727 with 904 parts vs A Glide #2978418
10/25/21 10:33 PM
10/25/21 10:33 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Any body ever weigh them curios of there weight? work
Re: 727 with 904 parts vs A Glide [Re: racerx] #2978433
10/26/21 12:07 AM
10/26/21 12:07 AM
NY
challenger451ci Offline
NY
For reference, my stock case Glide with a JW BB Bell and deep pan is 123lbs. The Glide does have dump valves so that's probably a few pounds with the solenoids and lines.
Not 904 internals, but my 727 with a JW BB bell and deep pan is 150lbs for reference.
Re: 727 with 904 parts vs A Glide [Re: racerx] #2978490
10/26/21 08:41 AM
10/26/21 08:41 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I can tell you my glide conversion to "B" engine is heavier than a production 727. The JW bell adds some weight to everything. My conv. uses a GM based bell. I have a 1/2" midplate/adapter. Also 8" to 8" the GM converter is 'thicker'.
Re: 727 with 904 parts vs A Glide [Re: racerx] #2978999
10/27/21 06:42 PM
10/27/21 06:42 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
My all aftermarket glide weighs 106 lbs. Reid case, Sonnex 1.58 gear set, ATI aluminum pump and billet valve body.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: 727 with 904 parts vs A Glide [Re: challenger451ci] #2979239
10/28/21 01:06 PM
10/28/21 01:06 PM
NC
440Jim Offline
440Jim  Offline
NC
The PowerGlide weight will depend on a lot of parts you pick (and pay for).
The cast iron valve body is very heavy, and transbrake valve bodies are available both cast iron and aluminum.
Steel or cast iron drum vs aluminum drum.
JW bell, and my stock style crossmember mount has some weight too.
My PG trans weighs 129 lbs with J.W. Ultrabell for big block Mopar. Includes cast iron transbrake, deep pan, 7 clutch ATI steel drum.
You can get a PG down to about 100 lbs with aluminum valve body and aluminum drum, etc.
Re: 727 with 904 parts vs A Glide [Re: 440Jim] #2979290
10/28/21 03:53 PM
10/28/21 03:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Never weighted mine but it sure is nice to go from big block to small block in five minutes
47B06A71-AD11-46CD-9F68-E7586CC88C7C.jpeg75DA5150-DDA9-47EA-9270-8D484289EEE5.jpegD7E79C66-C77E-4904-9C3F-766A56E5A808.jpeg
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 with 904 parts vs A Glide [Re: racerx] #2979478
10/29/21 05:47 AM
10/29/21 05:47 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Whatever happened to the JW BELL that adapts a 904 to a BB ?
TONS cheaper than putting 904 internals into a 727 case tsk
Re: 727 with 904 parts vs A Glide [Re: dOc !] #2979605
10/29/21 01:39 PM
10/29/21 01:39 PM
Some of the stock 904 parts won't take a lot of HP shruggy scope
Knowing which racing parts to replace is the key to not failing twocents work
Re: 727 with 904 parts vs A Glide [Re: dOc !] #2979673
10/29/21 05:30 PM
10/29/21 05:30 PM
PA
moparacer Offline
moparacer  Offline
PA
That is the setup that 440Jim has in his pics. Same setup I have used for many many years.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 727 with 904 parts vs A Glide [Re: moparacer] #2979678
10/29/21 06:17 PM
10/29/21 06:17 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Keith Long has had a 904 with an Ultrabell behind a 496 in a B body for a few years now. The only failure so far was I believe the input shaft. He has someone making hardened shafts for him now.
He can't get bellhousings anymore.
Re: 727 with 904 parts vs A Glide [Re: slantzilla] #2979779
10/30/21 02:07 AM
10/30/21 02:07 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
904 behind a BB in a B-body? must be super light.
Re: 727 with 904 parts vs A Glide [Re: Runnoft] #2979780
10/30/21 02:10 AM
10/30/21 02:10 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Man that's light up
