Tranny Cover vibrations #2982466
11/06/21 05:15 PM
11/06/21 05:15 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
So is it crappy repro transmission covers ( 727 small block 71) that are causing the insane vibrations as I drive or is something else the culprit?
I replaced the missing cover , tightened everything down, no missing bolts an drove the car , it was fine.
Getting off the parkway and merging into traffic on road, I start hearing insane vibrations, so bad I think the transmission is about to blow. I gingerly drove it to my mechanic down the road (was going for an inspection).
He put it on lift and started car, and it was definitely the cover making the god awful noise. All bolts were secure.
Is the metal on the new covers just cheap and thin?
My other 71 with same cover doesn't vibrate at all. Not sure if it is a repro or not.
Mopar
Or
No
Car
Re: Tranny Cover vibrations [Re: MONC] #2982523
11/06/21 07:35 PM
11/06/21 07:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are the convertor bolts hitting the cover?
Re: Tranny Cover vibrations [Re: stumpy] #2982538
11/06/21 08:37 PM
11/06/21 08:37 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes, I seem to remember some little fingers on the cutout by the crank hitting if they don't seat right.
Re: Tranny Cover vibrations [Re: slantzilla] #2982542
11/06/21 08:44 PM
11/06/21 08:44 PM
MONC Offline OP
MONC  Offline OP
You mean the 2 small bolts at the bottom that act as a cover for the smaller inspection plate?
Was thinking about them as well. I was going to try and take them off first to see if that made a difference.
Mopar
Or
No
Car
Re: Tranny Cover vibrations [Re: stumpy] #2982548
11/06/21 09:08 PM
11/06/21 09:08 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
hahaThis.
Incorrect, bent or warped cover, cheap plastic cover, loose converter bolt, incorrect converter bolt. Correct converter bolts have thin heads and DO NOT use washers of any kind.
Cracked or bent flex plate.
Re: Tranny Cover vibrations [Re: GomangoCuda] #2982552
11/06/21 09:38 PM
11/06/21 09:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Myself, i usually run without them. If you find one that doesn't make noise, you should go to church on Sunday twocents
Do be aware that there are two different covers depending on the flexplate to converter bolt circle. beer
Re: Tranny Cover vibrations [Re: TJP] #2982563
11/06/21 10:20 PM
11/06/21 10:20 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Its easy to tell if its the cover, remove it and check for wear...but then again it would of hit and make noise on 1st start up..its not like it bends later
Re: Tranny Cover vibrations [Re: AARCONV] #2982642
11/07/21 09:55 AM
11/07/21 09:55 AM
MONC Offline OP
MONC  Offline OP
Exactly, not sure why it was fine for half the trip and then suddenly start vibrating. It didn't look cracked or anything when we inspected it on the lift.
I'll get under there today and check it out, thanks.
Mopar
Or
No
Car
Re: Tranny Cover vibrations [Re: GomangoCuda] #2982848
11/07/21 05:28 PM
11/07/21 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or the crank thrust bearing is severely worn. shock
Re: Tranny Cover vibrations [Re: MONC] #2983004
11/08/21 02:47 AM
11/08/21 02:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would remove the cover and look for a loose or missing converter bolt twocents scope
Re: Tranny Cover vibrations [Re: Cab_Burge] #2983355
11/09/21 10:16 AM
11/09/21 10:16 AM
MONC Offline OP
MONC  Offline OP
I removed the cover, didn't see any noticeable wear, and it wasn't cracked or anything.
I will check the converter bolts, good idea .
Mopar
Or
No
Car
Re: Tranny Cover vibrations [Re: MONC] #2983561
11/09/21 06:21 PM
11/09/21 06:21 PM
MONC Offline OP
MONC  Offline OP
Everything was tight and no sign of wear.
Just going to leave the cover off.
Mopar
Or
No
Car
Re: Tranny Cover vibrations [Re: MONC] #2983566
11/09/21 06:26 PM
11/09/21 06:26 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My cover would make noise until I shimmed the two lower bolts with some thin washers. I had no noise after that. I assume the cover must have been tweaked a little.
Re: Tranny Cover vibrations [Re: mopars4ever] #2983568
11/09/21 06:29 PM
11/09/21 06:29 PM
MONC Offline OP
MONC  Offline OP
Didn't make sense for me to shim the lower bolts, especially on a brand new cover, but glad it helped.
If I put it back on, I'll see if that makes a difference
Mopar
Or
No
Car
