Denso Alternator terminals
#2992692
12/06/21 09:22 PM
12/06/21 09:22 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
Doing an upgrade to a Denso alternator that requires the pictured plug for the V regulator. I have the plug but it's the pigtail version requiring butt splice and go which I HATE What should be fairly simple has consumed quite a but of time trying to find the required terminals so I can wire it in without butt splicing. Someone has to know the correct terminal and hopefully a source. In addition any confirmation on dismantling the connector to get the terminals out would also be helpful. I THINK I have that part under control BUT confirmation would be nice Any help is greatly appreciated
Re: Denso Alternator terminals
[Re: TJP]
#2993057
12/07/21 10:03 PM
12/07/21 10:03 PM
TJP
Omaha Ne
The metri=packs i have are the smaller 150 series So I'm thinking maybe I need the 280 series ? here's a couple of pic's if anyone can confirm. The retainer flag appears a bit different ? I hate this as it is very frustrating trying to find what should be simple ARRRGGGGHHHH
[Re: TJP]
#2993224
12/08/21 01:42 PM
12/08/21 01:42 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I have the plug but it's the pigtail version requiring butt splice and go which I HATE I agree, the typical insulated butt connectors are butt ugly so I've started using the non-insulated type covered with shrink wrap; not as ugly.
[Re: John_Kunkel]
#2993228
12/08/21 01:52 PM
12/08/21 01:52 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Solder, heat shrink with sealer, harness tape and/or plastic conduit. Works for me, but I'm a function over form kind of guy.
[Re: Guitar Jones]
#2993287
12/08/21 05:23 PM
12/08/21 05:23 PM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
Solder, heat shrink with sealer, harness tape and/or plastic conduit. Works for me, but I'm a function over form kind of guy. Me too. Napa has a book of terminals and may have what you need or at least a way to look it up. On a side note and the way I do it. You have the terminal out. I have used pics and small screwdrivers to open terminals and remove the wire. I then reshape the terminal enough to get a crimp but solder it anyway. Works like a charm with a little effort.
[Re: IMGTX]
#2993383
12/08/21 09:58 PM
12/08/21 09:58 PM
TJP
Omaha Ne
Solder, heat shrink with sealer, harness tape and/or plastic conduit. Works for me, but I'm a function over form kind of guy. Me too. Napa has a book of terminals and may have what you need or at least a way to look it up. On a side note and the way I do it. You have the terminal out. I have used pics and small screwdrivers to open terminals and remove the wire. I then reshape the terminal enough to get a crimp but solder it anyway. Works like a charm with a little effort. I have done that as well but these little xOB's are pretty fragile appearing, but that would've been a last resort
[Re: TJP]
#2993480
12/09/21 07:49 AM
12/09/21 07:49 AM
Posts: 9,871 MI, usa
dvw
MI, usa
We had those terminals by the roll at FCA. The connector hard shell may have a number stamped into it. That can be used to look up the proper terminal. We used U shaped splice clips.
https://www.newark.com/amp-te-connectivity/485043-1/terminal-open-barrel-splice-crimp/dp/33B9065?gclid=EAIaIQobChMIuMCv_dLW9AIVQfbjBx1PSQvsEAQYAiABEgLKPPD_BwE&mckv=s95bbt2s8_dc|pcrid|434136793404|plid||kword||match||slid||product|33B9065|pgrid|100464450466|ptaid|pla-985509465520|&CMP=KNC-GUSA-GEN-Shopping-NewStructure-Connectors
When used with this style w crimp tool the crimp is no bigger than the wire itself.
https://www.amazon.com/Qibaok-Ratcheting-0-5-1-5mm%C2%B2-Connectors-Terminals/dp/B07RZSSTSJ/ref=asc_df_B07RZSSTSJ/?tag=hyprod-20&linkCode=df0&hvadid=366281307321&hvpos=&hvnetw=g&hvrand=10762719042515110981&hvpone
Doug
