Mid Plate or Solid Mounts #2991032
12/01/21 09:13 PM
12/01/21 09:13 PM
portland, ct
Since1822 Offline OP
portland, ct
So I have a new project for the winter that has a modified k frame with the motor mounts cut out of it. Previous owner used a mid plate that cracked. Car has an ar engineering front plate in it.
My question is at what point does a mid plate become necessary? Reason I ask is because I am thinking of replacing the k frame to one with mounts, running solid mounts with the front plate and eliminating the mid plate. Its easy enough to put a new k frame in at this point. Car is 9.80-10.0 ish back half race car. Any input would be helpful.
Re: Mid Plate or Solid Mounts [Re: Since1822] #2991107
12/02/21 12:02 AM
12/02/21 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been running a mid plate and a front plate since I built my car.. I run 2 limiter bars all along
and nothing has broke... love it this way(full tube chassis) running 8.90s in my SB
IF you keep the front plate wide you will have better leverage on the engine(less movement)
wave
Re: Mid Plate or Solid Mounts [Re: Since1822] #2991139
12/02/21 03:55 AM
12/02/21 03:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
My S/P car has both plates as well as a tranny mount, no travel bar limiter front to rear shruggy
I've raced the car that way since 2013 when I got it, runs high 8s at 148+ MPH in the 1/4 mile, 5.5 at 125 MPH in the 1/8.
it is a full tube chrome moly chassis car with 4 link rear coil overs and A arm with coil overs in the front and a rack and pinion steering
It weighs 2850 Lbs. with me in it racing it. shruggy
Re: Mid Plate or Solid Mounts [Re: Cab_Burge] #2991162
12/02/21 08:32 AM
12/02/21 08:32 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would just replace the cracked plate I don't know if it helps but on my -090- steel mid plate I welded a 3/4" wide strip perpendicular to the plate in the area from approx the bottom corner of the block to the area where it bolts on the frame
Re: Mid Plate or Solid Mounts [Re: B1MAXX] #2991164
12/02/21 08:43 AM
12/02/21 08:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No mid plate in mine. It does have fore/aft travel limiters. 750 passes so far. 1.25/9.00/150@3325lbs.
Doug
Re: Mid Plate or Solid Mounts [Re: dvw] #2991174
12/02/21 09:28 AM
12/02/21 09:28 AM
an8sec70cuda Offline
Doug
iagree Same here. Front plate only w/ a poly trans mount and one fore/aft limiter. Been mid/high 8s at almost 3900 lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mid Plate or Solid Mounts [Re: an8sec70cuda] #2991198
12/02/21 11:00 AM
12/02/21 11:00 AM
Penna
70satelliteguy Offline
Penna
No mid plate in mine either! Just front motor plate solid mounts and poly trans mount. Don't even run any limiters. 3550 lbs. /8.72-157.1.27 60ft.
Re: Mid Plate or Solid Mounts [Re: Since1822] #2991262
12/02/21 01:37 PM
12/02/21 01:37 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
A mid plate is more than an engine mount, if it is properly mounted it stiffens the firewall area of the chassis and adds as a safety net of sorts if there is a catastrophic transmission failure. Not knowing what chassis aids you have ( full cage, roll bar only?? ) a properly sized mid plate can be mounted at the bottom and top to chassis/frame members and significantly reduce twist between the engine mount and forward rear suspension mount . Again more needs to be known about the car to give more in-depth opinion. but my vote if it’s a race car with modified chassis/body components it should at least have a 1/8" mid plate as a trans failure safety mechanism. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Mid Plate or Solid Mounts [Re: W.I.N. Racing] #2991688
12/03/21 03:02 PM
12/03/21 03:02 PM
moparx Offline
moparx  Offline
when using a mid plate, where is the best place to put the flex plate/torque converter spacer ?
behind the flex plate or in front of it ?
beer
Re: Mid Plate or Solid Mounts [Re: moparx] #2991714
12/03/21 04:06 PM
12/03/21 04:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Between the flexplate and crank
Re: Mid Plate or Solid Mounts [Re: B1MAXX] #2991720
12/03/21 04:35 PM
12/03/21 04:35 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
When you get down into the 1.20s in 60, you would be surprised how much that stuff moves with motor plates. They work great for torsional forces. Are lousy for fore and aft movement when it has to control hundreds of pounds at 2+ Gs. The car is literally trying to drive out from under the heavy engine/trans assembly that doesn't want to move. Newton's first law of motion.
I always control converter clearance with shims/washers between the converter and flexplate, and bolt the flexplate directly to the crank. Some of the Powerglide bellhousing/adapter packages are done differently.
Re: Mid Plate or Solid Mounts [Re: CMcAllister] #2991747
12/03/21 05:49 PM
12/03/21 05:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This takes care of the fore/aft movement.
Doug
Re: Mid Plate or Solid Mounts [Re: dvw] #2991930
12/04/21 10:13 AM
12/04/21 10:13 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I built that exact same set up and on the first pass broke the tabs off the tranny. haha
Re: Mid Plate or Solid Mounts [Re: B1MAXX] #2991955
12/04/21 11:58 AM
12/04/21 11:58 AM
portland, ct
portland, ct
I was thinking the same thing would happen.
Re: Mid Plate or Solid Mounts [Re: Since1822] #2992034
12/04/21 04:44 PM
12/04/21 04:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I didn't know if it would work when I built it either. That was 9 years and 750 passes ago. 60 fts mid 1.2x to low 1.3x depending on if it's being slowed to run 9.25 index. Weight varies from 3325 to 3550. Same case and tail housing since day one.
Doug
Re: Mid Plate or Solid Mounts [Re: dvw] #2992048
12/04/21 05:51 PM
12/04/21 05:51 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Small block car would go low 1.20s. Limiters on either side of the engine. Had 3/8" G8 bolts in the block in single shear. Broke one of the bolts one day. Bent the motorplate. Got my attention.
Re: Mid Plate or Solid Mounts [Re: moparx] #2992075
12/04/21 07:38 PM
12/04/21 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can use .090 steel(MIN) and dont need any spacers.. thats the way I'm set up
wave
Re: Mid Plate or Solid Mounts [Re: MR_P_BODY] #2992084
12/04/21 08:29 PM
12/04/21 08:29 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
All I am implying is those limiters aren't doing anything then, your motor plate and trans mount must be doing the job. Because if it comes to those limiters its going to take the outside of the aluminum ears off. up
Re: Mid Plate or Solid Mounts [Re: B1MAXX] #2992103
12/04/21 09:41 PM
12/04/21 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I was talking about was the min mid plate thickness... I have my limiters mounted from
my block over to the chassis on both sides
wave
Re: Mid Plate or Solid Mounts [Re: B1MAXX] #2992129
12/04/21 11:37 PM
12/04/21 11:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It has a stock replacement S-10 rubber trans mount. You'll notice that the heim joints are 90 degrees to each other. If there is any twist they wont bind at the trans ears or the crossmember tabs. The motor plate tabs are probably over built. Look at the bottom of the plate. It is also tied in at the bottom of the timing cover. Don't know if these items made a difference. I know a few guys have copied it with no failures. To be honest I would have put a mid plate in it, but the headers wouldn't fit.
Doug
