Re: Flat HP Curve
[Re: INTMD8]
#2987490
11/21/21 01:47 PM
11/21/21 01:47 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Let’s say you built a run of 5 engines all exactly the same, or bought them...... like Crate engines. If you dyno tested them all back to back on the same dyno, the power curves and output should be very close.
Now take those 5 engines and stick them in 5 different cars with different transmissions, gears, converters, exhaust systems etc, and test the 5 different vehicles on the same chassis dyno.
I’m confident the chassis dyno results would be way different from each other than the 5 engine dyno tests.
If you’re really trying to determine what the power curve and output of the “engine” is........ put it on an engine dyno.
Re: Flat HP Curve
[Re: INTMD8]
#2987496
11/21/21 01:57 PM
11/21/21 01:57 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
horsepower is a calculated value, The dyno measures torque, the engine rpm is then used in the calculation Horsepower (HP) = (Torque × Speed)/5252, if the dyno computer does not have the real engine rpm the readings are not correct. I used a Mustang dyno for several years, they either were too lazy or did not have the proper equipment to read engine rpm. The old roller rpm trick is when you can not get a real engine rpm number. Mustang used to use what was called smart tach, and it was sometimes a challenge to get a proper rpm reading, as a regular distributor, MSD, coil on plug, waste spark, etc. all have different settings in the soft ware to condition the signal. If the vehicle has a manual transmission and you stick it in 1 to 1 ration usually 4th gear it is close, but an automatic especially with a loose converter, wasting your time. Depends on the dyno. Dynojet measures horsepower and calculates torque if it has an rpm input. Otherwise you just get horsepower vs speed. Are you sure you don't have that backwards? Because the rollers on a Dynojet absorbs torque. Torque is a measured output (from a strain gauge) and you need a rpm value to calculate horsepower. Joe
Without Data, you’re just another guy with an opinion.
Re: Flat HP Curve
[Re: sr4440]
#2987512
11/21/21 02:47 PM
11/21/21 02:47 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Yeah I'm sure.
What you described is not how a dynojet works, if we are talking inertia and not eddy current.
Re: Flat HP Curve
[Re: INTMD8]
#2987518
11/21/21 02:55 PM
11/21/21 02:55 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
Yeah I'm sure.
What you described is not how a dynojet works, if we are talking inertia and not eddy current. x2. Inertia dynos measure HP and then back calculate torque with an rpm signal. Eddy current dynos measure torque.
Re: Flat HP Curve
[Re: Blusmbl]
#2987560
11/21/21 04:39 PM
11/21/21 04:39 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Re: Flat HP Curve
[Re: Blusmbl]
#2987644
11/21/21 09:39 PM
11/21/21 09:39 PM
sr4440
Central TEXAS!!!!
Yeah I'm sure.
What you described is not how a dynojet works, if we are talking inertia and not eddy current. x2. Inertia dynos measure HP and then back calculate torque with an rpm signal. Eddy current dynos measure torque. I stand corrected, you both are correct, the dynojet measures work (hp) then can calculate torque with a rpm signal. Joe
