Page 1 of 3 1 2 3
572 engine, PG or 727 trans? #2977925
10/24/21 05:40 PM
10/24/21 05:40 PM
AndyF Offline OP
AndyF  Offline OP
I'm working with a race team who is putting a 572 inch wedge (Indy block and heads) into a B body race car. Trying to decide to go with a PG or stay with the 727. I'm leaning towards the PG since they have a couple of other cars with glides in them so they have PG spare parts. Also, the PG can be built with an aftermarket case which is SFI legal while the 727 requires a blanket or shield. I'm not sure which will be quicker down the track. They bracket race so they car about consistency more than ET. My guess is that the PG should work just fine behind the 572 and it might be a tad bit more consistent since it only has one gear change.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977934
10/24/21 06:05 PM
10/24/21 06:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m going to say powerglide all the way BUT aftermarket case have been impossible to find. At least the ATI cases. I have three of them with gearsers ranging from 1.68-1.98 and we tried to order one for my son and they told me they probably wouldn’t have any this years. Jegs charged my card so I canceled the order. You may want to check to see what is available.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977935
10/24/21 06:12 PM
10/24/21 06:12 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
If it's light I'd go with a PG, if not I'd be leaning to a SFi case TH400 or something of that ilk. An SFi TH400 is something I've been considering for our car, re-certifying or replacing blankets/ shields etc is just a monumental PITA at the moment as no-one has stock. Also, I've no experience running a PG but I hear correct converter choice is paramount.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977936
10/24/21 06:19 PM
10/24/21 06:19 PM
NC
440Jim Offline
440Jim  Offline
NC
What kind of "B body race car?"
Tube frame, back half, ladder bar, 4-link, weight ?
Depending on weight and chassis., it could benefit from either one.
But without more info, a 800 hp engine in a 3100 lb car with a good chassis would be a great bracket car with a PG and the right converter.
A 750 hp engine in a 3400 lb car with a good chassis could work well with a 3-speed transmission.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977942
10/24/21 06:36 PM
10/24/21 06:36 PM
gregsdart Offline
gregsdart  Offline
I am a dyed in the wool fan of Torqflites', but in this case I would go glide if possible. A Torqueflite loses consistancy due to the first shift coming up real quick and too much starting line ratio. If they can't find a glide trans then I would run a rear gear like a 3.73 to reduce SLR to about 9.0 with the Torqueflite.
I had to go to an airshifter on an RPM switch to get consistant times, and even with a well prepped track and 15x33 goodyears sometimes my 60 ft might vary by .01 or more.
Re: 572 engine, PG or 727 trans? [Re: gregsdart] #2977952
10/24/21 07:05 PM
10/24/21 07:05 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My 572 runs a 727 with a 4.30 and 10.5 tires. It's done well in brackets and running index. This is the last time out. Couple of 60ft on the rear tire. First pass throttle pulled back. Last pass motor was wounded.
Doug
Re: 572 engine, PG or 727 trans? [Re: dvw] #2977954
10/24/21 07:09 PM
10/24/21 07:09 PM
Doug
I'm jealous whiney
I wish we could get that many runs in one day out here in the west luck
Wait, maybe if I could go more than one round I could whistling
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977959
10/24/21 07:22 PM
10/24/21 07:22 PM
illinois,u.s.
beezer Offline
beezer  Offline
illinois,u.s.
I would seriously consider a gear ratio change for the torqueflite. B-bodies would most likely be on the heavy side and all that weight is gonna be hard on convertors.
Re: 572 engine, PG or 727 trans? [Re: 440Jim] #2977968
10/24/21 07:37 PM
10/24/21 07:37 PM
AndyF Offline OP
AndyF  Offline OP
It is a gasser type of car with ladder bars and big tires. The 572 should make around 900 hp but it hasn't been on the dyno yet. I'm not sure on the car weight, maybe 3300 with the new aluminum engine. I think the car has 3.89 gears in the rear right now but of course those can be changed. It currently runs 9.70 with an iron block 505 so they are looking to step up next season. The new 572 just arrived from Best so they are getting ready to swap engines over the winter.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2977972
10/24/21 07:47 PM
10/24/21 07:47 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
I am certainly no expert, but I think vehicle weight & engine power are critical for this decision. Assuming 900+ hp and under 3000 lbs for a track only car that runs on well prepped surface the powerglide will be less expensive to buy, less expensive to maintain, and slightly faster with the right converter. If the car is heavy, less power, or needs 2nd gear launch for no prep then a 727 or TH400 may be better.
