Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. #2990214
11/29/21 04:28 PM
11/29/21 04:28 PM
CA
jung Offline OP
jung  Offline OP
CA
Rather than hijack someone else's thread, I thought I'd ask here.
After having problems with two different manufacturers Hydraulic Roller lifters, I'd more or less come to the decision to throw in a set of solid rollers. Doubt my car even sees a thousand street miles a year and checking the lash every few outings is no big deal.
The Combo is a 505 RB based stroker, with Indy EZ MW ported heads (through pushrod oiling), Harland Sharp 1.5 ratio rockers.
After a lot of rummaging, I finally found my cam card - it's nothing radical, looks a lot like a Comp XR286 but with a wider LSA, which as I'm running power brakes and EFI probably isn't a bad thing.
Gross lift is IN .586", EX .544", duration @ .050 is IN 236, EX 244 on a 112lsa. Running whatever springs Comp suggested (I'm not sure what they are.)
With help from here, I'd narrowed the lifter selection down to:
Comp AMC, with the mopar tie bars #861-16 or..
Howard Cams 91735s
Both seem to have pressurised oil to the roller and can oil through pushrods, the Howards are notably cheaper.
Not looking for the perfect set up, just something I can run for a bit without having to worry about hydraulic lifters failing - does the set up with either of these sets of lifters sound doable?
Thanks!
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: jung] #2990228
11/29/21 05:35 PM
11/29/21 05:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would go with Johnson rollers, NOT johnson hylift, I have the expensive Morel hydros push rod oiling in my 512, I had to set them .020 from the bottom to quiet them down, wish I would have gotten Johnson's, if I go into my motor, I am going to try & make my hydros solid
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: CSK] #2990418
11/30/21 10:27 AM
11/30/21 10:27 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Curious, what kind of problems are you having with the hydraulic rollers? I would think with the introduction of hydraulic rollers with the later LA's, the Magnums, and now the third Gen Hemi's the technology would be sorted out by now.
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: 6PakBee] #2990497
11/30/21 02:12 PM
11/30/21 02:12 PM
CA
jung Offline OP
jung  Offline OP
CA
Both times the problem has been an odd lifter (or two) collapsing / not pumping up. Generally the failures have come soon after installation, few hundred miles tops. First with a Comp set, then Erson.
I've just double checked with Howards and the part # I listed is not correct, apparently if you want direct oiling to the rollers and through pushrod oiling for the rocker tips, it's the 91735 set. These are the made in the US, racemax lifters and are closer to the price of the Comps. (around $600 vs $800 for the Comp once I buy the tie bars.) I think the only difference I spotted between the two is the Comps have .8" roller and the Howards a .75". I'm leaning towards the Howards as I'll save the cost of another set of pushrods and I can't see why they would be inferior?
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: jung] #2990541
11/30/21 03:59 PM
11/30/21 03:59 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“Usually”, there is enough difference in pushrod seat height between hyd rollers vs solid rollers that a pushrod swap is necessary.
I’d also re-verify those lifters do indeed have pushrod oiling.
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: fast68plymouth] #2990547
11/30/21 04:13 PM
11/30/21 04:13 PM
CA
jung Offline OP
jung  Offline OP
CA
Oh definitely - the Ersons are 2.685 w 312 ball in the seat, the Howards are 1.756 w 312 ball, so will need to measure up for another set. I've almost got Smiths on speed-dial at this point! frown Howards did confirm by e-mail that they're OK for pushrod oiling - guess I'll find out, I can always send them back if not.
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: jung] #2990616
11/30/21 07:32 PM
11/30/21 07:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
shruggy Howards are reboxed,
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: fast68plymouth] #2990673
11/30/21 10:10 PM
11/30/21 10:10 PM
I heard years ago that here were only two automotive lifter manufactures in the U.S. and one of them went B.K. shortly after that. scope
Fast, do you know how many U.S companies are making roller lifters now for U.S. made motors?
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: Cab_Burge] #2990711
11/30/21 11:12 PM
11/30/21 11:12 PM
CA
jung Offline OP
jung  Offline OP
CA
I'm overthinking it for sure, there seem to be at least 7 or 8 options available but a lot look very similar (and I'm sure are probably made in the same place!) All I need is a set that have direct oiling for the rollers and through pushrod oiling for the rocker cups. With the modest cam and spring pressures I'm running I can't see needing anything too exotic.
I'm redoing the fuel system at the moment anyway so will make up my mind at some point. If anyone has experience with a similar combo, please let me know! Cheers all.
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: jung] #2990723
11/30/21 11:44 PM
11/30/21 11:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
When I was going through the cam change deal last year I spoke to Gaterman who makes the Hyd roller lifters for Howards. He told me some of the cam companies recommend too much spring pressure for the hydraulic lifter to operate. I can't remember the owners name but he was very helpful and eventually we came down to the solution for me was a solid flat tappet cam instead of a hyd, roller with my car being a manual transmission. Look up Gaterman lifters and talk to the owner there he is very helpful.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: fourgearsavoy] #2991076
12/01/21 10:27 PM
12/01/21 10:27 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I'm using BAM lifters out of FL.
Really nice pieces.
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: 65Fury440] #2991414
12/02/21 10:07 PM
12/02/21 10:07 PM
CA
jung Offline OP
jung  Offline OP
CA
I had a look at the BAM set - they do look good, not crazy expensive either. Definitely an option, thanks!
Re: Cam for 505 Stroker, swapping Hyd Rollers for Solid. Update. [Re: jung] #2993051
12/07/21 09:35 PM
12/07/21 09:35 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Np, I used the bushings with DLC, hopefully they last for years.
