Re: For those "well my tranny never blew up" fools...
[Re: A727Tflite]
#2980247
10/31/21 01:57 PM
10/31/21 01:57 PM
Posts: 8,339 fredericksburg,va
cudaman1969
fredericksburg,va
That looks toasty. Hope he wasn't too scorched.
Is there any video of this one? Wrong class and wrong track. Never saw a video. Is that even Ron Mancini's signature? The second 9 in 1969 looks suspect. Thought he ran the 1964 in SS/DA class and it was Dallas when the trans blew? All the info and signature is bogus, and the neutral drop thing gets perpetuated because it sounds “cool”. How can you say that, I personally saw it many times, then there’s the spinning the tires, stagged, before the lights came down? They all tried stuff BEFORE the high stall converters came about. THE reason Sox, Grump, Landy and the rest ran a stick. I imitated that trick with my car back in the 60s felt like the whole car was coming apart. Stopped that real quick. One big time factory racer carried 3 or 4 trans with him to each race. But I guess I’m dreaming, has been a long time. Like the OP said get the best parts in the trans for your peace of mind.
[Re: A727Tflite]
#2980359
10/31/21 08:21 PM
10/31/21 08:21 PM
cudaman1969
fredericksburg,va
I’m speaking only in regards to the 64 Dodge mentioned here.
Yes, guys were doing the drops back in the day. In fact this driver built 25 transmissions specifically prepared to last longer than a standard 727 would. Chrysler made them available to factory guys and some others back in the day. That’s cool, can’t place the guy though. We both older than dirt but you know your stuff, I will listen to ya.
[Re: A727Tflite]
#3057222
07/07/22 05:22 PM
07/07/22 05:22 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Is there any video of this one? Wrong class and wrong track. Never saw a video. Is that even Ron Mancini's signature? The second 9 in 1969 looks suspect. Thought he ran the 1964 in SS/DA class and it was Dallas when the trans blew? All the info and signature is bogus, and the neutral drop thing gets perpetuated because it sounds “cool”. What's the deal with neutral starts in the 1960's? Was it ever a common strategy at the drag strip? I have never ever heard anyone proclaim they were a good idea or common. Until now...
[Re: A727Tflite]
#3057258
07/07/22 07:12 PM
07/07/22 07:12 PM
MoonshineMattK
NW Illinois
Back before converter technology advancements - they were worth some ET. But the risks were too high.
Thanks So neutral drops being "standard operating procedure lets say back in the 70's" https://www.youtube.com/watch?v=wNJabHbfe2w&ab_channel=UncleTony%27sGarage is not exactly accurate.
[Re: MoonshineMattK]
#3057292
07/07/22 10:09 PM
07/07/22 10:09 PM
Posts: 3,089 Michigan
A727Tflite
Thanks So neutral drops being "standard operating procedure lets say back in the 70's" https://www.youtube.com/watch?v=wNJabHbfe2w&ab_channel=UncleTony%27sGarage is not exactly accurate. Not SOP ever that I recall. They were used in the eliminators and class when needed. The special units built were good for 15 or 20 runs (depending on the car) then things got sloppy again. The units we built for Chrysler I think were for the 67 Nats when we were battling some Fords and Chevies for class.
[Re: A727Tflite]
#3057358
07/08/22 09:34 AM
07/08/22 09:34 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
My recollection is that it was at the 67 Nationals that the "No Neutral Starts" signs appeared on the Christmas Tree.
[Re: 340Cuda]
#3057599
07/09/22 08:28 AM
07/09/22 08:28 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I remember well the "No Neutral Starts" sign. I was there. EVERYONE was doing them, it was before the good converters that are available today. We had a 64 Hemi Dodge there, an aluminum nosed Super Stocker out of Ohio.
I was wondering when I'd see another "if you race a torqueflite you're gonna die" thread. It's been a while.
I'm 70 years old and have been racing one behind a Hemi in a 65 Dodge since 1969, and have never blown one up. In my 53 years of racing, I've seen three let go, and all of them were due to driver error. Build it right, pay attention to what you are doing at all times (which you should be doing anyway), and you won't have an issue.
But, what do I know?
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Steve1118]
#3057603
07/09/22 09:05 AM
07/09/22 09:05 AM
Posts: 2,524 PA
moparacer
PA
Its not just builder driver error....
If anything breaks in the driveline and you don't pull the trans apart and check the sprag, you are rolling the dice....
Twice now over the years I seen guys who broke rears or driveshafts fix them, drive the car around the pits to make sure the trans was "ok" then proceed to blow the trans up the next pass.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3057625
07/09/22 11:19 AM
07/09/22 11:19 AM
cudaman1969
fredericksburg,va
The number one rule to follow. Even if you have the steel drum it can still ‘roll’ over the sprag, the good drum doesn’t stop that. If anything breaks in the drive train IN FIRST GEAR pull it!
[Re: cudaman1969]
#3057635
07/09/22 11:39 AM
07/09/22 11:39 AM
Steve1118
Yep. I was pounded this early, and pounded it into my boys who race wedge cars.
I use low gear for putting it on the trailer, into the garage, and leaving the starting line only. In the water I start in second, and shift to high. With water on the tires it doesn't take much to get them spinning. I NEVER use low in the water, for anything. Why?
I notice a fair number of these explosions are done by cars that also do a little street duty. Go out, blow the tires off in low to impress the local kids, turn the sprag, bolt some meats on it and k-pow, there you go. Then you can blame it on the Transmission itself. Never mind that thousands have been raced for over a half a century, 99 percent of them with no issue.
Keep your stuff in good shape, den on't do stupid stuff, and pay attention. You won't have any problems.
[Re: 340Cuda]
#3057675
07/09/22 02:18 PM
07/09/22 02:18 PM
A727Tflite
My recollection is that it was at the 67 Nationals that the "No Neutral Starts" signs appeared on the Christmas Tree. The transmissions were built way before that. Indy may have been the first and only appearance of that sign.
[Re: Cab_Burge]
#3057733
07/09/22 06:35 PM
07/09/22 06:35 PM
Posts: 11,658 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm under the impression that trans brakes started the 727 explosion before steel or aluminum drums stop that I've seen a lot of roller clutches fail at the hit footbraking, even for me once. Usually, the guy gets his foot out of it before anything bad happens, or like me, they are using a 904. If it's not your lucky day, you have a problem. Floor, dash, windshield, roof, feet, legs, etc.... Roller clutches can and will fail. Regardless the good parts used. The bad stuff happens in a 727 with a stock cast drum and the engine spun over 5K if you don't get your foot out of it.
