Re: Mid Plate or Solid Mounts
[Re: Since1822]
#2991107
12/02/21 12:02 AM
12/02/21 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been running a mid plate and a front plate since I built my car.. I run 2 limiter bars all along and nothing has broke... love it this way(full tube chassis) running 8.90s in my SB IF you keep the front plate wide you will have better leverage on the engine(less movement)
[Re: Since1822]
#2991139
12/02/21 03:55 AM
12/02/21 03:55 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
My S/P car has both plates as well as a tranny mount, no travel bar limiter front to rear I've raced the car that way since 2013 when I got it, runs high 8s at 148+ MPH in the 1/4 mile, 5.5 at 125 MPH in the 1/8. it is a full tube chrome moly chassis car with 4 link rear coil overs and A arm with coil overs in the front and a rack and pinion steering It weighs 2850 Lbs. with me in it racing it.
[Re: dvw]
#2991174
12/02/21 09:28 AM
12/02/21 09:28 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
No mid plate in mine. It does have fore/aft travel limiters. 750 passes so far. 1.25/9.00/150@3325lbs. Doug Same here. Front plate only w/ a poly trans mount and one fore/aft limiter. Been mid/high 8s at almost 3900 lbs.
[Re: Since1822]
#2991262
12/02/21 01:37 PM
12/02/21 01:37 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
A mid plate is more than an engine mount, if it is properly mounted it stiffens the firewall area of the chassis and adds as a safety net of sorts if there is a catastrophic transmission failure. Not knowing what chassis aids you have ( full cage, roll bar only?? ) a properly sized mid plate can be mounted at the bottom and top to chassis/frame members and significantly reduce twist between the engine mount and forward rear suspension mount . Again more needs to be known about the car to give more in-depth opinion. but my vote if it’s a race car with modified chassis/body components it should at least have a 1/8" mid plate as a trans failure safety mechanism.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: B1MAXX]
#2991720
12/03/21 04:35 PM
12/03/21 04:35 PM
Posts: 11,649 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
When you get down into the 1.20s in 60, you would be surprised how much that stuff moves with motor plates. They work great for torsional forces. Are lousy for fore and aft movement when it has to control hundreds of pounds at 2+ Gs. The car is literally trying to drive out from under the heavy engine/trans assembly that doesn't want to move. Newton's first law of motion.
I always control converter clearance with shims/washers between the converter and flexplate, and bolt the flexplate directly to the crank. Some of the Powerglide bellhousing/adapter packages are done differently.
[Re: CMcAllister]
#2991747
12/03/21 05:49 PM
12/03/21 05:49 PM
Posts: 9,865 MI, usa
dvw
MI, usa
This takes care of the fore/aft movement. Doug
[Re: Since1822]
#2992034
12/04/21 04:44 PM
12/04/21 04:44 PM
dvw
MI, usa
I didn't know if it would work when I built it either. That was 9 years and 750 passes ago. 60 fts mid 1.2x to low 1.3x depending on if it's being slowed to run 9.25 index. Weight varies from 3325 to 3550. Same case and tail housing since day one. Doug
[Re: dvw]
#2992048
12/04/21 05:51 PM
12/04/21 05:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Small block car would go low 1.20s. Limiters on either side of the engine. Had 3/8" G8 bolts in the block in single shear. Broke one of the bolts one day. Bent the motorplate. Got my attention.
[Re: B1MAXX]
#2992129
12/04/21 11:37 PM
12/04/21 11:37 PM
dvw
MI, usa
All I am implying is those limiters aren't doing anything then, your motor plate and trans mount must be doing the job. Because if it comes to those limiters its going to take the outside of the aluminum ears off. It has a stock replacement S-10 rubber trans mount. You'll notice that the heim joints are 90 degrees to each other. If there is any twist they wont bind at the trans ears or the crossmember tabs. The motor plate tabs are probably over built. Look at the bottom of the plate. It is also tied in at the bottom of the timing cover. Don't know if these items made a difference. I know a few guys have copied it with no failures. To be honest I would have put a mid plate in it, but the headers wouldn't fit. Doug
