Re: BB Road Race pan and dipstick ??
[Re: Stanton]
#2992398
12/05/21 09:39 PM
12/05/21 09:39 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
External pickup model. Can you find a link to the tray? I might have one loose.
[Re: Jeremiah]
#2992415
12/05/21 10:29 PM
12/05/21 10:29 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
I had a 70 383 with a stock dipstick that I put the 31580 pan on. It fit like a glove and the dipstick worked fine.
IIRC the tray had a dipstick cutout. It was a stock stroke.
Several people have reported the pickup hits the pan and requires reworking. Guy in here this year and I checked reviews and saw the same mentioned over the last few years. Not sure that would play into your issue, but worth mentioning.
I want my fair share
[Re: Stanton]
#2992639
12/06/21 05:42 PM
12/06/21 05:42 PM
Jeremiah
Rogue River, OR
I needed I can measure the distance from the lip of the pan to the baffle support rail. Not sure if that will help solve the mystery. Let me know!
[Re: Stanton]
#2992683
12/06/21 08:40 PM
12/06/21 08:40 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Yes…..i had to cut the baffle at that location to use the stock-type dipstick.
[Re: 440Brian]
#2993019
12/07/21 08:15 PM
12/07/21 08:15 PM
Posts: 8,907 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
When I flipped the dipstick around, 180 degrees, the curve went below the pickup tube and into the oil pan without a problem. You realize the hole in the block that the tube fits into is what dictates the tube direction, right ?!?!
[Re: 440Brian]
#2993056
12/07/21 10:01 PM
12/07/21 10:01 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
I have that pan and windage tray with an internal pick up. The dipstick would hit the pickup tube and deflect upwards, never dipping into the oil. When I flipped the dipstick around, 180 degrees, the curve went below the pickup tube and into the oil pan without a problem. hahaha . this just happened to me . I have run the road/race pan for 6 or 7 years on 3 different motors no problems . I just replaced the oil pan gasket last week and now stick only goes in one way . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
