Small block guys #2992560
12/06/21 01:32 PM
12/06/21 01:32 PM
CA.
RAY1969CARS Offline OP
CA.
What’s 6 inch rods are you using in your small blocks ???
Re: Small block guys [Re: RAY1969CARS] #2992586
12/06/21 02:38 PM
12/06/21 02:38 PM
I'm using a set of Scat small journal (2.00) SB Chevy 6.125 long H beam rods in a mild 360 offset ground stroker motor I'm making to sell up
I need to get the block rough bored and order the pistons for that project and get it done wrench
Re: Small block guys [Re: RAY1969CARS] #2992625
12/06/21 05:13 PM
12/06/21 05:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Mine had compstar. Nice rods.
Re: Small block guys [Re: RAY1969CARS] #2992646
12/06/21 06:03 PM
12/06/21 06:03 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Eagle H-beam => CRS6123C3D
Re: Small block guys [Re: Diplomat360] #2992677
12/06/21 08:18 PM
12/06/21 08:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Eagle H-beam, 6.123 IIRC. Bought 'em many years ago.
Been 7500 regularly & several times 8000, zero issues ever.
Re: Small block guys [Re: RAY1969CARS] #2992752
12/06/21 11:26 PM
12/06/21 11:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Molnar GM pin
Re: Small block guys [Re: RAY1969CARS] #2992814
12/07/21 09:41 AM
12/07/21 09:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Two sets of Compstars here, my 434 has 2.00 X 6.200 and my 408 had 2.100 X 6.125, No issues with either set.
Re: Small block guys [Re: justinp61] #2992829
12/07/21 10:39 AM
12/07/21 10:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I'm not running a 6" rod but I would highly recommend Molnar, good service and nice parts!
68 Barracuda Formula S 340
Re: Small block guys [Re: RAY1969CARS] #2992865
12/07/21 12:59 PM
12/07/21 12:59 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have run 6 inch Molnar rods with good results with 1.88 rod bearings.
I am running 6 inch Carrillo rods now. Custom for 1.85 crank, so far so good.
Re: Small block guys [Re: 340Cuda] #2992898
12/07/21 02:34 PM
12/07/21 02:34 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
compstar 2.00 x 6.200
callies ultra 2.00 x 6.125
Re: Small block guys [Re: usp4u] #2992985
12/07/21 06:35 PM
12/07/21 06:35 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
GRP 2.00 X 6.400
Lentz 2.00 X 6.200
Re: Small block guys [Re: RAY1969CARS] #2993005
12/07/21 07:37 PM
12/07/21 07:37 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Oliver 6.535” x 2.125”, .927 pin.
Re: Small block guys [Re: Leigh] #2994148
12/10/21 07:56 PM
12/10/21 07:56 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Carillo 6.25 x 2"
Re: Small block guys [Re: RAY1969CARS] #2994161
12/10/21 08:39 PM
12/10/21 08:39 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Wont find many that arent running a longer rod. Standard is 6.123
Many run 6.200, 6.300 stuff.
I ran 6.300 Compstars on the only ultra serious build i have had, very nice units. Cheap Callies
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small block guys [Re: B3422W5] #2994705
12/12/21 07:15 PM
12/12/21 07:15 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Which big end journal size are you going to be running? What Stroke? How much RPM do you intend on running?
You might need to look at a Carillo or something similar.
The Callies Compstar or Molnar stuff is nice for more budget friendly stuff.
Alan Jones
