Page 1 of 4 1 2 3 4
For those "well my tranny never blew up" fools... #2979469
10/29/21 12:28 AM
10/29/21 12:28 AM
Fulton County, PA
CMcAllister Offline OP
Mr. Helpful
Mr. Helpful
Fulton County, PA
...just a reminder. Listen to the advice you are given.
An oldie but goodie...
Re: For those "well my tranny never blew up" fools... [Re: CMcAllister] #2979475
10/29/21 02:54 AM
10/29/21 02:54 AM
A really bad day down under for a Mopar racer on the south end of this planet whiney
i hope he wasn't hurt also luck
Re: For those "well my tranny never blew up" fools... [Re: Cab_Burge] #2979476
10/29/21 03:32 AM
10/29/21 03:32 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Thats Brett my enhind builder . Foot brake
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: For those "well my tranny never blew up" fools... [Re: tex013] #2979477
10/29/21 05:40 AM
10/29/21 05:40 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
He shoulda had a steel jacketed aluminum front drum !
Re: For those "well my tranny never blew up" fools... [Re: dOc !] #2979484
10/29/21 06:30 AM
10/29/21 06:30 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
been there done that 727 are well known for that,so buy a 6k trans so it wont happen
Re: For those "well my tranny never blew up" fools... [Re: dart games] #2979489
10/29/21 07:02 AM
10/29/21 07:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Low band apply valve body and a billet drum cures this.
Re: For those "well my tranny never blew up" fools... [Re: fbs63] #2979517
10/29/21 09:25 AM
10/29/21 09:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
8.75 rear? Place your bets!!
Re: For those "well my tranny never blew up" fools... [Re: J_BODY] #2979519
10/29/21 09:31 AM
10/29/21 09:31 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Being down under I would bet 9" whistling 8 3/4 parts probably harder to find over there and we all know how easy they break stirthepot
Gus beer
64 Plymouth Savoy
Dana 60
Re: For those "well my tranny never blew up" fools... [Re: fourgearsavoy] #2979528
10/29/21 10:11 AM
10/29/21 10:11 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've seen at least 3 of them let go in person in similar fashion.
I've never seen a glide come apart like a 727.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: For those "well my tranny never blew up" fools... [Re: 69dart] #2979532
10/29/21 10:34 AM
10/29/21 10:34 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The sky is falling The sky is falling. Everything will break
Re: For those "well my tranny never blew up" fools... [Re: cudaman1969] #2979545
10/29/21 11:16 AM
10/29/21 11:16 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Never ever do a burn out starting in first gear. Never! Get a manual valve body.
Re: For those "well my tranny never blew up" fools... [Re: fbs63] #2979587
10/29/21 12:55 PM
10/29/21 12:55 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's all it takes.
And pull it and check/fix it if you break anything in the driveline under power.
And no low gear burnouts.
Correction. Everything can break. But there are simple, well known steps to take that can prevent it or stop it from being catastrophic.
Re: For those "well my tranny never blew up" fools... [Re: CMcAllister] #2979600
10/29/21 01:23 PM
10/29/21 01:23 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Did the car twist enough to blow the windshield trim into the air?
Re: For those "well my tranny never blew up" fools... [Re: MoonshineMattK] #2979607
10/29/21 01:53 PM
10/29/21 01:53 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I've never exploded a transmission in untold thousands of passes....
You guys worry to much...
Probably not going to happen either.....of course I run MANUAL transmission...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: For those "well my tranny never blew up" fools... [Re: MoonshineMattK] #2979610
10/29/21 01:55 PM
10/29/21 01:55 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I'm guessing trans parts hit enough of the cowl area that the trim flew off because of it.
Re: For those "well my tranny never blew up" fools... [Re: Blusmbl] #2979616
10/29/21 02:13 PM
10/29/21 02:13 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I was thinking "was that a coolant line"?
Joe
Re: For those "well my tranny never blew up" fools... [Re: Blusmbl] #2979618
10/29/21 02:17 PM
10/29/21 02:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yep been there done that. dana 60 broke the rear end. I made it to the 60 ft almost to second gear.
Re: For those "well my tranny never blew up" fools... [Re: VernMotor] #2979623
10/29/21 02:43 PM
10/29/21 02:43 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I haven't blown up a 904 during 35 years plus of racing. I have hurt them ,once due to an out of adjustment shifter. I am not required to have a trans shield to run mid 11s but I keep it in just in case. Its a pain when changing a motor or trans but I like having the security of it.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: For those "well my tranny never blew up" fools... [Re: 11secdart] #2979634
10/29/21 03:05 PM
10/29/21 03:05 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Someone on here once said it's due the stock steel 727 front drum diameter being larger so it can't take the speeds created when the other parts (rear sprag?) fails? 904 rotating parts are small enough that it's less of an issue with those?
Re: For those "well my tranny never blew up" fools... [Re: Neil] #2979637
10/29/21 03:19 PM
10/29/21 03:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Interesting...
So I'm a fool because "my tranny has never blew up"? shruggy
'63 Dodge 330
11.19 @ 121 mph
Page 1 of 4 1 2 3 4
