Re: Small block guys
[Re: justinp61]
#2992829
12/07/21 10:39 AM
12/07/21 10:39 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I'm not running a 6" rod but I would highly recommend Molnar, good service and nice parts!
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#2994161
12/10/21 08:39 PM
12/10/21 08:39 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
What’s 6 inch rods are you using in your small blocks ??? Wont find many that arent running a longer rod. Standard is 6.123 Many run 6.200, 6.300 stuff. I ran 6.300 Compstars on the only ultra serious build i have had, very nice units. Cheap Callies
[Re: B3422W5]
#2994705
12/12/21 07:15 PM
12/12/21 07:15 PM
Posts: 6,148 Melbourne , Australia
LA360
Which big end journal size are you going to be running? What Stroke? How much RPM do you intend on running? You might need to look at a Carillo or something similar. The Callies Compstar or Molnar stuff is nice for more budget friendly stuff.
Alan Jones
