Re: 750 cfm dominators
[Re: AndyF]
#2992226
12/05/21 12:29 PM
12/05/21 12:29 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
[quote][/quote] I assume you have a tunnel ram with a dual Dominator pattern that you are trying to use? For a street car a pair of 4150 carbs would be better but you could make the 750 Dominators work if you want to go that way. Not a very friendly street setup but if you only drive it in the summer to cruise in events then you should be able to live with it. Actually I was after the look of a dominator too. I don't have anything yet but I keep kicking the idea in my head. The car sees the track a few times a year also
[Re: Uncle Barry]
#2992231
12/05/21 12:42 PM
12/05/21 12:42 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A “750” Dominator is just a 2 circuit 1050 with skirted boosters in it.
I seem to recall it being a child of the “Pro Street” movement.
[Re: fast68plymouth]
#2992254
12/05/21 01:27 PM
12/05/21 01:27 PM
Uncle Barry
I don't know much about them so I figured I would ask on here. It's winter and I'm just in the thinking phase of a possible future change on my set up.
#2992297
12/05/21 03:34 PM
12/05/21 03:34 PM
Posts: 31,060 Oregon
AndyF
I had a 750 Dominator that I converted to a 1050 by changing the boosters. I used it on my 470 low deck. It made more power as a 1050 than as a 750.
[Re: AndyF]
#2992332
12/05/21 05:22 PM
12/05/21 05:22 PM
Posts: 12,409 Taxes & Virus's R-US, NY
Dragula
Honestly, many on here have probably run Dommy's on the street as I have, and yes, they are livable, but anyone who has had a pair of them and then gone back to a single will tell how much better even a single is over duals for drivability....
But the best way to satisfy the need to know might be to try it. and see...Obviously, anytime you put the time ,effort, and money into somthing, you can make it work.
Me, if I had a nice pair of restored 750 Dommy's., I would want to make sure they have screw in high speed and idle air bleeds at a minimum....Also, I would switch out the 4 -50cc accelerator pumps to 30cc ones....Jet and go from there. Bet it would be fun...
