BB Road Race pan and dipstick ?? #2992385
12/05/21 08:41 PM
12/05/21 08:41 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
BB with Milodon Road Race pan and (if I remember correctly) the Milodon "stroker" windage tray. Anyone else have this combo ?? I don't think the dipstick is going down into the pan, I think its bending at either the windage tray or possibly one of the pan baffles. Problem is, I don't recall if the tray has the cutout or hole for the dipstick and likewise the pan.
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2992398
12/05/21 09:39 PM
12/05/21 09:39 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
External pickup model. Can you find a link to the tray? I might have one loose.
Re: BB Road Race pan and dipstick ?? [Re: Jeremiah] #2992415
12/05/21 10:29 PM
12/05/21 10:29 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a 70 383 with a stock dipstick that I put the 31580 pan on. It fit like a glove and the dipstick worked fine.
IIRC the tray had a dipstick cutout. It was a stock stroke.
Several people have reported the pickup hits the pan and requires reworking. Guy in here this year and I checked reviews and saw the same mentioned over the last few years. Not sure that would play into your issue, but worth mentioning.
I want my fair share
Re: BB Road Race pan and dipstick ?? [Re: SomeCarGuy] #2992476
12/06/21 09:36 AM
12/06/21 09:36 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Thanks for the photo. Looks to me like it might hit right here
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2992502
12/06/21 10:43 AM
12/06/21 10:43 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Pretty sure this is the tray - the others have way more holes and cutouts than I remember
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2992639
12/06/21 05:42 PM
12/06/21 05:42 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I needed I can measure the distance from the lip of the pan to the baffle support rail. Not sure if that will help solve the mystery. Let me know!
Re: BB Road Race pan and dipstick ?? [Re: Jeremiah] #2992658
12/06/21 07:05 PM
12/06/21 07:05 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I think what I'm going to do is take a piece of welding wire and stick it down the dipstick tube and measure where it bottoms out versus the length outside the pan. I'm also thinking of making a dipsitck adapter that will thread into that hole on the opposite side of the pan.
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2992683
12/06/21 08:40 PM
12/06/21 08:40 PM
New York, USA
Chargerfan68 Offline
New York, USA
Yes…..i had to cut the baffle at that location to use the stock-type dipstick.
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2992947
12/07/21 05:17 PM
12/07/21 05:17 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I have that pan and windage tray with an internal pick up. The dipstick would hit the pickup tube and deflect upwards, never dipping into the oil. When I flipped the dipstick around, 180 degrees, the curve went below the pickup tube and into the oil pan without a problem.
Re: BB Road Race pan and dipstick ?? [Re: 440Brian] #2993019
12/07/21 08:15 PM
12/07/21 08:15 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
You realize the hole in the block that the tube fits into is what dictates the tube direction, right ?!?!
Re: BB Road Race pan and dipstick ?? [Re: 440Brian] #2993056
12/07/21 10:01 PM
12/07/21 10:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hahaha . this just happened to me . I have run the road/race pan for 6 or 7 years on 3 different motors no problems . I just replaced the oil pan gasket last week and now stick only goes in one way .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: BB Road Race pan and dipstick ?? [Re: Stanton] #2993282
12/08/21 05:15 PM
12/08/21 05:15 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I'm talking about the dipstick, not the tube that it goes into. Mine has a slight bend, matching the tube. Installing it in the opposite direction of the bend of the tube causes it to pass below the internal pick up tube and into the oil pan.
Re: BB Road Race pan and dipstick ?? [Re: 440Brian] #2993336
12/08/21 07:43 PM
12/08/21 07:43 PM
I'm talking about the dipstick, not the tube that it goes into. Mine has a slight bend, matching the tube. Installing it in the opposite direction of the bend of the tube causes it to pass below the internal pickup tube and into the oil pan.
I've seen similar results on aftermarket aluminum deep sump drag race pans with baffles and trap doors, I've bent the last 1/2 inch on the tip of the dipstick around 15 degrees to make it fit one way in the pan and not fit the other way scope up
