. If I was going to build a girdle it would have a very tall structure , like three inch or maybe even more. Rather impractical though, hanging a three to four inch tall girdle on the block to transfer more of the load to the pan rail, which might not be strong enough to hold up . But it would help resist virtical forces a lot.
Re: 400 block [Re: gregsdart] #2994845
12/13/21 08:18 AM
12/13/21 08:18 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
All those girdles are gimmicks in my opinion. All you can do is periodically check for cracks.
Re: 400 block [Re: cesar perez] #2994873
12/13/21 10:44 AM
12/13/21 10:44 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If I wanted to make the most power I could using a stock block, I'd probably stop around 4" or less and put a long rod in it.
Re: 400 block [Re: cesar perez] #2995206
12/14/21 11:06 AM
12/14/21 11:06 AM
SWFL
Tie Rod Garage Offline
SWFL
If you decide to use the girdle and aluminum cap set up, Laz at Mesa Balancing did the machine work on my RB stroker with the the BCR parts. the only thing I can complain about is cap growth and low oil pressure if i let the idle go below 800 rpm. i did change to a Milodon 21814 pump which helped some. Oil pressure over 900 rpm or cold any rpm is fine.
1941 Dodge WC, 493 cid twin turbo FAST XFI
2002 Dakota R/T RC
Re: 400 block [Re: Tie Rod Garage] #2995230
12/14/21 12:22 PM
12/14/21 12:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Do you know what the main bearing clearances were set at?
