Re: 93 5.2 Magnum stumbles off idle. I'm stumped [Re: demon] #2985785
11/16/21 02:56 PM
11/16/21 02:56 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Another thing to check on the EGR is just below the throttle blades.
The EGR outlet holes are arranged in a “T” just below the throttle butterflys.
If one hole of the two holes on the T plugs up with carbon crud,
it will send all of the exhaust gas to one side of the V8
which will cause those 4 cylinders to stall out.
Re: 93 5.2 Magnum stumbles off idle. I'm stumped [Re: demon] #2985832
11/16/21 04:37 PM
11/16/21 04:37 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Originally Posted by demon
I did not remove the distributor.
One thing though, the engine seems to use more oil than it used to, and it will puff blue out the exhaust when restarted after it stumbles and stalls.
Ok based upon that you almost certainly have a bad intake pan gasket on the kegger. Look down the throttle body inside the intake. If you can see oil this is your problem. It will cause the motor to use oil and have a vacuum leak. Exactly what you are describing.
There are aluminum plates out there available to replace the stamped sheet metal piece on the bottom of the intake to make sure it does not leak again.
Re: 93 5.2 Magnum stumbles off idle. I'm stumped [Re: mgoblue9798] #2985895
11/16/21 08:46 PM
11/16/21 08:46 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Nope, I did the intake pan gasket a year ago. Ran fine until recently
Re: 93 5.2 Magnum stumbles off idle. I'm stumped [Re: demon] #2986007
11/17/21 09:50 AM
11/17/21 09:50 AM
USA
3
360view Offline
360view  Offline
3
USA
The PCV system design on the early Magnum’s is not the best.
Blue oil smoke might be an indicator that oil is being drawn in.
Even a tip top condition PCV system on a Magnum V8 allows more oil through than I like to see.
The valve cover baffles leave a lot to be desired.
If you install an oil separator in the line it will catch a lot of oil.
Re: 93 5.2 Magnum stumbles off idle. I'm stumped [Re: demon] #2986040
11/17/21 11:29 AM
11/17/21 11:29 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’d check it again, they do fail. The steel pan and aluminum intake move differently from hot to cold.
