Page 2 of 3 1 2 3
Re: Solid roller lifter on hydraulic roller [Re: AndyF] #2981703
11/04/21 03:20 PM
11/04/21 03:20 PM
CA
jung Offline
jung  Offline
CA
Hi Andy,
Why would it be a problem for a low mile, street driven car as long as you keep an eye on the lash? I ask, as I'm thinking of doing similar - I've had back to back failures with Comp, then Erson hydraulic roller lifters and was thinking of swapping over to the AMC solid variety. It's for a 505 stroker, with a modest Comp Hydraulic roller. It's a super pain in the bum because every time I have a problem, I have to pull one of the heads to get in to inspect (running Indy EZ heads with the valley plate that dovetails under the edge..)
Really appreciate your input. Ta!
Re: Solid roller lifter on hydraulic roller [Re: jung] #2981727
11/04/21 04:26 PM
11/04/21 04:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sorry but I'm just not understanding the logic of this. Presumably the OP has the solid roller lifters and is planning to purchase a new cam. So why not just buy a solid cam?
Re: Solid roller lifter on hydraulic roller [Re: Stanton] #2981741
11/04/21 05:09 PM
11/04/21 05:09 PM
CA
jung Offline
jung  Offline
CA
Not meaning to hijack the OPs original post but for me, I'm perfectly happy with my cam, it's the hydraulic roller lifters that have been problematic. Two sets, two manufacturers, both have had issues. Rather than roll the dice on yet another, I fancy the simplicity of solid lifters. They're a bit lighter too. I would have thought that with the slightly lower spring rates and less aggressive ramp, solid rollers should have an easier life on a modest hydraulic roller cam?
My car is definitely not a race car - probably less than 1500 miles a year and maybe an occasional trip up the strip for 'run what you brung' night.
Re: Solid roller lifter on hydraulic roller [Re: Stanton] #2981750
11/04/21 05:26 PM
11/04/21 05:26 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I'm considering a hydraulic roller. A friend suggested using a solid roller lifter on it. I'm just asking questions from those who have done it, pro's and cons.
America First!
Re: Solid roller lifter on hydraulic roller [Re: jung] #2981802
11/04/21 08:03 PM
11/04/21 08:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by jung
Hi Andy,
You do not have to pull the heads to remove the valley pan with Indy heads. Slice the RTV between the head and the tray with a knife. Then run the knife under the tray at the china wall. Tap the tray rearward with a block of wood, the RTV will break loose since its been cut. The tray can ow be tipped out of the valley. Done it more than few times.
Doug
Re: Solid roller lifter on hydraulic roller [Re: dvw] #2981814
11/04/21 08:26 PM
11/04/21 08:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Nothing like a bunch of crumbled RTV bits to clean out of the valley !!! While you have that pan out, throw it in the trash and install one with the removable center.
Re: Solid roller lifter on hydraulic roller [Re: Stanton] #2981820
11/04/21 08:41 PM
11/04/21 08:41 PM
CA
jung Offline
jung  Offline
CA
Definitely have to pull at least one head on mine (as far as I can see) - the valley tray dovetails under the heads on both sides so can't be lifted, even if you can break the RTV. Possible you could slide it but I'd have to pull the rad and everything for clearance. Oddly enough, I was planning on fitting the one with the inspection panel but I didn't anticipate how regularly I was going to have to inspect.... frown
Re: Solid roller lifter on hydraulic roller [Re: jung] #2981830
11/04/21 09:03 PM
11/04/21 09:03 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am going to mill my indy valley tray flat and tap it for an inspection plate. That thing is a pita compared to the setup on my victor headed deal.
Re: Solid roller lifter on hydraulic roller [Re: Jeremiah] #2981866
11/04/21 10:47 PM
11/04/21 10:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you do that, mill it all the way to the front and back. The Indy inspection plate could really do to be the full length of the valley.
Re: Solid roller lifter on hydraulic roller [Re: Stanton] #2981953
11/05/21 09:54 AM
11/05/21 09:54 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've had good luck with the Herbert roller lifters and cams. I dont run anything crazy - usually around .605 or .620 lift. They drop right in.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Solid roller lifter on hydraulic roller [Re: 69dart] #2981962
11/05/21 10:08 AM
11/05/21 10:08 AM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
I recently made this swap,using a custom spec comp grind. 243/247 @.050 .570/.575 lift split on a 107° Lsa. I used Howard's solid roller lifters, set them at zero lash, fired up great and ran great. I used trick flow dual springs with 190 lbs on the seat and 400 lbs open at .570 lift. Everythig was working out beautifully untill a carb baseplate screw decided to vibrate out and down into my #8 cylinder !! confused
It smashed between the piston and deck, lifted the head high enough to let water in and hydrolocked the cylinder.. cracking the #8 cylinder wall.. bawling
Please check your baseplate screws guys.. it was something i didn't expect to have bite me.
