Re: Question about forum
[Re: ForceD]
#2991567
12/03/21 11:17 AM
12/03/21 11:17 AM
Posts: 19,907 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
You're not able to post in any locked thread. You should post them in the unlocked threads in the "engines" section of the classifieds (link below). There are several threads in there, broken down by engine type - small block, big block, Elephant Hemi, and modern/Gen III Hemi/other. Choose whichever one applies to your specific engine, pick any ad that's already posted, click "reply," and then post your ad as a reply. Be sure to include price, location, and contact info. You can post up to 4 pics per ad. If you are selling slant 6 stuff, it would go in modern/Gen III Hemi/other. https://board.moparts.org/ubbthreads/ubbthreads.php/forums/13/1/moparts-engines.html
Earning every penny of that moderator paycheck.
DBAP
[Re: ForceD]
#2991572
12/03/21 11:22 AM
12/03/21 11:22 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Certainly not this forum unless the engines have “let’s go Brandon” or BLM painted on them! You probably want to go in this forum: https://board.moparts.org/ubbthreads/ubbthreads.php/forums/13/1/moparts-engines.htmlFind the appropriate sub forum under that one. Like if it’s a big block, reply to the first post in that sub forum, or the last. Change the title to describe your engine. Then type your description and make sure to include a price and contact info or the mods will delete your post. Some newbies have trouble posting pictures. Look toward the bottom of your post you are creating and you will see a paper clip and the words attachment manager, click on that and add your pics. Good luck.
