Re: Do Torsion bars just break?
[Re: AndyF]
#2980639
11/01/21 05:41 PM
11/01/21 05:41 PM
Posts: 23,275 Here
jcc
Here
A TB that 100,000? cycles lifespan for a final failure must be way over designed for the task, in that with the increasing stress concentration of a continuously growing crack, combined with the decreasing load bearing cross section area in play, means the bar has to be way over designed to endure the expanding crack until the final failure. I am not sure how much safety factor is built in intentionally to delay final crack initiated failures, which once begun, must be the final outcome.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: AndyF]
#2980640
11/01/21 05:43 PM
11/01/21 05:43 PM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
I replaced both of mine after I had to adjust one of them three times in less than a month. I didn't wait for it to break. It didn't break my heart to send a highly stressed fifty year old part to the scrap yard. The new bars haven't needed any adjustments since I put them in several years ago.
[Re: GomangoCuda]
#2980868
11/02/21 11:43 AM
11/02/21 11:43 AM
Posts: 20,235 north of coder
moparx
back in the mid to late 80's, my brother had a 73 or 74 dart sport [sunroof car-he hated that option. not sure why, it didn't leak]. he was going down a back street [35mph, possibly] and the passenger's side bar broke. just a "pop", and the car dropped. he thought he had a flat until he got out and looked. a different [new to the car] bar and all was well with the world. it was a break like Andy showed. our area is a salt zone, so that's what we blamed it on.
[Re: AndyF]
#2981066
11/02/21 08:24 PM
11/02/21 08:24 PM
Posts: 23,275 Here
jcc
Here
I'm currently building a custom set, B length, C Hex, CM 1.37"d hollow, approx 500ft/lbs, farmed out, IMO would be very costly.
[Re: AndyF]
#2981156
11/02/21 11:41 PM
11/02/21 11:41 PM
Posts: 782 wine country
8urvette
wine country
They do, but they cost a ton of money. I'll sell the used /6 bars I have for $40 if the OP wants them. Shipping will probably double that to $80 total but still will be a lot cheaper then new prices. Local CL might find some torsion bars, it is hit or miss around here for used torsion bars. Thanks for the offer. I just purchased a set of slightly thicker bars from "sway away". I hope they come soon, they claim to have several in stock.
[Re: AndyF]
#2981187
11/03/21 07:11 AM
11/03/21 07:11 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Can someone please share the list of torsion bar numbers? I know they should be paired and how to tell right from left? Even and odd part numbers even = right, odd = left ? Thanks in advance Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2981233
11/03/21 09:59 AM
11/03/21 09:59 AM
Posts: 349 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Anyone using a 50 year old six cylinder TB is asking for trouble! Seen lots of big block A Bodies running Six Cylinder TB’s for drag racing? They are supposed to give better weight transfer... Anything that keeps the car off the ground, tyres, TB’s leaf springs and shocks are Mega important. Never seen a broken TB myself but a lower ball joint failure on my Charger R/T, certainly gave me fright...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: 6PAX]
#2981306
11/03/21 12:24 PM
11/03/21 12:24 PM
Posts: 31,201 Oregon
AndyF
Not to hijack the thread but since we're on the subject of torsion bars, when installing them is there a specific way they are supposed to go in? I heard once they had to be "clocked" but never found out if that was true and if it was, exactly how are they supposed to be "clocked"? Factory torsion bars are clocked 30 degrees against the twist. So they have a pre-set against the twisting force of holding up the car. That is why they need to be installed on the correct side. If you install them on the wrong side (hard to do) then you defeat the pre-set. Aftermarket bars can be a crap shoot. There have been aftermarket mfgs who didn't understand the pre-set and they didn't properly clock their bars. If the bars are not properly clocked then the you'll have problems getting the car to sit at the correct ride height. I think most of those issues have been resolved but it was a big problem when Mopar first started jacking up the prices on bars and people started trying to make their own.
[Re: AndyF]
#2983867
11/10/21 05:13 PM
11/10/21 05:13 PM
Posts: 321 Staten Island, NY
RO23dave
Staten Island, NY
my ro23 belvedere, in ss/ea, has to weigh 3770 #'s, i had /6 tbars in her forever, then several months ago, on a Thursday, had to download some info from the tach. came back Monday opened garage door & car was sitting on drivers tire. remember this is a big wheelstanding heavy car, so I thought its life cycle had ended. just so happened I went to my chassis guy, for another problem, & just wanted to show him the bar & ask if this was a stress fracture, it broke in a 45* curl with a raised line on one side & a depression line on the other. he said you know how that happened? a welding arc. i looked closer & yup you could see where the arc had punctured/popped a tiny hole thru the paint & outer surface of the metal. guess over time the fracture just cut it's way across. nobody in the household ever heard the bar break. i could just imagine what would've happened if it broke going down track at speed. i have a picture of it but don't know how to post it. replaced the bars with another set of b body /6 bars & she's wheelstanding again. Dave #1355 ss/ea
[Re: RO23dave]
#2985519
11/15/21 06:41 PM
11/15/21 06:41 PM
Posts: 23,275 Here
jcc
Here
I thought these quotes from well known racing guru/author Carroll Smith are pertinent here, from his 1990 book "Nuts, Bolts, Fasteners and Plumbing Handbook", pages 26 &27:
Regarding Fatigue:
"The initial crack has reduced the cross-sectional area of the member. Consequently there is less material available to resist the next load cycle. We know that unit stress is load divided by cross-sectional area. Therefore, the next time the load is applied, the imposed unit stress will be greater than it was the last time (assuming an equal load). More important, despite the migrated dislocations, the jagged bottom of the initial crack acts like a first class stress concentrator. Just as wolves always go after the weakest member of the herd, as more load cycles are applied, the concentration of stress at the leading edge of the crack will cause the crack to enlarge until enough fresh material is engaged to resist the stress, this time. These fatique cracks are transgranular in nature; the fracture actually splits the individual grains of the metal rather than following grain boundaries. As a result, the opposing surfaces of the crack tend to be quite smooth in appearance."
"This repeated sequence of events creates typical smooth opposing surfaces with the telltale concentric beach marks that are also visible in the illustration. The beach marks are formed by the progressive enlargement of the crack and radiate outward from the focus of the original fault. Beach marks are characteristic of the fatique failure...…… The next sufficiently large load application sudden and catastrophic failure of the remaining portion of the metal. This last failure is intergranular in nature."
"The final rupture proceeds along the grain boundaries, leaving the individual crystals exposed as a rough and granular surface. This allows the self appointed expert to peer knowingly at the part and proclaim, "Ha! Just as I suspected, a crystallization failure" . When you hear this sort of statement, the proclaiming person from your list of those to be consulted in the future."
"it is important to realize that, in the fatique history of any part, neither the rate at which stress is built up within the part nor the period of the time over which the stress is maintained is significant."
