Re: Do Torsion bars just break?
[Re: theraif]
#2980429
11/01/21 01:21 AM
11/01/21 01:21 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
had one break in the pits after racing . swapped wheels , packed the boot just about ready to leave just siiting there . BANG .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2980434
11/01/21 06:31 AM
11/01/21 06:31 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I've never experienced a torsion bar break on my cars but Dad had 2. One on his 57 Hemi Desoto and one on his 66 383 Satellite. Both situations over night. Found when heading out to go to work the next morning.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
[Re: 8urvette]
#2980566
11/01/21 01:39 PM
11/01/21 01:39 PM
Posts: 22,783 Bitopia
jcc
Bitopia
I think your original, still unanswered, question was, "do TB's just break?". I have zero experience with that outcome, but what I have read here for nearly 20 years, the answer is yes, they just break anecdotally when parked, most of the time. Why, I have no idea, but am very curious. The explanations above do not address, IMO, why its most often when parked. It might be the ones that broke at speed, put the driver in the cemetery, and we never heard the real reason why they crashed?
[Re: lancer493]
#2980621
11/01/21 04:51 PM
11/01/21 04:51 PM
jcc
Bitopia
Yes, I agree that the failure process occurs overtime, exempting a hard crash, be it corrosion, fatigue, notch sensitivity, etc and/or some combination. What catches my attention, is the final chapter of that failure process according to years of reports here, often occurs suddenly, and at rest, which I find hard to explain. The cool down heat gradient idea is interesting.
