I did not remove the distributor.
One thing though, the engine seems to use more oil than it used to, and it will puff blue out the exhaust when restarted after it stumbles and stalls.
The PCV system design on the early Magnum’s is not the best.
Blue oil smoke might be an indicator that oil is being drawn in.
Even a tip top condition PCV system on a Magnum V8 allows more oil through than I like to see.
The valve cover baffles leave a lot to be desired.
If you install an oil separator in the line it will catch a lot of oil.
