New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: For those "well my tranny never blew up" fools...
[Re: tex013]
#2979477 10/29/2105:40 AM10/29/2105:40 AM
I haven't blown up a 904 during 35 years plus of racing. I have hurt them ,once due to an out of adjustment shifter. I am not required to have a trans shield to run mid 11s but I keep it in just in case. Its a pain when changing a motor or trans but I like having the security of it.
[Re: 11secdart]
#2979634 10/29/2103:05 PM10/29/2103:05 PM
Someone on here once said it's due the stock steel 727 front drum diameter being larger so it can't take the speeds created when the other parts (rear sprag?) fails? 904 rotating parts are small enough that it's less of an issue with those?
[Re: Neil]
#2979637 10/29/2103:19 PM10/29/2103:19 PM
So I'm a fool because "my tranny has never blew up"?