Engine is currently tore down awaiting a rebuild.😥 ... pulled the cam and lifters out.. everything looked fine.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Solid roller lifter on hydraulic roller [Re: jung] #2982033
11/05/21 12:15 PM
11/05/21 12:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I can see using a solid roller lifter on a hyd roller cam as sort of a “band-aid” for someone who’s trying to remedy a bad situation they’re going through with HR lifters.........like in jungs case.
But....... starting from scratch for a combo that will see pretty limited use?
Just give me the SR cam to go with the SR lifters.
Re: Solid roller lifter on hydraulic roller [Re: fast68plymouth] #2982048
11/05/21 12:43 PM
11/05/21 12:43 PM
CA
jung Offline
jung  Offline
CA
Ha...question for me is whether 3rd time's the charm or it's fool me twice...err...etc...:)
I was going to try the Comp 861-16s but I've just asked Howards about their 91727s to see if they have through pushrod oiling - they are priced attractively for sure.
Re: Solid roller lifter on hydraulic roller [Re: fast68plymouth] #2982062
11/05/21 01:22 PM
11/05/21 01:22 PM
California, U.S.A.
California, U.S.A.
Yeah, I see that logic. I was just trying to avoid Jung's situation from the start. Also hoping that the HR profile would be easier on parts while street driving. Honestly I didn't know that a " street solid roller" was a thing when I decided to go this route. "Street solid roller" is not a category I recall seeing in catalogs.. now I know.
Re: Solid roller lifter on hydraulic roller [Re: jung] #2982106
11/05/21 03:30 PM
11/05/21 03:30 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I had the same sort of thing with Morel lifters, using an Erson 231/236 HR cam in a little 406" engine. Just didn't want to work right for dyno breaking and tuning.. I had solid roller lifters laying about, so put them in after jumped through my own colon for pushrods and used with the HR beehive springs PAC I believe. Per Erson used .006/.008 lash. Engine worked fine, 435HP/445ftlb torque with a basic Performer intake and 8.something:1 compression. S/F....Ken M
Re: Solid roller lifter on hydraulic roller [Re: 451Mopar] #2982369
11/06/21 01:14 PM
11/06/21 01:14 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted by 451Mopar
Quote
I'm considering the XR 286 HR-10 Comp, their website states billet steel. I'm aware of the lash and having to experiment with it.
Running that cam in my 505" rb (0.030" over 440 with 4.25" stroke)
Running with Stealth heads, 10.3:1 compression, and 1.6:1 HS Rockers.
It is a fairly tame cam (running EFI), makes good torque, but I limit peak RPM to 6,000 RPM.
Using ISKY 8005A valve springs that are just a bit stiffer than the Comp 925-16 valve springs. Retainers (for the Isky springs) are Comp 748-16
Video was when it had a RPM Intake and 750 cfm carb, TTI 1-7/8" headers, and 2.5" TTI X-pipe exhaust with the TTI supplied Super Turbo Mufflers.
https://www.youtube.com/watch?v=0ui4GCHn_7o
I forgot to mention, the Lifters were from Hughes Engines, I think the HRC 91774, which were less expensive than the comp lifters.
I did not open up the pushrod holes on the heads, so I used custom 5/16" Smith Brothers pushrods, I think they are the 0.083" wall or thicker?
Re: Solid roller lifter on hydraulic roller [Re: Torquemonster440] #2982379
11/06/21 01:31 PM
11/06/21 01:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My old 451 Stroker had an Ultradyne street roller, 251/251 duration @ 0.050", and not much lift for the duration, I think 0.612" using 1.6:1 rocker arms. It was pretty quiet too using about 0.014"/0.016" cold lash.
I'm not that impressed with the Hydraulic Roller, it really is not quiter, or if it is, I can't tell over all the other rollerized parts in the engine. I still run Harlan Sharp adjustable 1.6:1 rocker arms, and have to adjust pre-load, much like adjusting lash, so not a big difference there.
The Hydraulic roller setup was more expensive than a solid, has heavier lifters, and weaker valve springs, so really recommend a rev-limiter of some type to not float a valve. To me it just seems the HR gives up performance to a solid for maybe a bit less maintance in adjusting valve lash?
Re: Solid roller lifter on hydraulic roller [Re: jung] #2983034
11/08/21 09:23 AM
11/08/21 09:23 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
So you'd rather pull a head off than just snatch the radiator out? shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Solid roller lifter on hydraulic roller [Re: an8sec70cuda] #2983036
11/08/21 09:33 AM
11/08/21 09:33 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I pulled my old Indy plate out from the front just slicing the sealer and sliding out then I slid the new Trick-Flow plate in there. The Trick-Flow plate is much nicer than the Indy plate and Summit stocks them up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Solid roller lifter on hydraulic roller [Re: fourgearsavoy] #2983090
11/08/21 12:45 PM
11/08/21 12:45 PM
CA
jung Offline
jung  Offline
CA
That's a good looking part - ta for the suggestion! No issues with the fit on the Indy EZ heads?
Might give the sliding technique a go this time.
Page 2 of 3 1 2 3