Re: 572 engine, PG or 727 trans? [Re: Craig J] #2978143
10/25/21 10:46 AM
10/25/21 10:46 AM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
If you do go with the 727 at least buy it from a super-stock racer like i did, great trans ! .........but now i would go with the PG.....and parts ................. good luck.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2978179
10/25/21 12:20 PM
10/25/21 12:20 PM
Call Dave or Darren at Pro Trans. 661-940-7400 and ask them about the gear ratios they would use in one of their 3 speed tranny for that car, I know they offer a 2.20 low gear and I think they offer higher low gear set than that like a 1.80 ratio also scope
i have friends who race in the P.S.C.A. heads up series with a lot more power than that that ran their, Pro Trans, tranny and love them up
Re: 572 engine, PG or 727 trans? [Re: Cab_Burge] #2978184
10/25/21 12:27 PM
10/25/21 12:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If its a bracket car then I would ALWAYS say a Glide, those who think weight matters to a glide need to buy a better glide. I personally have a Joels on Joy Proflite in my 3500+ lb Savoy and its been quite consistent as well but was not really built to bracket race so much. Ones less shift is one less opportunity for an issue.
Re: 572 engine, PG or 727 trans? [Re: Al_Alguire] #2978203
10/25/21 12:51 PM
10/25/21 12:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
In that application,if they are serious, Glide.
Hate to say it but it"s like the old 9" vs. 8.75 or 60 debate. Glide has been developed and supported in the aftermarket so much more and offers so many advantages, it's a no brainer.
Converter development, options and availability, Cases. Parts. Gear ratios. Even the cost for a top shelf unit.
Buddy just put a 1.68 gear in an old 2400# ladder bar car with a 555. Made it much more manageable.
I love the Torqueflites, but if you're gonna race and not just play, you gotta use the right stuff. Watching The Million over the weekend. It's nasty out there.
Re: 572 engine, PG or 727 trans? [Re: Al_Alguire] #2978205
10/25/21 12:55 PM
10/25/21 12:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I like the idea of the “all new” trans built with all the components designed for the rigors of drag racing.
So, budget allowing...... a TH400 or PG based combo would be my choice.
Re: 572 engine, PG or 727 trans? [Re: AndyF] #2978213
10/25/21 01:18 PM
10/25/21 01:18 PM
NC
440Jim Offline
440Jim  Offline
NC
900 hp, 572 CID will have plenty of torque to get that car moving with a PG.
I highly recommend the aftermarket case (with bell). All the guts should be aftermarket at that level, so there is some choice of 1st gear ratio. Like a straight cut 1.80 gear set. And the Turbo style input shaft with matching converter.
Re: 572 engine, PG or 727 trans? [Re: 440Jim] #2978234
10/25/21 01:58 PM
10/25/21 01:58 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
If starting from scratch - I would go with a glide. Could probably build a spare for what a 727 will cost to run at 900hp.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 572 engine, PG or 727 trans? [Re: 69dart] #2978237
10/25/21 02:03 PM
10/25/21 02:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
C4
Re: 572 engine, PG or 727 trans? [Re: 69dart] #2978239
10/25/21 02:04 PM
10/25/21 02:04 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
I started out with a 727 in the challenger i had years ago. The car was 2640 with me in it. I had issues getting the car to repeat, i put a 2.28 low gear in the 727 which helped some. i ended up putting a 1.80 glide in it, the car picked up a tenth and was a good bracket car after the switch. the car had a 572 (572-13 head) etc. car ran the best of 8.24 @ 165 with 1.15 60'
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: 572 engine, PG or 727 trans? [Re: FastmOp] #2978245
10/25/21 02:16 PM
10/25/21 02:16 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted by FastmOp
C4
It’s about time you got here. Aren’t you retired like most of us old timers. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 1 of 3 1 2 3
